agouge888 Posted January 7, 2019 Report Share Posted January 7, 2019 Hey...I’m new here. Just bought a stock 620 18L and I’m looking forward to my first real drive(Driving it on the trailer doesn’t count:) It starts fine most of the time and idles pretty good for around 30 seconds, it then will high idle for a minute or two then just die. It doesn’t sputter....it just dies It’s as if u cut the key off. It doesn’t restart until I pump it 3 or 4 times then it will finally start, but idles kinda rough and dies this time more like it’s not getting fuel. I looked at the stock carb and the butterfly is about 1/8 from being closed. When I get it started and it’s running rough...I can put my finger on the butterfly and close it till it’s about a 1/16 gap from closed and the idle smoothes out, but idle goes up to a high idle. It will still die randomly as if u cut the key off though. Shoukd I try a carb rebuild, or go with a Weber ? any help is appreciated. thanks Andy 1 Quote Link to comment
DanielC Posted January 7, 2019 Report Share Posted January 7, 2019 How old is the gasoline in the truck? How long has the truck been sitting? How dirty is the gas tank? Are there any vacuum leaks in the intake system? Before dealing with the carburetor, is the compression on the engine good? Are the valves adjusted correctly? Is the ignition system in good shape? How old are the spark plugs? Make sure the compression is good, and the ignition is good before you even think about the carburetor issues. The truck is 45 years old, getting the gas tank clean is a very good start no matter what carb you end up running on the engine. Fresh gasoline is also a good thing. Stock OEM Datsun carbs are very sophisticated. They are difficult to rebuild correctly. Additionally, if the throttle shaft is worn, that need to be corrected. But if you get the stock carb working, that is the best, in my opinion. If you can move the butterfly with your finger, that is not the throttle butterfly, that is the choke butterfly. It is connected to the throttle by some linkage. A carburetor had many different circuits for fuel to flow, depending on the operating conditions of the engine. There is an idle circuit, a low power cruise circuit, a wide open circuit at low RPM, an additional different circuit that comes into play at higher RPM, a circuit that is only in play when the engine is cold. That is only some of them. Learn and understand how all the different circuits on the carb work together, and when they are in play in engine operation. I took some automotive community college classes in the 1970's. One term (12 weeks) of the auto program was just on carburetion. I would suggest you clean the gas tank, and get fresh gasoline in the clean tank. Get a new fuel filter. Clean the float bowl on the carburetor. Be very careful, there are small parts on and in the carb that are very easy to lose. Next, I would check to make sure the idle circuit on the carb is not obstructed. That should keep you busy for a while. 2 Quote Link to comment
banzai510(hainz) Posted January 7, 2019 Report Share Posted January 7, 2019 My opinion here mostly same as above(Daniel) To me its running with the choke on bypassing the idle circuit. I would see if idle circuit is dirty or the power to the idle cut off valve is is bad. also make sure the 2nd barrel is fully closed. so it dosnt make it look like a vaccumleak. take the old fuel filter and cut it open if really bad with rust or dist then this will more likely confirm the above theory I have. Shoot lots of carb cleaner in there and rev the motor up. learn how to adjust points ignition and get a timming light. YOUTUBE Datsun!!!!! 1 Quote Link to comment
datzenmike Posted January 8, 2019 Report Share Posted January 8, 2019 Listen near the back of the carburetor and have a friend turn the ignition switch on (not start) then off, on, off, on, off. What you should hear is a faint clicking sound. If you don't the idle cut solenoid is not working. This is an electric shut off for fuel to the idle circuit mentioned above. No click, no fuel for idle... no run at idle. 1 Quote Link to comment
datzenmike Posted January 8, 2019 Report Share Posted January 8, 2019 The above applies when the engine is warmed up and the choke is OFF. The butterfly you mention is the choke plate. During cold engine start, a choke is used to make the fuel mixture richer so enough gas will evaporate for it to run. Once the engine and intake warm up this extra gas is not needed. An EFI engine sprays fuel in a fine mist that evaporates easier and is not as sensitive to engine temperature. The choke uses an electric heater that warm and uncoil a mechanical spring which turns and opens the choke plate. While the engine is cold and the choke on, a fast idle cam holds the throttle open to speed up the warming of the engine. While the choke is on no setting of the idle is possible or sensible. If the choke fails to open fully after 5-10 minutes the 12v supply to the heater may not be working. If the choke is set too rich it will literally 'choke' the engine and it won't run. 1 Quote Link to comment
Moist Lightning Posted January 8, 2019 Report Share Posted January 8, 2019 Lots of good info on the stock carb. but no one really answered the weber question. The weber is a lot simpler than the stock carb. Lots of diagrams and info available for them too. I would recommend getting one. especially if your not familiar with carbs. took me a while to comprehend all the circuits and functions, allot easier to learn on a weber 32/36. 1 Quote Link to comment
