Pedro Posted January 6, 2009 Report Share Posted January 6, 2009 Looks awesome. Couple of questions, are you guys painting with 2pac? If yes, are you only using the heat gun to cure the paint? or have you got heaters and fans in there as well? I'm keen to get a garage paint shop setup, just want some tips. Quote Link to comment
thisismatt Posted January 6, 2009 Report Share Posted January 6, 2009 I usually paint with Notorious B.I.G. Quote Link to comment
LAYEDOUTB2K Posted January 6, 2009 Report Share Posted January 6, 2009 looks real good. reminds me of my dads 4 door too. Quote Link to comment
Icehouse Posted January 7, 2009 Author Report Share Posted January 7, 2009 Looks awesome. Couple of questions, are you guys painting with 2pac? If yes, are you only using the heat gun to cure the paint? or have you got heaters and fans in there as well? I'm keen to get a garage paint shop setup, just want some tips. We did our best to heat the engine bay before painting and also kept it heated afterwards, I'm sure it's not the best practice but we don't really have any choice. We can't wait until summer, in the end there is no way it will be worse than it was :D Here are a few new pics, the brake lines and suspension are in, luckily we got the old brake lines that the PO took out. He did manage to loose the 1 to 1 valve and the brass cube behind the engine the thing that cuts the flow.... anyways here are the pics. Quote Link to comment
endubguy Posted January 7, 2009 Report Share Posted January 7, 2009 mmm... Blue ( homer simpson voice) Quote Link to comment
Icehouse Posted January 11, 2009 Author Report Share Posted January 11, 2009 Well we spent all saturday working on the 4 door, our goal was to get the engine in and running.... The engine was missing quite a few parts due to the PO, which I would like the thank Hainz for finding us the engine. We decided to use a s12 turbo trans with a KA bell since we didn't have any KA trans that worked, and the car came with a broken one so be basically put 2 and 2 together :D After doing a few engine swaps it's nice to get as much stuff in the engine bay as possible before the engine goes in just to make life a little easier. So we went through the stock engine harness and removed all the BS to clean it up and make it fit our needs. The engine went in at about 9ish, Dillon worked on making a auto trans mount work while Frank hooked up the fuel lines starter and dizzy, of coarse I wired the ECU :D Well about 2am we ran into a problem with the fuel pump which put a holt in the plans to fire it off :( Not wanting to be defeated we sprayed some fuel in the intake just to remind the neighbors who's the man!! Still needs to be taped but I wanted to make sure I had everything in there first. I know Rob one day I will use relay plugs :D Hey man those connectors are only 7 cents each at Homedepot :D Quote Link to comment
endubguy Posted January 11, 2009 Report Share Posted January 11, 2009 was this what you were doing when i called? lol Quote Link to comment
Bleach Posted January 11, 2009 Report Share Posted January 11, 2009 does Frank have another 510 that looks like this... that he's selling? Quote Link to comment
endubguy Posted January 12, 2009 Report Share Posted January 12, 2009 yea i think soo damn frank and his bottomless pit of 510s! :lol: Quote Link to comment
510er Posted January 12, 2009 Report Share Posted January 12, 2009 What are you going to do with the 3 ingnition switches... I know someone that needs one!!! me! Quote Link to comment
]2eDeYe Posted January 12, 2009 Report Share Posted January 12, 2009 was this what you were doing when i called? lol X2 :lol: Quote Link to comment
Icehouse Posted January 12, 2009 Author Report Share Posted January 12, 2009 Bleach the 510 on craigslist is one of Dillon's friends cars, he bought it but wants to sell it and his honda to get a driving datto (good plan if you ask me) instead of trying to save the one he has. Yeah sorry guys we where hard at work :D We always make goals in the morning and try are damnedest to get them done. Hopefully this weekend will be as productive :D Quote Link to comment
]2eDeYe Posted January 12, 2009 Report Share Posted January 12, 2009 Might wanna keep the following weekend free ;) Call me back :D Quote Link to comment
Icehouse Posted January 13, 2009 Author Report Share Posted January 13, 2009 Built this to connect the zx pump to the stock outlet on the fuel tank. I know what you are thinking :D Is the 1/4" line big enough? yep my truck has 1/4" lines and I have driven it around 50k with no problems. Now if the engine was going to be turboed 5/16's wouldn't be a bad idea :D Quote Link to comment
ggzilla Posted January 13, 2009 Report Share Posted January 13, 2009 Hey I called you Sat too, but only got your answering message. I figured you were working on a Datsun. 1/4" lines are only good for what? 125 HP? You could make an outlet that is both: starts out 5/16 but has a 1/4" tip, and later cut of the 1/4" tip if you upgrade. Like those cheap plastic filters, but in aluminum instead. Quote Link to comment
Pacific coast Datsun Posted January 13, 2009 Report Share Posted January 13, 2009 Coming along nice guys. How do you guys work in the cold? ;) Quote Link to comment
Cuts metal like mad Posted January 13, 2009 Report Share Posted January 13, 2009 wow for once I feel dumb for not knowing something... What exactly is the adapter you made used for? Fuel, ok, but why the 1/4" to what looks like 1/2"? Quote Link to comment
Icehouse Posted January 13, 2009 Author Report Share Posted January 13, 2009 Hey I called you Sat too, but only got your answering message. I figured you were working on a Datsun. 1/4" lines are only good for what? 125 HP? You could make an outlet that is both: starts out 5/16 but has a 1/4" tip, and later cut of the 1/4" tip if you upgrade. Like those cheap plastic filters, but in aluminum instead. HAHA lets just say they are good for 135 hp :D its 5/16 to the engine from the pump which is good. Coming along nice guys. How do you guys work in the cold? ;) haha :D Actually I bet it makes us work faster :D Quote Link to comment
Duke Posted January 13, 2009 Report Share Posted January 13, 2009 haha :D Actually I bet it makes us work faster :D The faster you work, the more heat you produce. I was working in shorts and flip flops today...it was mid 70's here:confused:. Way to warm for January (normal temps are around mid 50's). Quote Link to comment
Icehouse Posted January 19, 2009 Author Report Share Posted January 19, 2009 She's a driver!! Frank, Hainz and I took the 4 door to Clark the exhaust artist for one of his fancy jobs. Sorry no good shots of his work.... Damn some times I just forget to take pics... He is really fucking good at what he does, I like to call him an artist. For some reason Clark doesn't feel like he is one.... :D Of coarse I forgot to take an engine bay pic.... I wanted to get one after it was out of the canopy but totally forgot... Nice looking rig huh :D Clark welding on the new exhaust Hainz sporting his new hat! Quote Link to comment
Pacific coast Datsun Posted January 19, 2009 Report Share Posted January 19, 2009 Kool that shes on the road & i love that shade of blue. What kind [if any] of muffler is he running & is it loud ?? Is that a hat or heavy metal hair...? :lol: Just messin Hainz :D Quote Link to comment
Icehouse Posted January 19, 2009 Author Report Share Posted January 19, 2009 The car has one of those old "stinger" mufflers, I forget what they are called though... The motor cycle ones. Hainz's hat is made out of a fox :D Quote Link to comment
Duke Posted January 19, 2009 Report Share Posted January 19, 2009 That thing is damn clean. Good job guys! Good stance, nice original paint...makes me want a 4-door. Looks like it will make a good DD for somebody. Quote Link to comment
bonvo Posted January 19, 2009 Report Share Posted January 19, 2009 someone like me maybe :rolleyes: just a thought since my baby came to an untimly end Quote Link to comment
