Tristin Posted March 19, 2014 Report Share Posted March 19, 2014 Swapped out gauge clusters to a true 45K mile cluster; its pristine. Hoping the new gauges will eliminate my fluctuating fuel level. Also hooked up my clock so its actually working now. Quote Link to comment
danfiveten Posted March 19, 2014 Report Share Posted March 19, 2014 Its nice when the clock actually works. Quote Link to comment
Tristin Posted March 19, 2014 Report Share Posted March 19, 2014 With my current levels of money, wiring in my clock is about as fancy as I can get right now. Quote Link to comment
Brad's 510 Posted March 20, 2014 Report Share Posted March 20, 2014 Saturday, before the I.E. meet & Eagle Rock, I installed the front speakers that I have sitting in the garage for a while. Quote Link to comment
67_1600 Posted March 20, 2014 Report Share Posted March 20, 2014 Not as much as what I did as what I got - I was at the Lynnwood PnP and they'd just put an '87 E30 out and it had really nice black comfort seats. I didn't waste any time and got them out and even got a little discount with the sale they have going on right now. No, they're not the convertible seats but I think they're a better match. Now I just have to get them installed and find a new home for the blue pair I'd gotten not too long ago. 1 Quote Link to comment
Tristin Posted March 21, 2014 Report Share Posted March 21, 2014 Nice score! I was at the Lynnwood PnP Anything else worth checking out? I havent been to any of the local yards since I moved to this side of the water. Quote Link to comment
Brad's 510 Posted March 21, 2014 Report Share Posted March 21, 2014 Going to be driving the 510 from sunny So Cal to Kingman, Az. Saturday so I thought I would change oil, check stuff out, etc. Found the rear u-joint to have some movement in it, replaced it. Looked at the fuel filter that's between the tank & electric pump to see some debris in it & realized that there are intact flies in the filter. How in the hell....? Also, tried to fix the wipers, no luck. If you turned them off, the keep going. Pull the switch out partially, they stop. I think it's in the motor timing switch. Need to figure that out. Quote Link to comment
67_1600 Posted March 21, 2014 Report Share Posted March 21, 2014 Nice score! Anything else worth checking out? I havent been to any of the local yards since I moved to this side of the water. There isn't too much out right now but it really just depends on what you're after. There is that L16 long block plus a few other 70+ 510 parts in the back of the one truck but most things have been picked over by now. They do put out about 150 cars a week, so it's worth checking their inventory now and then. Quote Link to comment
Tristin Posted March 21, 2014 Report Share Posted March 21, 2014 There isn't too much out right now but it really just depends on what you're after. There is that L16 long block plus a few other 70+ 510 parts in the back of the one truck but most things have been picked over by now. They do put out about 150 cars a week, so it's worth checking their inventory now and then. Might roll over just to check it out. Thanks! Quote Link to comment
Ranman72 Posted March 23, 2014 Report Share Posted March 23, 2014 today I drove it on a fun run to an old covered bridge and old restored gas station it is a state park and for a small fee you can pull your cars down by the old station and have a pick nick lunch 2 Quote Link to comment
Brad's 510 Posted March 26, 2014 Report Share Posted March 26, 2014 Did a 700 mile road trip from Anaheim, Ca. to Kingman, Az. & back in the 510. Started having lower RPM ignition problems with the old Mallory point distributor about the time I got to my mom's place. Once off the 93, had 2-3 miles down paved/dirt/wash-board road, then 1/4 mile soft dirt driveway with 2 washes to get up to the house. 2 Quote Link to comment
the510keeper Posted March 26, 2014 Report Share Posted March 26, 2014 Thinking about pouring gas on it and lighting it on fire 2 Quote Link to comment
RTB Posted March 26, 2014 Report Share Posted March 26, 2014 Block and Rods have been prepped. Picking them up tomorrow. :thumbup: 1 Quote Link to comment
Busta Nut Posted March 26, 2014 Report Share Posted March 26, 2014 Pulled out and compared old to new to me today. That's a crazy design on those control arm brackets......never seen something like that....have you used them before?? Quote Link to comment
r0p0doe Posted March 27, 2014 Report Share Posted March 27, 2014 Reinstalled grill and put in harnesses, they keep me nice and sung. Also took her for a spin, need to get my carbs tuned this week hopefully. Quote Link to comment
jovial_cynic Posted March 29, 2014 Report Share Posted March 29, 2014 Installed the ignitor (thanks, eBay!) on the SR20DET and spent a while trying to get it to kick over. Apparently, the injectors aren't behaving, because it'll kick over (vroom!) when I dump gasoline in the intake. And since it's ALL of the injectors, I'm guessing it's a power line or ground for the whole bank of them. Fun fun. Quote Link to comment
RTB Posted March 29, 2014 Report Share Posted March 29, 2014 Put in newly powder coated front crossmember. Cleaned and painted the block. Hopefully selling some parts Monday to rebello. Quote Link to comment
dimeguy 510 Posted March 29, 2014 Report Share Posted March 29, 2014 same thing i have done for the past 4 months just walk by it and wish it would run. Quote Link to comment
skyblue Posted March 30, 2014 Report Share Posted March 30, 2014 Installed camber plates And bump steer spacers Quote Link to comment
hang_510 Posted March 31, 2014 Report Share Posted March 31, 2014 That's a crazy design on those control arm brackets......never seen something like that....have you used them before?? must be a few degrees between each groove Quote Link to comment
nixapgt Posted March 31, 2014 Report Share Posted March 31, 2014 Grabbed a set of $300 wheels and flipped the crossmember for the upcoming KA24de 2 Quote Link to comment
datzenmike Posted March 31, 2014 Report Share Posted March 31, 2014 Finish filling out your profile so we know where you are Quote Link to comment
Son_of_a_Datsun_Guy Posted March 31, 2014 Report Share Posted March 31, 2014 Drove the snot out of it... literally 3 Quote Link to comment
DISLEXICDIME Posted March 31, 2014 Report Share Posted March 31, 2014 Finally installed my control arm bushings and then my rear crossmember control arms r200 and Carrera coilovers. We will see how mutch the alignment guy hates me Quote Link to comment
edekalil Posted March 31, 2014 Report Share Posted March 31, 2014 Paid for the transmission repair now I have to get the 72/510 to the fella to swap out the trans and clutch. Quote Link to comment