datzenmike Posted January 9, 2019 Report Share Posted January 9, 2019 On 1/7/2019 at 7:48 AM, agouge888 said: Hey...I’m new here. Just bought a stock 620 18L and I’m looking forward to my first real drive(Driving it on the trailer doesn’t count:) It starts fine most of the time and idles pretty good for around 30 seconds, it then will high idle for a minute or two then just die. It doesn’t sputter....it just dies It’s as if u cut the key off. It doesn’t restart until I pump it 3 or 4 times then it will finally start, but idles kinda rough and dies this time more like it’s not getting fuel. I looked at the stock carb and the butterfly is about 1/8 from being closed. When I get it started and it’s running rough...I can put my finger on the butterfly and close it till it’s about a 1/16 gap from closed and the idle smoothes out, but idle goes up to a high idle. It will still die randomly as if u cut the key off though. Shoukd I try a carb rebuild, or go with a Weber ? any help is appreciated. thanks Andy Couldn't find any mention of a Weber question. Course you could spend $300 on one but that's after you can't get the stock one to work, which probably costs nearly nothing. I would hate to replace a carburetor and then find out the problem was a combination of a part plugged fuel filter, the distributor needed new points and the plug wires were really bad. The best carb for the 620 is the stock one. It's already there, gives the best mileage and drivability in all weather and was designed for this engine. It is complex because of this. The Weber is simpler but is not made for the 620, does not drive as well but is a better performer. 1 Quote Link to comment
agouge888 Posted January 9, 2019 Author Report Share Posted January 9, 2019 Just a little update. I started the truck earlier today. Turned the key and it fired right up and ran perfect. I mean I don’t even pump the gas and it starts quicker than a new vehicle. I reved it up some and it’s crisp/ no hesitation or lag. It seems like timing is spot on. Could points / ignition still be bad if it runs this clean for the first couple minutes it’s started each day? I even pulled it in the garage. The truck is all stock w/ 63k original miles. This eve I checked fuel filter, changed it even though it looked very clean. Running new fuel. Pulled the plugs and checked compression for #1 (145psi) #2 (155psi) #3 (155psi) #4 (140psi). This was cold before it had been running again. Old Plugs were gapped at about .015 , so I put new plugs in while I had them out and gapped them at .032. Fired it up and it ran smooth again like earlier for about 2 minutes at a medium/ high rpm. It then began to sputter and the rpm”s started to come down like it was dieing...so I pushed the choke butterfly down till it was almost closed and the rpm went up again and it smoothed out and ran clean 30 seconds then died as if I cut the key off. It would not restart even pumping the pedal. I then put a shot of starter fluid in the carb and it tried to fire again. So it seems like after it starts to warm up...the fuel is getting cut off and it immediately dies. Also...on another note..... I do have a vacuum leak in the brake booster. With engine off..When the brake pedal is pushed down you can hear a puff of air in the throat of the carb. When u let the pedal back up...you can hear air escaping the brake booster. I unhooked the booster hose from the manifold tube and capped that tube off that leads to the manifold, hoping that that’s why it was idling high and would die, but it had no effect on the idle and it dying. It still does it. I’m gonna order a new booster ASAP and M/C and keep working on her. Where’s the best place to purchase booster and m/c? Thanks and keepem coming. Andy 1 Quote Link to comment
datzenmike Posted January 9, 2019 Report Share Posted January 9, 2019 Don't forget that while warming up, the choke is on and the mixture is over rich. As the choke comes off the engine gas to start running on the idle circuit without help from the choke. If the idle circuit is not working properly it will run poorly or not at all. The choke hides the problem with the idle. This could be why closing the choke plate helped. Did you turn the ignition on off on off and listen for the clicking sound???? 1 Quote Link to comment
banzai510(hainz) Posted January 9, 2019 Report Share Posted January 9, 2019 (edited) its the idle circut to me that not getting fuel or the mixture is off at the base of the carb with the screw and tension spring. I had one like this a 521 with no idle. It would rev up fine and run but no idle. Found 2 carb base bolts loose and then the mixture was off. set mixture and was fine. Edited January 9, 2019 by banzai510(hainz) 1 Quote Link to comment
