q-tip Posted December 11, 2014 Report Share Posted December 11, 2014 You don't NEED spacers, I don't run any. Quote Link to comment
Josh K. Posted December 11, 2014 Report Share Posted December 11, 2014 Have you measured your bump steer? Quote Link to comment
q-tip Posted December 11, 2014 Report Share Posted December 11, 2014 Don't really have an issue with bump steer, car tacks pretty damn well. Quote Link to comment
jeph Posted December 12, 2014 Author Report Share Posted December 12, 2014 got some more work done today at work on lunch sand blasted and powder coated some parts. Before After also cleaned up my camber plates and put my tie rods together 1 Quote Link to comment
Trophy24 Posted December 12, 2014 Report Share Posted December 12, 2014 Nice looking stuff there! 1 Quote Link to comment
jeph Posted December 12, 2014 Author Report Share Posted December 12, 2014 Nice looking stuff there! Thanks! Quote Link to comment
q-tip Posted December 12, 2014 Report Share Posted December 12, 2014 If you are going low, please get adjustable lca's and tc rods. Quote Link to comment
jeph Posted December 12, 2014 Author Report Share Posted December 12, 2014 no i plan to have at least a finger gap above each wheel i want the car to be functional, and do a few road course days. im not into the super low, blown oil pan, binding axle stuff lol. Quote Link to comment
q-tip Posted December 12, 2014 Report Share Posted December 12, 2014 If you want to do track days with the proper setup I would also suggest LCA modification and adjustable tc rods. You can only get 2° of caster on stock parts 1 Quote Link to comment
datsunfreak Posted December 12, 2014 Report Share Posted December 12, 2014 You don't NEED spacers, I don't run any. 24 510s deep, I've never run them either. The one car I did put them on, it increased bumpsteer. ^_^ But never run super low and always run 280ZX struts, so... 1 Quote Link to comment
jeph Posted December 18, 2014 Author Report Share Posted December 18, 2014 a little update, did some more work on the engine bay, ended up spraying it with a new rustoleum texture paint called galaxy, did not know it had metal flake in it but its starting to grow on me and doesn't look too bad. Decided to hit up the brake lines with some steel whool its crazy how much better they look lol Also anyone know what these would be called? they sit on top of the coilovers in the front and rest underneath the camber plates. these ones are chewed lol Quote Link to comment
datsunfreak Posted December 18, 2014 Report Share Posted December 18, 2014 Also anyone know what these would be called? they sit on top of the coilovers in the front and rest underneath the camber plates. these ones are chewed lol Upper spring hats is what I've always heard them called? Quote Link to comment
jeph Posted December 18, 2014 Author Report Share Posted December 18, 2014 Upper spring hats is what I've always heard them called? Cool thanks i found them and their cheaper then i thought. https://technotoytuning.com/nissan/510/conical-upper-hats-coilovers-25-id-springs Quote Link to comment
q-tip Posted December 18, 2014 Report Share Posted December 18, 2014 Top hats are pretty cheap, if you're running the t3 coil over and camber plate youll need to top hat with the bearings in them Quote Link to comment
r0p0doe Posted December 18, 2014 Report Share Posted December 18, 2014 a little update, did some more work on the engine bay, ended up spraying it with a new rustoleum texture paint called galaxy, did not know it had metal flake in it but its starting to grow on me and doesn't look too bad. I like it man, looks good :thumbup: Quote Link to comment
jrock4224 Posted December 18, 2014 Report Share Posted December 18, 2014 gotta put some clear on that near chrome or it goes to shit ..... look at my truck bumperettes... 1 Quote Link to comment
denmarkboy Posted December 18, 2014 Report Share Posted December 18, 2014 gotta put some clear on that near chrome or it goes to shit ..... look at my truck bumperettes... sorry for the thread jacking thats about to happen , jrock can you pm me and address and way to reach you so when i am up there i can bring the stuff to you for the giveaway truck. tried to pm a ya dude but that babe is full ..no mass thanks , sorry again , and p.s. i do love the engine bay 1 Quote Link to comment
Fat510 Posted December 18, 2014 Report Share Posted December 18, 2014 do you remember how much compression you are running? Quote Link to comment
jeph Posted December 19, 2014 Author Report Share Posted December 19, 2014 do you remember how much compression you are running? its stock so 8.6:1 compression Quote Link to comment
jeph Posted December 19, 2014 Author Report Share Posted December 19, 2014 Got some work done today, i cleaned and painted my strut tubes, and took apart and rebuilt/cleaned the windshield wiper motor And the motor is in!!! Radiator is close but has plenty of room not bad for a ebay radiator. Also Ran into a problem today for some reason the lower ball joints i ordered are bigger taper then the ones i took off. Any ideas what i did wrong? summit said they are for a 1970 datsun 510. 2 Quote Link to comment
q-tip Posted December 19, 2014 Report Share Posted December 19, 2014 68-69 are 11mm stud and 70-73 are 14mm stud, it should fit. Maybe its misboxed? Quote Link to comment
Three B's Racing Posted December 19, 2014 Report Share Posted December 19, 2014 68-69 are 11mm stud and 70-73 are 14mm stud, it should fit. Maybe its misboxed? 68's yes, 69's not all and depends on manufacture month of `69. I have a `69 built July of `69 and it has the 14mm. 1 Quote Link to comment
Three B's Racing Posted December 19, 2014 Report Share Posted December 19, 2014 Got some work done today, i cleaned and painted my strut tubes, and took apart and rebuilt/cleaned the windshield wiper motor And the motor is in!!! Radiator is close but has plenty of room not bad for a ebay radiator. Also Ran into a problem today for some reason the lower ball joints i ordered are bigger taper then the ones i took off. Any ideas what i did wrong? summit said they are for a 1970 datsun 510. Being you're 510 is a `70 it would be the 14mm tapers. Because the ball joint is to large and won't fit the knuckle it looks like someone replaced parts with early `69's or 68's but who would do that. Seems odd so with that I would ck to see if the tie rod ends fit the centerlink and the end of the turning knuckle. Quote Link to comment
jeph Posted December 19, 2014 Author Report Share Posted December 19, 2014 The parts i ordered are Mog-k9011 - ball joints Mog-es483r Mog-es486l Mog-es487l Mog-es489r - tie rods Quote Link to comment
thisismatt Posted December 19, 2014 Report Share Posted December 19, 2014 Get newer steering knuckles. Problem solved. Quote Link to comment
