builte Posted September 25, 2023 Report Share Posted September 25, 2023 I'm thinking about it. Quote Link to comment
datzenmike Posted September 25, 2023 Report Share Posted September 25, 2023 For a clear advantage or just for showing it can be done? 1 Quote Link to comment
builte Posted September 25, 2023 Author Report Share Posted September 25, 2023 Either or I know for models that were made with power steering this would increase the ease of turn Quote Link to comment
builte Posted September 25, 2023 Author Report Share Posted September 25, 2023 Without* Quote Link to comment
john510 Posted September 25, 2023 Report Share Posted September 25, 2023 Just buy a VW beetle. 1 Quote Link to comment
builte Posted September 26, 2023 Author Report Share Posted September 26, 2023 Anyone could have a vw beetle with an engine in the back I'm looking to do something unique 2 hours ago, john510 said: Just buy a VW beetle. Quote Link to comment
bottomwatcher Posted September 26, 2023 Report Share Posted September 26, 2023 Do a fiero swap. V6 version. Quote Link to comment
datzenmike Posted September 26, 2023 Report Share Posted September 26, 2023 VW bugs are rear engine not mid engine. 510 IRS style would be best, the differential is solidly mounted so just mount engine and transmission in front and solidly bolt together and let the two driveshafts articulate. Total length would put the engine between the front bucket seats but it would be mid engine. Car is now all but useless for driving. L4 plus shortest 4 speed is around 45" so do some measuring. A truck maybe would possibly keep the engine outside the cab. Automatic would be easier to drive than manual but all transmissions are over 30" long and then there is the connection to the differential which couldn't be solidly bolted and needs a driveshaft making even longer. Best bet is a FWD and engine and swap in place of the stock differential. Here a truck has the advantage of keeping it out of the cabin. 1 Quote Link to comment
builte Posted September 26, 2023 Author Report Share Posted September 26, 2023 What do you think about a 620 with a chopped driveshaft lowered between the frame and mounted? 20 hours ago, john510 said: Just buy a VW beetle. Quote Link to comment
builte Posted September 26, 2023 Author Report Share Posted September 26, 2023 Last comment was for datsunmike Quote Link to comment
datzenmike Posted September 26, 2023 Report Share Posted September 26, 2023 The differential moves up and down so how will transmission connect? Short double cardan U joint? Measure from differential to cab. You would need somewhere around 55"??? or the clutch fan will be into the back of the cab. Interesting thought experiment but of no practical application. Will someone ride in the back to shift the gears? Relocate the gas tank? Best bet is a later V6 automatic FWD swapped in place of the rear axle. 1 Quote Link to comment
Jesse C. Posted September 26, 2023 Report Share Posted September 26, 2023 After quite a few beers, yes, that was talked about with some friends. One option was going with a 914 Transaxle with an adapter piece, obviously. Then there was the Corvair set up, since I have seen a few mid engine conversions. Then there was the "What to stick it in"? question. 510 wagon was the choice. And then make it a two door wagon while we where coming up with crazy shit. 1 Quote Link to comment
datzenmike Posted September 26, 2023 Report Share Posted September 26, 2023 8 hours ago, datzenmike said: VW bugs are rear engine not mid engine. ... and so are the Corvairs. Quote Link to comment
john510 Posted September 26, 2023 Report Share Posted September 26, 2023 9 hours ago, datzenmike said: VW bugs are rear engine not mid engine. 510 IRS style would be best, the differential is solidly mounted so just mount engine and transmission in front and solidly bolt together and let the two driveshafts articulate. Total length would put the engine between the front bucket seats but it would be mid engine. Car is now all but useless for driving. L4 plus shortest 4 speed is around 45" so do some measuring. A truck maybe would possibly keep the engine outside the cab. Automatic would be easier to drive than manual but all transmissions are over 30" long and then there is the connection to the differential which couldn't be solidly bolted and needs a driveshaft making even longer. Best bet is a FWD and engine and swap in place of the stock differential. Here a truck has the advantage of keeping it out of the cabin. Yes I know.Just flip the motor and tranny around.Flip the ring and pinion and bam,mid engine.Just like all the old school dunebuggies. Quote Link to comment
