datzenmike Posted October 14, 2014 Report Share Posted October 14, 2014 There is a copper corrosion test for EP oils, I'll see if I can find it. A copper strip is dipped in warmed trans oil and rated on how much the oil attacks it over time. The test has a name, but can't recall it. The GL5 obviously does not disolve copper like an Alka-Setlser tablet but it does darken and tarnish it. On silver spoons, it you wipe the tarnish off enough times the spoon will wear out. Knowing that this is the case, Nissan probably errs on the side of caution, same as you wouldn't add something to your engine oil that 'probably' wasn't good for bearing material. I have several bronze 71B synchros around. Maybe I'll do my own test. 1 Link to comment
smoke Posted October 14, 2014 Report Share Posted October 14, 2014 There is a copper corrosion test for EP oils, I'll see if I can find it. A copper strip is dipped in warmed trans oil and rated on how much the oil attacks it over time. The test has a name, but can't recall it. The GL5 obviously does not disolve copper like an Alka-Setlser tablet but it does darken and tarnish it. On silver spoons, it you wipe the tarnish off enough times the spoon will wear out. Knowing that this is the case, Nissan probably errs on the side of caution, same as you wouldn't add something to your engine oil that 'probably' wasn't good for bearing material. I have several bronze 71B synchros around. Maybe I'll do my own test. Thought about doing that myself, just did not care quite enough. You will probably not see much but discoloration until you're on your death bed. Link to comment
q-tip Posted October 14, 2014 Report Share Posted October 14, 2014 I forgot to mention I shifted without using the clutch for a good 10k on said transmission.... Link to comment
smoke Posted October 14, 2014 Report Share Posted October 14, 2014 I forgot to mention I shifted without using the clutch for a good 10k on said transmission.... THANKS OBAMA! Link to comment
q-tip Posted October 14, 2014 Report Share Posted October 14, 2014 Nah, just lazyness, a synchronized transmission will rev shift quite nicely really Link to comment
smoke Posted October 14, 2014 Report Share Posted October 14, 2014 Yeah, the only time I use the clutch in the old ford is to take off and stop, the rest of the time, it falls right in with nothing fancy. Link to comment
q-tip Posted October 14, 2014 Report Share Posted October 14, 2014 Yeah, the only time I use the clutch in the old ford is to take off and stop, the rest of the time, it falls right in with nothing fancy. That's how I drive my Dodge, silky smooth. The old flat bed that was at the hog farm on the other hand, not so much. Had some Isuzu diesel and a 5 speed in it, had to rev match and use the clutch. We did haul 2 tons of feed on the bed without issue though. Link to comment
smoke Posted October 14, 2014 Report Share Posted October 14, 2014 Wish Ford made a 5 speed with the FE pattern. Well, they did, but 5th is just direct, so all you get is more shifting. I would love another gear, I had one of those gear vendor overdrives for a while, the kind the go between the engine and trans, but I scattered that fucker. Could just go to a taller gear I guess. Link to comment
q-tip Posted October 14, 2014 Report Share Posted October 14, 2014 My step dad has one of those in his cj5, don't have to worry about blowing that up with a 225 v6 though Link to comment
smoke Posted October 14, 2014 Report Share Posted October 14, 2014 I think I could if given enough time and booze. Link to comment
q-tip Posted October 14, 2014 Report Share Posted October 14, 2014 I'm not doubting that you or I could break it I'm just saying in that application with that driver it is highly unlikely to happen :lol: Link to comment
Chuck Most Posted October 14, 2014 Report Share Posted October 14, 2014 I'm not doubting that you or I could break it I'm just saying in that application with that driver it is highly unlikely to happen :lol: I know I could do it. Toss me the keys to ANY vehicle and I'll grenade it before it leaves the driveway. :D Link to comment
smoke Posted October 14, 2014 Report Share Posted October 14, 2014 I once broke a car by just calling the owner on the phone. Link to comment
q-tip Posted October 14, 2014 Report Share Posted October 14, 2014 I saw a broken car once......on the internet.... Link to comment
bananahamuck Posted October 14, 2014 Report Share Posted October 14, 2014 I like to "feel" safe. http://www.youtube.com/watch?v=QC-R3YUy9Wg 1 Link to comment
smoke Posted October 14, 2014 Report Share Posted October 14, 2014 Without even watching this, I will now recite a line from it....eeeeh, 2400 old man? I dunno, I'm gonna have to think about it. 2 Link to comment
DaBlist Posted October 14, 2014 Report Share Posted October 14, 2014 Good thing it was Merican made 1 Link to comment
tr8er Posted October 30, 2014 Report Share Posted October 30, 2014 I fuck'n love pumpkin Link to comment
Chuck Most Posted October 30, 2014 Report Share Posted October 30, 2014 Now it's sexy time... 1 Link to comment
datzenmike Posted November 2, 2014 Report Share Posted November 2, 2014 Go to Ontario and stand outside a McDonalds or WallMart. They are either still poking a Mac in their face or pushing a cart with 7 cases of bottled water, nothing else (wtf???) Chicks are the fattest I have ever seen and travel in herds. Good hunting. Link to comment