agouge888 Posted January 10, 2019 Author Report Share Posted January 10, 2019 12 hours ago, datzenmike said: Don't forget that while warming up, the choke is on and the mixture is over rich. As the choke comes off the engine gas to start running on the idle circuit without help from the choke. If the idle circuit is not working properly it will run poorly or not at all. The choke hides the problem with the idle. This could be why closing the choke plate helped. Did you turn the ignition on off on off and listen for the clicking sound???? Got home this eve and checked it out further.. i had a friend turn the key and each time I can hear a click from what looks like a long cylinder on the carbs upper back side that I’m guessing is the idle circuit. Is there any way it could still be bad and not working,? thanks, Andy 1 Quote Link to comment
datzenmike Posted January 10, 2019 Report Share Posted January 10, 2019 Fi clicking it's only presumed to be working. You could unplug the wire and unscrew it. Watch out it has a spring and a pin inside. Catch those and set aside. Put it back together. This removes the solenoid function so that it cannot shut the gas off to the idle circuit. Try it now. 2 Quote Link to comment
banzai510(hainz) Posted January 11, 2019 Report Share Posted January 11, 2019 (edited) idle circut still could be full of rust. as its small hole aslo try messing with the mixture screw at base of carb Edited January 11, 2019 by banzai510(hainz) 1 Quote Link to comment
BOZO Posted January 11, 2019 Report Share Posted January 11, 2019 Could be an unvented gas tank. Maybe try feeding your gas from a separate container. Or even just temporarily removing the filler cap just to test. 2 Quote Link to comment
agouge888 Posted January 20, 2019 Author Report Share Posted January 20, 2019 Thanks for bearing with me guys. For a couple of days it wouldn’t idle at all. I could start it and keep about half throttle and it would run, but sometimes just die. Today I went at it agin. Went ahead and changed points (gapped .018) and it runs the same. Tried to run without gas cap...still same. I pulled the idle stop solinoid ( checkedit and the plunger comes in/out and clicks when I grounded it) as well as the idle mixture screw and squirted carb cleaner in both several good times. I could see a mist coming up from the barrel of carb when spraying both areas. Put back together and tried to start. Still won’t idle but will run if i keep pedal half way down. Ughhh! Pulled line from top of carb and cleaned needle and seat good. Pulled front glass off of bowl and sprayed cleaner into both holes at bottom as well as cleaned bowl. Cleaned and checked float. Put back together.....and tried it again. Had a friend hold the choke closed and it will idle somewhat. I can still rev it and it will come down to a rough idle again. The choke is now beginning to open. It slowly opens to almost all the way, but idle really lopes and idles rough up and down. Adjusted idle mix screw on pass side of carb from all the way in to almost all the way out. I did it slowly to let the engine catch up, and the mixture screw doesn’t make much of a difference whether in, 2 turns out, or all the way out. We loosened the dizzy and moved it a bit and it ran worse. I put it back and it revs crisp and nice again. Darn thing just idles rough, up and down, and still sounds like it might die at any second. I can close the choke and the idle goes up pretty high and smoother out. I replaced the vac. advance line, and several othe vacuum lines, and still the same. I finally plugged/ capped off all vacuum lines, even the auto Tranny line, power booster vac line, and the vac. ports on drivers side of carb. She still lopes at idle. As a change from yesterday...It does fire up now as soon as I hit the key, but then quickly idle runs rough. Where can I get a new base gasket. I do smell a rich smell. Exhaust is pretty strong smelling. Gonna try it next. I really wanna stay with the stock carb, but I’m pulling my hair out so far. Keeper coming guys. Thanks for the support, Andy agouge888 1 Quote Link to comment
wayno Posted January 20, 2019 Report Share Posted January 20, 2019 This sounds like a plugged idle jet or a non-functioning fuel cutoff solenoid. Down draft carbs are great when they work properly, they are a nightmare when not working properly, I had a Weber that did the weirdest shit, when I first started it it idled fine on fast idle, but the first time I touched the pedal it would not idle anymore unless I shoved the choke closed and gave it some throttle, I did everything I could think of to fix it, then I figured out that if I warmed it up and then shut it down and walked away for a half hour, then I could come back start it and it ran perfect for the rest of the day or until it cooled, then it would do the same crap all over again. That carb became someone else's problem, if they used it as a carb it was not my fault as I gave it to them as a parts carb. Have you taken that carb completely apart and cleaned it, and I mean every stinking piece, if my pressure washer gas sits in the carb too long and goes half bad, I have to remove the carb and clean it completely out, and it runs great after that. Another thing to keep in mind is that pump gas has a short shelf life, it starts going bad in a month, if you mix it with bad gas it goes bad the moment they mix. 1 Quote Link to comment
