What problems should I expect running 9-out-of-10 head bolts on an L20b?
Justin
Hey ya'll!
So, for those that don't know, I punched a hole in my L16 block and am (desperately) trying to slap together another L series to get it back on the road-
And, I keep running into problems-
I snapped a 1 of the 5 flywheel bolts on the L18... took it as "a sign" and moved onto the L20b-
Found out it's been bored .50 over (so it's pistons WON'T work in my other stock L20b block that has no pistons) and the 2nd from last rear head bolt hole has been stripped out. So that means if I run that L20b I'll be running 9 out of 10 bolts and JB Weld/gasket maker or some stupid nonsense in the 10th so I'm not overly-panicked about the thing all the time.
***Unless I remove the L18 pistons from the connecting rods and remove the L20b connecting rods from the over-bored pistons and slap said stock pistons onto correct-length connecting rods BUT I have no idea which side is the entry side and which side is the exit side (and, it says in the book pistons must be separated from connecting rods by using a press and not hammering, so that kinda stops me there too)
It's actually pretty funny because the L16's head was merely cracked before the head-swap;
And now that I've switched to an L20 I'll likely still be dealing with (the same)*similar issues.
I'm pretty sure the CORRECT way to fix this would be to take it to a machine shop and have them heli-coil up the hole and re-tap it, but none of my other vehicles run or are licensed right now so I don't see THAT happening (and price is a factor 'cause hey, it IS a Datsun)...
So yeah, any info on better solutions/options or any idea what kind of problems I'll be facing if I run the motor with only 9 of the 10 headbolts?
Or (**better option**) is it possible to separate pistons from connecting rods at home?
Thanks!
  • Replies 18
Get a $10 drill bit and do it yourself. Maybe it's in the heli-coil kit. Why pay $100 for a mechanic to do what you can do yourself? Get-r-done!
I broke all the flywheel bolts off once. Black and Decker hand drill, (borrowed) drill bit, tap and 6 new grade10 bolts came to $30 back in the mid 80s. Couldn't save the bolts, or get them out so I drilled to an over size. The holes weren't very straight but it worked and I was on the road in a weekend.
Installing Heli-coils is pretty straight forward ,,,, you can do it.   Just take your time and read up on a few the internet articles on the subject ,, maybe watch a You tube video on it... take your time,, you can do this.
Hahahaha, okay, okay! Never messed with heli-coils before, don't know!
No 280zx oil cooler laotsu (but there's one on ebay now for $75 shipped, FYI), and I DO have an extra L20b block, just only one set of connecting rods on the over-size pistons.
I guess maybe I should be wondering how to separate the pistons from the connecting rods/how to tell which end is the small end?
Or where to buy heli-coil and what type to get?
Thanks guys.
Head bolts have very healthy torque requirements. I think I would use a "Threadsert" insert [check the name, that's how I remember it, doesn't mean it's correct]. You drill and tap like a helicoil, but the insert has two vertical slots and hardened steel rectangular drive pins. You thread it into the block and give the steel pins a good smack with a small sledge, driving the 2 steel pins into the head and pop off the "bridge" connecting the pins. An anti-retation device.
That one on E-bay has only half the lines and no adapter, but thanks for looking out.
FYI a "short-block" is: the block, crank, con-rods, wrist pins, pistons and the various bearings, bolts, and seals that hold it all together. I'm not pushing it on you, just passing on info that I have picked up.
For head bolts I would go with a thread insert before a helicoil but that's just the machinist in me....
...a helicoil would work for you situation but its just a good band aid not a permanent fix.
You could also just go up to the next size thread on the bolt,(stongest optoin and what i would do) don't know if there is clearance in the hole in the head though.
As for finding out which end of the wrist pin is the small end go to harbor freight and get you a set of $10 digital calipers, they are good enough for garage use.
Good luck!!!
Just put a heilcoil in it, and use an ARP stud kit, no issues since. :)
ARP 202-4201
what wayno said
If you leave it out you will be doing the same job again sooner then later
if you arp stud it that bolt will never have to be removed
do it right or do it twice   your choice
