TENDRIL Posted February 25, 2014 Report Share Posted February 25, 2014 its the am...... 2 Quote Link to comment
boonedock saints Posted February 25, 2014 Report Share Posted February 25, 2014 Has that black accent always been there? if you plan on keeping it I think it'd look bomb going all the way down the side of the bed under the hooks. I agree, and...Id even entertain trying to duplicate that body line down the bed, with some fabbed metal work all the way down...lots of work of course...and it may take away from true Datsunisk look...but I think it would be different and bad ass/subtle... Quote Link to comment
red76datsun Posted February 25, 2014 Report Share Posted February 25, 2014 its now the PM..... pics!!! :thumbup: Quote Link to comment
metalmonkey47 Posted February 26, 2014 Author Report Share Posted February 26, 2014 I'm at work guys, I'll be back later! Put the new bezel in last night and its sick! Also gonna be starting bodywork soon and doing paint in a short bit Quote Link to comment
datzenmike Posted February 26, 2014 Report Share Posted February 26, 2014 Fawk. Snowed for three days here from Saturday. Not heave but steady, about a foot. Didn't bother going to work till today. hey I see Adam and Jess got a wide band and dial gauge. Quote Link to comment
'70dime Posted February 26, 2014 Report Share Posted February 26, 2014 what about that parts haul? whachu get home boy? Quote Link to comment
metalmonkey47 Posted March 5, 2014 Author Report Share Posted March 5, 2014 Sorry guys, so I'm back! I ended up picking up a whole dashboard out of a '79 620, complete with factory flashers, headlight switch, wiper switch, etc, crack free bezel, new dash carpet, etc. I also got new hood bumpers, king cab window seals, front valence lights NEW, new re-pro headlight housings and retainer rings, sweet door mirrors, and a few other small things. Stopped by Summit Racing on the way home and picked up the in house brand wideband kit, which happens to use the Innovate LC-1 controller. Worth it for sure! I'll post on that more later though... Pics of busy work... This guy shipped from Cyprus, and took about 2 months to get. Worth it! I really like it... Quote Link to comment
metalmonkey47 Posted March 5, 2014 Author Report Share Posted March 5, 2014 I'll be starting bodywork again soon, but this time with an end goal! I'm gonna get the body well sealed for some temporary color, aka plastidip. At least until I get another DD and can gut the body of the truck. It's got some holes to be filled. They have some pearl and other add-ins that would look pretty cool. https://www.dipyourcar.com/ Quote Link to comment
Hooligan Posted March 5, 2014 Report Share Posted March 5, 2014 I love this damn truck... everytime I see this damn thing I wanna wrench on mine Quote Link to comment
metalmonkey47 Posted March 5, 2014 Author Report Share Posted March 5, 2014 That's awesome, thanks man. Your truck makes me want titan rims and bags haha. It's such a good look, my truck just wouldn't go for it 1 Quote Link to comment
metalmonkey47 Posted March 5, 2014 Author Report Share Posted March 5, 2014 Alright, so i'm gonna start learning how to log AFR's on my LC-1 soon, but it's kind of confusing. I don't know how the LC-1 is supposed to log properly without a tach reference. It logs AFR's fine I'd assume, but it's gotta be hard to read the logs without throttle position or tach reference. Using the wideband I've learned quite a bit, but my ignorance to jetting is still leaving a little hole. -Cruising my afr's are about 13-14 ish. Sometimes fluctuating a hair over 14. Seems pretty accurate. -Under acceleration I dip WAY down into the 10-12 range (even under normal low load acceleration), which to me seems like it's going to be quite a bit rich, and explains why even as a conservative driver I average about 15-17mpg. Not sure how I could correct this, or even how far from normal that would be. Air jets? Emulsion tubes? -Idle is about 12.8-13.3 and seems to be pretty consistent there. I do notice after idling a short time at lights it seems like it wants to flood, as my AFR's drop down to low 12's as