hessianben Posted May 18, 2009 Report Share Posted May 18, 2009 Just test fit them today with some duct tape. They're surprisingly close and won't require much modification. OOOOHHHHH!!!!! GIMMME!! Serious. where you got those???!!! what they called, where, when, gimme!:D More pics installed pleeeeze! Quote Link to comment
NSRz32 Posted May 19, 2009 Report Share Posted May 19, 2009 The plan for today after work is to install my fender mirrors, roll and pull the front fenders and the rear quarters, install my ZG fender flares, and to use the glass paint to do the highbeam housings in yellow. Hopefully I have time to get it all done haha OOOOHHHHH!!!!! GIMMME!! Serious. where you got those???!!! what they called, where, when, gimme!:D More pics installed pleeeeze! I should have some installed pics after tonight :) They're s30 ZG fender flares that i'm adapting to fit the 521. I have a set of 15x10 very low offset wheels that i'm installing so I needed some flares to fit them :) Quote Link to comment
datzenmike Posted May 19, 2009 Report Share Posted May 19, 2009 I cut the clutch off the front of a Z engine water pump, you know, the deeper hi-volume ones. This will replace the leaky one I have and work with my electric fan. Quote Link to comment
ariascarlos1990 Posted May 19, 2009 Report Share Posted May 19, 2009 how close to the pully did you cut at? Do you have a picture? Quote Link to comment
moparvwfreak Posted May 19, 2009 Report Share Posted May 19, 2009 changed the oil in the 78 yesterday. Valvoline 40W with a bottle of Lucas. hopefully my oil pressure will go up as well as startup pressure. Quote Link to comment
LCDC Posted May 19, 2009 Report Share Posted May 19, 2009 I extended my King Cab today, what does everyone think? Well, not really, but looks kewl, better then having an 01 on the side. Did anyone notice? :D Quote Link to comment
ariascarlos1990 Posted May 19, 2009 Report Share Posted May 19, 2009 I extended my King Cab today, what does everyone think? Well, not really, but looks kewl, better then having an 01 on the side. Weird how there is missing fence above the kc window....;) Quote Link to comment
jrock4224 Posted May 19, 2009 Report Share Posted May 19, 2009 photo shop......nice maybe make it into a submarine too.... Quote Link to comment
LCDC Posted May 19, 2009 Report Share Posted May 19, 2009 Weird how there is missing fence above the kc window....;) Nah, thats just heat rising off the top of the cab. It was a hot day. :D Quote Link to comment
ariascarlos1990 Posted May 19, 2009 Report Share Posted May 19, 2009 Nah, thats just heat rising off the top of the cab. It was a hot day. :D mmhmm.:cool: Quote Link to comment
LCDC Posted May 19, 2009 Report Share Posted May 19, 2009 photo shop......nice maybe make it into a submarine too.... Actually it was Mspaint. Done alot of work on paint. Check it out. Bastards on youtube screwed up on of my vids and took my edited dragon force song that I shortened up. Quote Link to comment
datzenmike Posted May 20, 2009 Report Share Posted May 20, 2009 (edited) how close to the pully did you cut at? Do you have a picture? I cut one before right up against the pressed on pulley. It's welded but I got too close and it worked off. This one I sliced the aluminum casing off and exposed the bearing. Then cut the outer race off and removed the balls. I left the inner race on. If I had a larger cutting wheel I would have 'trimmed' it but there's lots of room now so I'll leave it. http://i138.photobucket.com/albums/q251/datzenmike/720%20stuff/720stuffclutchfanremoval007Large.jpg[/img]"] http://i138.photobucket.com/albums/q251/datzenmike/720%20stuff/720stuffclutchfanremoval006Large.jpg[/img]"] All the Z20/22 and 24 water pumps I've ever seen have a deeper cavity and taller impeller inside. L series clutch fan/water pump: http://i138.photobucket.com/albums/q251/datzenmike/Lenginewaterpump.jpg[/img]"] Z series clutch fan/water pump: