KiloTango1200 Posted July 21, 2015 Author Report Share Posted July 21, 2015 The difference between the Coupe and Sedan differential mounts. Coupe upper, Sedan lower. Quote Link to comment
KiloTango1200 Posted July 22, 2015 Author Report Share Posted July 22, 2015 The traction bar mount on the Coupe SCCA Racing suspension. The Coupe and Sedan Race rear springs are identical. 2 leafs separated by a layer of insulating material of unknown origin. Coupe left, Sedan right. Quote Link to comment
Duncan Posted July 22, 2015 Report Share Posted July 22, 2015 I spent quite a while trying to get both of these out of my wagon. I drilled straight through the center of the broken bolts, then threaded them with a M6 tap. I don't anticipate them ever coming loose.. The rear lower bolt holding the bottom of the front fender to the rocker panel broke off. This one will take some work. 1 Quote Link to comment
KiloTango1200 Posted July 23, 2015 Author Report Share Posted July 23, 2015 Top to bottom. Rear sway bar, adjustable rear spring shackles, front spring mounts and traction bars. Springs to the left. 1 Quote Link to comment
KiloTango1200 Posted July 23, 2015 Author Report Share Posted July 23, 2015 Adjustable rear shackles attached to the springs. 1 Quote Link to comment
KiloTango1200 Posted July 23, 2015 Author Report Share Posted July 23, 2015 Decided I wanted to see what the traction bar looks like hooked up to the rear suspension. The look from vertical. Traction Bar view from the side. 6 Quote Link to comment
KiloTango1200 Posted July 25, 2015 Author Report Share Posted July 25, 2015 Rust found and removed at the left inner fender to firewall connection. Removed and cleaned the left tension rod. 1 Quote Link to comment
datsunfreak Posted July 25, 2015 Report Share Posted July 25, 2015 That T/C rod seems a little bent? Or is that the camera? Quote Link to comment
KiloTango1200 Posted July 25, 2015 Author Report Share Posted July 25, 2015 That T/C rod seems a little bent? Or is that the camera? Good eye. I didn't notice till your post. That was the side that was hit. I'll put a straight edge to it tomorrow. It had 3 shims on it. The hardware that came off the left tension rod. Quote Link to comment
datsunfreak Posted July 25, 2015 Report Share Posted July 25, 2015 Are you putting 210 stuff in that car? If so, you can just use 210 T/C rods. Quote Link to comment
KiloTango1200 Posted July 25, 2015 Author Report Share Posted July 25, 2015 Are you putting 210 stuff in that car? If so, you can just use 210 T/C rods. Right now I am ripping the front end apart to find any rust or shoddy damage repair. So far, so good, only minor stuff. I am going to see if the 1200 struts that I got 10 years ago can be repaired. Hopefully I will find out this weekend. Quote Link to comment
KiloTango1200 Posted July 26, 2015 Author Report Share Posted July 26, 2015 Got the sway bar off. Need to clean it up. FINALLY! Something is going back together. The new LCA bushing is pressed in after the control arm was cleaned and painted. Bushing installed. Quote Link to comment
KiloTango1200 Posted July 27, 2015 Author Report Share Posted July 27, 2015 New bushing top, old bushing bottom. The new bushing is 0.007 inches longer than the old bushing. A preliminary fitting caused some trouble. You wouldn't think that small an difference would be a problem, but it will have to be forced in. The bushing needs to be pressed into the LCA another 0.003 inches to be exactly centered. Will try that sometime this week. Quote Link to comment
njoz1200ute Posted July 28, 2015 Report Share Posted July 28, 2015 Love this thread. I am about half way through. Great backstory to the car. Keep up the good work Welcome to the party! Datsunfreak and Dimlight65 also have 1200s in the metroplex. There is also a 1200 UTE with a SR20DET that puts out 400+ HP here. Do you have any photos of this Ute? Out of the 2 I brought to the USA, one is mine and the other was going to be rebuilt by someone in Texas. Could be the same ute? But may not. Just wondering what ever happened to the General. 1 Quote Link to comment
KiloTango1200 Posted July 28, 2015 Author Report Share Posted July 28, 2015 Love this thread. I am about half way through. Great backstory to the car. Keep up the good work Do you have any photos of this Ute? Out of the 2 I brought to the USA, one is mine and the other was going to be rebuilt by someone in Texas. Could be the same ute? But may not. Just wondering what ever happened to the General. Its a South African Datsun Bakkie that the owner brought over from home. He also has a really nice Silvia that also puts out a ridiculous amount of power. He describes the Silvia as really fast and the Bakkie as scary and brutal. 1 Quote Link to comment
datsunfreak Posted July 28, 2015 Report Share Posted July 28, 2015 Do you have any photos of this Ute? Out of the 2 I brought to the USA, one is mine and the other was going to be rebuilt by someone in Texas. Could be the same ute? But may not. Just wondering what ever happened to the General. Yours is in North Dallas. He's put it on craigslist a few times, but no one has bought it yet. I don't think he actually wants to fix it. Steve has owned his since around 2005. Lots of build pics here: http://www.510garage.com/photos/thumbnails.php?album=223 1 Quote Link to comment
