Stoffregen Motorsports Posted September 29, 2023 Report Share Posted September 29, 2023 26 minutes ago, mojojojo78 said: What about a Subaru setup? I saw a picture of someone stick a Subaru in the back of a 70's BMW. It didn't look bad. There are companies that make kits to remove the AWD differential from the transmission. Then you have a compact engine that puts out decent power. Just a thought. I believe someone makes a rotary adapter for the Subaru transaxle. I know I've seen a mid engined Datsun car before, but can't remember when or where. Have you guys ever seen the twin engined Mini Cooper? Quote Link to comment
builte Posted October 1, 2023 Author Report Share Posted October 1, 2023 I think I've only ever seen a twin engined school bus 1 Quote Link to comment
Ranman72 Posted October 6, 2023 Report Share Posted October 6, 2023 (edited) you would want to have a transmission transaxle type like they use in sandrails engine and trans bolt together auto or manual cv joint shafts out the side of the trans axle your gears stick back behind the driveshafts no matter what motor you use this will make the shortest drive unit the actual length to the axles would not be much longer then the motor the axles are about 9" to maybe 1' behind the back of the motor Edited October 6, 2023 by Ranman72 1 1 Quote Link to comment
datzenmike Posted October 6, 2023 Report Share Posted October 6, 2023 The truck runs pretty well as is and being a truck is useful for carrying 'stuff'. Fitting another engine or the stock engine behind the cab seems like a lot of work to make if non useful as a truck and to what end? I don't see any advantage to off set all the work involved. Quote Link to comment
thisismatt Posted October 6, 2023 Report Share Posted October 6, 2023 3 hours ago, datzenmike said: The truck runs pretty well as is and being a truck is useful for carrying 'stuff'. Fitting another engine or the stock engine behind the cab seems like a lot of work to make if non useful as a truck and to what end? I don't see any advantage to off set all the work involved. C'mon Mike, look at all the bagged/dropped trucks with the beds turned into swiss cheese. They're no longer trucks either 😆 Quote Link to comment
Lockleaf Posted October 6, 2023 Report Share Posted October 6, 2023 On 9/29/2023 at 10:16 AM, Stoffregen Motorsports said: I believe someone makes a rotary adapter for the Subaru transaxle. Kennedy engineering used to make one. Thats the only one I have ever seen though. I'd be interested if someone else is making one again. I have this build in my head of a Mazda rotary powered, Subaru AWD, b13 sentra front knuckled, Datsun 1200 fastback. Researching that nonsense is where I found those old kennedy engineering adapters. I called this build the MazDatSubaruDaSun 2 Quote Link to comment
Stoffregen Motorsports Posted October 6, 2023 Report Share Posted October 6, 2023 3 minutes ago, Lockleaf said: I called this build the MazDatSubaruDaSun I call that confusing as hell. 1 Quote Link to comment
datzenmike Posted October 6, 2023 Report Share Posted October 6, 2023 1 hour ago, thisismatt said: C'mon Mike, look at all the bagged/dropped trucks with the beds turned into swiss cheese. They're no longer trucks either 😆 Well they have slamming them as a reason. 1 Quote Link to comment
Jesse C. Posted October 6, 2023 Report Share Posted October 6, 2023 And there is always the Shogun way 1 1 Quote Link to comment
dew Posted October 12, 2023 Report Share Posted October 12, 2023 + 1 on Kennedy Engineered Products. Also fairly straight forward if you can find a rear clip of Porsche 944/928. For a pickup then use minimal drive shaft. My 521 is front mount mid-engine. Moved cab back 24”, engine Aprox 18” shorten bed. Then any IRS will work. Early Subi works with Z diff. Was the way I was looking until MX5 got plentiful. But I only expect 185hp. 1 1 Quote Link to comment
ratpatrol66 Posted October 12, 2023 Report Share Posted October 12, 2023 (edited) I put a SBC (small block chevy) in the back of my Patrol no pictures to prove it? Also put a SBC in the trunk of my 94 Roadmaster. Yeah sure but WTH. Edited October 12, 2023 by ratpatrol66 3 Quote Link to comment
Crashtd420 Posted October 12, 2023 Report Share Posted October 12, 2023 9 hours ago, dew said: + 1 on Kennedy Engineered Products. Also fairly straight forward if you can find a rear clip of Porsche 944/928. For a pickup then use minimal drive shaft. My 521 is front mount mid-engine. Moved cab back 24”, engine Aprox 18” shorten bed. Then any IRS will work. Early Subi works with Z diff. Was the way I was looking until MX5 got plentiful. But I only expect 185hp. Any pics of the 521? Quote Link to comment
dew Posted October 12, 2023 Report Share Posted October 12, 2023 Sorry guys. No pics worth seeing. Body up on blocks for 3.5” body drop & pulling doors in 2” each side. Then aged family need help and it’s been sitting 2yrs an hr away from me now. Cowl looked to be prewar (even has patches over where windshield pillars were). So when body measured close to a Ford Model A, had to find out what what other stuff Datsun used, like MG Midget windshield bolts onto dash side bolts, susp is MGC modified. So everything went vintage ‘30s style street rod. 79 LCA D21 spindles ect. widen frt track few inches to match 58” rear axel. Back to topic... I used 1/4” angle to make bottom of motor mounts. Ran straight edge off OEM frame bracket for tops, filled sides with 1/8” sheet. Done! Mid engine, just like MG, and vintage rods built in ‘60’s, open engine, open wheel rat. Late ‘60’s Mercedes grill shell mounted where old eng mounts used to be completes the look, and 11x27” tires, & 5.5” ground clearance. Just wanted to see what Datsun COULD have built in late ‘60s. Became a project to find what Datsun did to make a ‘30s car into a ‘70’ pickup, then reverse it without molesting the firewall, tho I did remove the roof. Ok, I like roadsters ! 2 1 Quote Link to comment
Stinky Posted October 16, 2023 Report Share Posted October 16, 2023 If Kennedy made an adapter, they still make it....all their adapters are made to order. 1 Quote Link to comment
Stinky Posted October 16, 2023 Report Share Posted October 16, 2023 You could do the above, w/most any FWD set-up. It would be fairly easy to find a 250HP V6 in a FWD car....Honda Accord, Honda Odyssey, mini-vans. 1 Quote Link to comment
Fred Key Posted April 24 Report Share Posted April 24 Did this way back in the early 80's Dual carbed tunnel rammed 350 chevy lt1 in a 78 620 long box. Old school M50 15's on Cragar 5 spokes and a crappy fitting fiberglass flare kit. Mounted in the box with a turbo 400 mated to a 4x4 transfer case at the rear bumper. The transfer case was a NP unit from an old ford if I remember right. In low range it was a beast up to around 50 mph. It drove a 3.73 geared 12 bolt posi mounted backwards and flipped. Used to drive it daily and race it on Dixon road on the weekends. Had a old aluminum canopy and a canoe on top. Would wheelstand through second gear and pulled off a 10 58 @ 137 mph @ Ashcroft. Screwed the back of the canoe pretty good. If anyone knows where it is now, let me know. stoopidfast@hotmail.com I have pics somewhere, will try to find them. Live like you mean it Fred 1 Quote Link to comment