http://i138.photobucket.com/albums/q251/datzenmike/motorLwaterpump.jpg[/img]"] The 280z/zx uses the same one as above BUT the pulley doesn't line up. DUH! FYI:Also the plastic fan blades won't swap between the two styles. Get a factory made one, they have the smooth cast impeller. Most after market ones are crappy stamped steel with sharp edges and will likely cavitate when run up in the higher RPMs. I grabbed this one because it looked new... piece of shit, won't use it. http://i138.photobucket.com/albums/q251/datzenmike/720stuffclutchfanremovalLarge.jpg[/img]"] Edited May 20, 2009 by datzenmike Quote Link to comment
ariascarlos1990 Posted May 20, 2009 Report Share Posted May 20, 2009 Cool thanks. Quote Link to comment
moparvwfreak Posted May 20, 2009 Report Share Posted May 20, 2009 bought a nice beautiful dash for my 73, a fuse box for my 78, and a couple spare early grilles to play with. Quote Link to comment
Farmer Joe Posted May 20, 2009 Report Share Posted May 20, 2009 well lets see. took the truck to the car wash. wasted 7 bux cause the it still looks dirty. meh, whadaya gonna do. then i got rid of the wires that went to the auto trans and hooked up the reverse switch. cut out the downshift solenoid wires and put a new connector on the wire that goes to the starter solenoid. also took the EGR counter off the truck and a relay that wasnt hooked up to anything. then i re-routed the fuel line to go around the back of the engine. pretty much cleaned up all the wiring under the hood. it looks alot better now. oh and then went for a drive to the lake with the fiance with the datto. had a good day lol Quote Link to comment
polski ogorki Posted May 20, 2009 Report Share Posted May 20, 2009 well today i removed all my rockers and my head as i had a blown gasket. my motor is fresh and i decided to give her a bit too much last week!@#$ oops!so today i took it apart not knowin if it was the gasket or not! it was the gasket and i have a replacement but it is a lordco one and i have a nissan one waiting for pick up tomorow. does anyone know of the best option for a head gasket? im gonna pick up the nissan one tomorra and it is 90 bux! what do you guys think about head gaskets? what should i use? i have an L20 with a 360cfm holley,offy intake,comp cam(dont know the specs),and a header?the motor is stock but fresh with a stove pipe head.w58 imghttp://i637.photobucket.com/albums/uu93/polski_ogorki/P5190053.jpg imghttp://i637.photobucket.com/albums/uu93/polski_ogorki/P5190047.jpg imghttp://i637.photobucket.com/albums/uu93/polski_ogorki/P5190045.jpg imghttp://i637.photobucket.com/albums/uu93/polski_ogorki/P5190055.jpg imghttp://i637.photobucket.com/albums/uu93/polski_ogorki/P5190069.jpg imghttp://i637.photobucket.com/albums/uu93/polski_ogorki/P5190069.jpg imghttp://i637.photobucket.com/albums/uu93/polski_ogorki/P5190065.jpg img Quote Link to comment
polski ogorki Posted May 20, 2009 Report Share Posted May 20, 2009 ok im retarded cuz i can send pix Quote Link to comment
ariascarlos1990 Posted May 20, 2009 Report Share Posted May 20, 2009 Here yah go.. Quote Link to comment
polski ogorki Posted May 20, 2009 Report Share Posted May 20, 2009 i think i figured it out Quote Link to comment
polski ogorki Posted May 20, 2009 Report Share Posted May 20, 2009 thax im fukn dumb! Quote Link to comment
ggzilla Posted May 20, 2009 Report Share Posted May 20, 2009 Yikes, never seen a gasket blown out that much. Quote Link to comment
polski ogorki Posted May 20, 2009 Report Share Posted May 20, 2009 that was my drunken helper who did not help much Quote Link to comment
polski ogorki Posted May 20, 2009 Report Share Posted May 20, 2009 its a first for me too! Quote Link to comment
ariascarlos1990 Posted May 20, 2009 Report Share Posted May 20, 2009 I think my head gasket is going out to. :D Quote Link to comment
polski ogorki Posted May 20, 2009 Report Share Posted May 20, 2009 oh ya how can you tell? Quote Link to comment