KiloTango1200 Posted July 28, 2015 Author Report Share Posted July 28, 2015 Yours is in North Dallas. He's put it on craigslist a few times, but no one has bought it yet. I don't think he actually wants to fix it. Dammit, You had to go there. I have needed a truck for the past 7 years. It just needs to haul parts and launch a John Boat at Lake Ray Roberts Quote Link to comment
njoz1200ute Posted July 28, 2015 Report Share Posted July 28, 2015 Yours is in North Dallas. He's put it on craigslist a few times, but no one has bought it yet. I don't think he actually wants to fix it. Steve has owned his since around 2005. Lots of build pics here: http://www.510garage.com/photos/thumbnails.php?album=223 There was a small dent in the driver's (right side) door and a rusted section at the bottom of the same door that needs addressing. Besides a few small holes in the floor pans it really wasn't in all that bad of shape compared to most Datsun 1200s. It does need new steering components like tie rods, ball joints, etc... and bushings. Mechanically the A12 ran awesome. I also put headers on it and the tune out of the exhaust was perfect. Besides all the other list of huge modifications I made when I owned it in Australia for 4 years including a full respray, I think the guy got a great deal. It's a shame he is just trying to flip it. Hopefully one if you guys down there in TX can own it again and give it the love that I gave it. And if so, I want to see you guys weld the doors shut and climb in through the windows. I attempted to do it once and bruised the shit out of my knee. (thats not how the dent got there) Dammit, You had to go there. I have needed a truck for the past 7 years. It just needs to haul parts and launch a John Boat at Lake Ray Roberts Heck you could even jump the damn lake too.....yeehaw. [musical air horn sounds] :w00t: 1 Quote Link to comment
datsunfreak Posted July 28, 2015 Report Share Posted July 28, 2015 There was a small dent in the driver's (right side) door and a rusted section at the bottom of the same door that needs addressing. Besides a few small holes in the floor pans it really wasn't in all that bad of shape compared to most Datsun 1200s. I can't speak to condition as I never saw it myself, but the aforementioned Steve said he thought it was really rusty. But I know one man's "super rusty" is another man's "Eh, it's not that bad". ^_^ He did say however that most of the rust was very well hidden. Some in the A-pillars between the door and fender, etc. Quote Link to comment
njoz1200ute Posted July 28, 2015 Report Share Posted July 28, 2015 I can't speak to condition as I never saw it myself, but the aforementioned Steve said he thought it was really rusty. But I know one man's "super rusty" is another man's "Eh, it's not that bad". ^_^ He did say however that most of the rust was very well hidden. Some in the A-pillars between the door and fender, etc. Really rusty is this: The General Ree looked like this: Like I said, for the amount of money the ute sold for (basically even with the cost of shipping) the guy got a bargain. Especially compared to the prices of other 1200 imports lately. But I don't want to jack up this thread. Enough talk about my previous 1200. I was just curious where it was. Hell, I might even try and buy it back one day. Lets get back to talking about KT's awesome Sedan. 2 Quote Link to comment
KiloTango1200 Posted July 31, 2015 Author Report Share Posted July 31, 2015 I got the left inner fender clean and ready for a coating of POR 15. I have never used this product, so I got a starter kit to see how it works. 2 Quote Link to comment
datsunfreak Posted July 31, 2015 Report Share Posted July 31, 2015 I got the left inner fender clean and ready for a coating of POR 15. I have never used this product, so I got a starter kit to see how it works. Curious to see myself. Had a friend do the bottom of his 510 with a similar product called Zero Rust with good results. 1 Quote Link to comment
hobospyder Posted July 31, 2015 Report Share Posted July 31, 2015 i have a buddy who coated the frame for a project of his in por 15 like 10 years ago. he swears by the stuff for rust prevention. says he can wipe the dust off his frame and it looks just as shiny as the day after he applied it 1 Quote Link to comment
Morrisun Posted July 31, 2015 Report Share Posted July 31, 2015 That is a butt ton of hard work to get 40+ years of "stuff" off your car. Looking great. POR-15, watch the warnings on temperatures, and avoid sweating in/or on to the POR-15, which is one of the reasons for pouring it in to another container and only using small amount at a time until you figure out how much you can do before it starts to set-up. Wear gloves, wear gloves, dish washing gloves would be good for you! And it something to take your time doing. 2 Quote Link to comment
king bee66 Posted July 31, 2015 Report Share Posted July 31, 2015 that bare metal sure looks pretty 1 Quote Link to comment