datzenmike Posted January 20, 2019 Report Share Posted January 20, 2019 1 hour ago, agouge888 said: I put it back and it revs crisp and nice again. Darn thing just idles rough, up and down, and still sounds like it might die at any second. I can close the choke and the idle goes up pretty high and smoother out. I replaced the vac. advance line, and several othe vacuum lines, and still the same. I finally plugged/ capped off all vacuum lines, even the auto Tranny line, power booster vac line, and the vac. ports on drivers side of carb. This would tell me it's running too lean. Most likely an air leak. When you add more gas (choke) it makes use of the extra air and revs up and smooths out. Also this is why it only affects idle. When revved up the air leak is too small to matter. If you've closed all the hoses and pipes off that only leaves the carburetor gasket. Inspect the carb body for a crack. Are the top and bottom intake bolts on tight? Have you had it off??? 1 Quote Link to comment
Charlie69 Posted January 20, 2019 Report Share Posted January 20, 2019 warmed up engine choke off no or rough idle is most likely a vacuum leak assuming the carb is good. I would use a gas can and run a hose to the carb. The tank and fuel lines are like rusty and full of shit if the y have not been thoroughly cleaned. Take some carb cleaner, brake cleaner, WD40 or starting fluid and spray around the base of the carb while engine is running and all vacuum fittings on the intake manifold and all the vacuum line ends where they are connected if the engine rpm increases then you have a vacuum leak. Quote Link to comment
agouge888 Posted January 20, 2019 Author Report Share Posted January 20, 2019 Ok...making some headway possibly. Wouldn’t start this a.m. first thing, so I primed with starter fluid and man it fired up and ran at low idle perfect with no sputter or even a miss(choke closed. 2 minutes in when the choke began to open it started sputtering. Sprayed with carb clean at the carbs base and did notice it went up in rpms some. Pulled the carb off....Could they have made the carb mounting nuts any harder to get to? I cut a perfectly good 12 mm wrench in half to get in there and have room to get them off of there:) ( that’s going in the tool box:). I pulled my base gasket off to inspect it and it has swelled places around 2 of the edges. I sure it was trying to separate the carb from the intake. Where can I get this 3/16” or so base gasket? there were no other gaskets on it. Should there be, or is this thicker gasket the only one? thanks fellas, Andy Quote Link to comment
datzenmike Posted January 20, 2019 Report Share Posted January 20, 2019 Best bet is to buy gasket material and make your own. Hell I use a cereal box for mine. Faster and cheaper in the long run than trying to find and order one that turns out wrong. Buy a circular hole punch from a dollar store. Try to save the original gasket using a sharp knife to peel it off. Draw the carb outline on the new gasket material. The two large center holes don't need to be perfect but try to get the bolt holes close. Use the hole punch to nibble away and make the bolt holes. For the two barrels just make a hole with the hole punch large enough to get scissors in to finish it. You can easily make a new gasket in the time it take to drive into town. You may need two as there may be a heat shield or plastic spacer between the carburetor and the intake. 1 Quote Link to comment
G-Duax Posted January 20, 2019 Report Share Posted January 20, 2019 Last year mine started having an idle issue. It turned out to be the diaphragm in the vacuum advance. Since you are going to throw points at it anyway, pull the vacuum line off the manifold, and suck on it (or use one of those vacuum pumps is your squeamish about old fuel deposits in you mouth), and see if the point plate moves like it should. If you can't pull a vacuum, or if it bleeds off right away, you need a new vacuum advance pod. Quote Link to comment
datzenmike Posted January 20, 2019 Report Share Posted January 20, 2019 If the idle is set properly the throttle plate is below the vacuum advance port and there is no vacuum signal to the diaphragm. There should be no change with or without the hose on. Quote Link to comment
G-Duax Posted January 20, 2019 Report Share Posted January 20, 2019 I run manifold vacuum, better performance. Quote Link to comment
agouge888 Posted January 23, 2019 Author Report Share Posted January 23, 2019 Whew! Still at it. I replaced old blistered carb gaskets that I know were causing a vacuum leak. Put everything back together and it didn’t help a ton, but did help. It still likes to have the clone closed when running. My mixture screw on the pass side of carb is still having no effect whether all the way in or anywhere in between. Any idea why nothing is happening? Again I sprayed that port good and needle looks good . I can let it run for 20 min with choke closed and high idle...it will eventually drop down in rpms as choke opens, but begins to stumble. It will maintain a rough idle after that. Thanks, Andy Quote Link to comment
Crashtd420 Posted January 23, 2019 Report Share Posted January 23, 2019 Does it actually take 20 minutes for the choke to open? Until you get off high idle the mixture screw wont matter, that mostly affects idle up to a certain rpm, then the main jets come in to play... your probably getting extra fuel from the main jet and the choke. What's the weather like where you are? Hot / cold.... You wanna get the truck to the point where its idling, even if ruff, then try to set your engine speed and mixture.... Also I believe you can adjust the electric choke to shut off sooner if its actually taking 20 minutes to open.... Quote Link to comment