datzenmike Posted September 26, 2023 Report Share Posted September 26, 2023 To be mid engine it has to be in front of the axle. Even in a Long Bed there isn't room. Quote Link to comment
Jskinny Posted September 26, 2023 Report Share Posted September 26, 2023 Would this count?? 1 Quote Link to comment
datzenmike Posted September 26, 2023 Report Share Posted September 26, 2023 I consider that a mid engine. He'll need a V drive to send it back to the rear. I wouldn't cut the cab, hell with 50/50. Just add weight under the hood. Shifting would be ... 2....4....6 1....3....5..... interesting. 1 Quote Link to comment
wayno Posted September 26, 2023 Report Share Posted September 26, 2023 3 hours ago, datzenmike said: The differential moves up and down so how will transmission connect? Short double cardan U joint? Measure from differential to cab. You would need somewhere around 55"??? or the clutch fan will be into the back of the cab. Interesting thought experiment but of no practical application. Will someone ride in the back to shift the gears? Relocate the gas tank? Best bet is a later V6 automatic FWD swapped in place of the rear axle. I had a mid engine Dodge van like this above, a kid hit me head on while making a left turn in front of me, I will never own a mid engine anything again, there is nothing between the front of the van and ones shins, I could not get in the van afterwards and my legs did not have a scratch on them, but my nose hit the steering wheel and flattened it, I had to have my nose moved back into position with a two prong fork, and I had another surgery to open the left nostril up so I could breathe thru it, I was lucky to survive, my friends ankle got caught between the engine block and the front sheet metal of the van, he was in a cast for almost a year, mid engine, no thanks. Quote Link to comment
builte Posted September 27, 2023 Author Report Share Posted September 27, 2023 The plan is to make a crumple cage in the engine bay to prevent this and act as counter weight 54 minutes ago, wayno said: I had a mid engine Dodge van like this above, a kid hit me head on while making a left turn in front of me, I will never own a mid engine anything again, there is nothing between the front of the van and ones shins, I could not get in the van afterwards and my legs did not have a scratch on them, but my nose hit the steering wheel and flattened it, I had to have my nose moved back into position with a two prong fork, and I had another surgery to open the left nostril up so I could breathe thru it, I was lucky to survive, my friends ankle got caught between the engine block and the front sheet metal of the van, he was in a cast for almost a year, mid engine, no thanks. Quote Link to comment
builte Posted September 27, 2023 Author Report Share Posted September 27, 2023 And I plan on trying to find 5 speed automatic trans mission to run to the back then figuring out a differential that would level Quote Link to comment
Duncan Posted September 27, 2023 Report Share Posted September 27, 2023 That'll be a quick project over a few weekends.. 1 2 Quote Link to comment
datzenmike Posted September 27, 2023 Report Share Posted September 27, 2023 The steering column is a solid one piece with the steering box on the frame. It doesn't crumple. Quote Link to comment
Crashtd420 Posted September 27, 2023 Report Share Posted September 27, 2023 11 hours ago, builte said: And I plan on trying to find 5 speed automatic trans mission to run to the back then figuring out a differential that would level I'd ditch the leaf spring and go independent suspension in the rear... then use something like the z cars/ subaru differential that doesn't move.... 1 Quote Link to comment
datzenmike Posted September 27, 2023 Report Share Posted September 27, 2023 Couple the transmission directly to the IRS.... still not much room for this to fit in the box though. FWD would be better in the rear. 1 Quote Link to comment
mojojojo78 Posted September 29, 2023 Report Share Posted September 29, 2023 What about a Subaru setup? I saw a picture of someone stick a Subaru in the back of a 70's BMW. It didn't look bad. There are companies that make kits to remove the AWD differential from the transmission. Then you have a compact engine that puts out decent power. Just a thought. 1 1 Quote Link to comment