my revs drop. A little rev, and it sorts out fine for a short bit. - I have a bit of an idle issue, that until now I had no idea the cause of. After spirited or even slightly harder then normal driving, I'd find that idle was impossible. Before I didn't know why, but now with the wideband I see it's leaning WAY the fuck out. As the idle drops I see AFR's up to 20+. Just to give you an idea, the O2 reads 21.2 +-.1 to be ambient air in the exhaust pipe. it's leaning WAY the fuck out. - I need to step up the accelerator pump nozzle 1 size. When transitioning from cruising to heavier throttle I see AFR's jump to 16-17 for no more then a split second before steadying out. Obviously not enough fuel through the accel pump. Everyone needs to invest in a wide band. I learn SO much! Quote Link to comment
ggzilla Posted March 5, 2014 Report Share Posted March 5, 2014 You are losing power at 10:1 in addition to wasting fuel. Maximum power is at 12:1. Cruising should be leaner then 14:1 for maximum economy. Idle should be 14:1 for smoothness or 14.7:1 for emissions. Set the idle mixture screw to Lean Best Idle. 1 Quote Link to comment
datzenmike Posted March 5, 2014 Report Share Posted March 5, 2014 Agreed the idle mixture IS adjustable. I can see the 21 on decelleration but that shouldn't affect idle when it gets there. Quote Link to comment
bananahamuck Posted March 5, 2014 Report Share Posted March 5, 2014 Any talk of changing to Titans makes me sad. Quote Link to comment
Hooligan Posted March 6, 2014 Report Share Posted March 6, 2014 I'm in the wideband boat myself. I am running the AEM Uego, O2 is stabbed in right after the down pipe curves under the truck. At an idle... I am running approx 12.3. Under normal driving conditions I can see anywhere between 12.0 - 13.8. Under hard acceleration (on the floor) the lowest I have seen it dip is mid 11's. I haven't done much more tuning as to I am getting ready to swap to a Weber 45 DCOE. I will spend the tune time when that carb is on. One thing I have noticed is the difference watching the Wideband with the headlight tunnel. With all of the rain right now I keep the tunnel blocked off so it isn't shooting water all over the engine bay. Now with the tunnel open, my hard acceleration will drop into high 10's and into low 11's. I love the use of a wideband myself Quote Link to comment
willz Posted March 6, 2014 Report Share Posted March 6, 2014 Any suggestions on a wideband? Ive been looking, but I honestly havent been super crazy about spending $300+ on a gauge "/ Quote Link to comment
ggzilla Posted March 6, 2014 Report Share Posted March 6, 2014 Get a bosch wideband O2 sensor for $70. You can use a high impedance voltmeter or build a $15 led gauge. 'Course u don't need one to tell if its running a power-robbing 11:1 - just look for the smoke in the rear view mirror. 1 Quote Link to comment
heretic Posted March 6, 2014 Report Share Posted March 6, 2014 ggzilla you should do a write up on this :) I for one would be WAY interested, just say'n :) Get a bosch wideband O2 sensor for $70. You can use a high impedance voltmeter or build a $15 led gauge. Quote Link to comment
MantisX620 Posted March 6, 2014 Report Share Posted March 6, 2014 Any suggestions on a wideband? Ive been looking, but I honestly havent been super crazy about spending $300+ on a gauge "/ Innovate makes a decent one. Comes with controller and o2 sensor. Can be had all day on ebay for 150 new. 2 Quote Link to comment
Hooligan Posted March 6, 2014 Report Share Posted March 6, 2014 Innovative and AEM are both good widebands and both can be had for $150 - $160 all day long Quote Link to comment
metalmonkey47 Posted March 13, 2014 Author Report Share Posted March 13, 2014 Also interested in the write up GGzilla! Any suggestions on a wideband? Ive been looking, but I honestly havent been super crazy about spending $300+ on a gauge "/ I'm using the Summit Racing brand for $175. It using the Innovate LC1 controller, with a serial out for data logging. If you could get a tach reference for the data logging software you could log AFR's and RPM's for a fairly accurate log. I can gun mine at 2000RPM and see it drop into 9's without any smoke LOL. Cruising for some reason after leaning out the idle circuits is about 13.8-14.6. Under acceleration is about 11.5-13 and it feels GOOD! One thing I can't figure out for the life of me is why it's running so fucking rich at idle. Even after spinning out the screws nearly all the way it's still high 11's - low 12's. It idles rough around 14:1 and still smells rich as hell. Idle quality SUCKS with this huge cam. I'm about to pull out my Z car SU's and finish building the linkages. I'm just gonna go ahead and run them, and dump the Mikuni money into brakes and coilovers. And a door hinge. Quote Link to comment
datzenmike Posted March 13, 2014 Report Share Posted March 13, 2014 Hitachi turns in to lean the idle mixture. (I can't remember what carb you have) A big cam will disrupt good manifoldd vacuum and ruin idle mixtrues. Try running 900 or 1,000 idle speeds. Quote Link to comment
Farmer Joe Posted March 13, 2014 Report Share Posted March 13, 2014 matt, turning the idle mixture screws out make its more rich on the 38. try this with the idle screws. turn them all the way in (softly, just till you feel its bottomed out) and then bring it out 1.5 turns on each one. Simple Rules for low speed calibration If the mixture screw is more than 11/2 turns out turns then the Idle jet is too lean (too small). When the mixture screw is ½ turn or less, then the Idle jet is too rich (too large). These assumptions are based on the fact that the speed screw setting is not opened more than 1/2 turn in. If the speed screw has to be opened1/2 or more turns then this is also an indication of a lean condition usually requiring greater change. At times it may appear to be showing signs of richness or flooding it is really a lean condition. Please understand the need to keep throttle plate as near to closed as possible so as not to prematurely expose the transition holes. This is what causes the visible rich condition, and confirms the need to increase the jet size. JET KITS are available if needed. EXAMPLE With the idle speed screw set at no more than 1/2 turn in after contact with the stop lever; and the best idle occurring with the idle mixture screw set at 1 1/2 turns from lightly seating, indicates the need for a larger Idle jet. Achieving the best idle at less than 1/2 turn indicates the need for a smaller idle jet. see what you have for idle the, and do like mike said. put the idle where its the smoothest, but still low so its not just free revving all the time. Quote Link to comment
Stupid_fast Posted March 21, 2014 Report Share Posted March 21, 2014 Also interested in the write up GGzilla! I'm using the Summit Racing brand for $175. It using the Innovate LC1 controller, with a serial out for data logging. If you could get a tach reference for the data logging software you could log AFR's and RPM's for a fairly accurate log. I can gun mine at 2000RPM and see it drop into 9's without any smoke LOL. Cruising for some reason after leaning out the idle circuits is about 13.8-14.6. Under acceleration is about 11.5-13 and it feels GOOD! One thing I can't figure out for the life of me is why it's running so fucking rich at idle. Even after spinning out the screws nearly all the way it's still high 11's - low 12's. It idles rough around 14:1 and still smells rich as hell. Idle quality SUCKS with this huge cam. I'm about to pull out my Z car SU's and finish building the linkages. I'm just gonna go ahead and run them, and dump the Mikuni money into brakes and coilovers. And a door hinge. Had an old school (DATSUN) tuner set my idle. He sat there for a minute with a screwdriver with his ear up to the carbs. 11.5:1. Idle around ~850-1000rpm depending on the carb. On my 32/36 I let it idle at 1100 with 490 lift. I usually set mine around 12:1-13:1. Big cam has low vacuum at idle, he said leave it rich to prevent pinging. Mine doesn't matter cause stock compression and 91 california mix. Quote Link to comment
metalmonkey47 Posted March 26, 2014 Author Report Share Posted March 26, 2014 Suddenly.... A wild Datsun appears! 4 Quote Link to comment
