datsunfreak Posted February 15, 2014 Author Report Share Posted February 15, 2014 Muffler test fit... This is the exact exit location I wanted, and it looks like it will work very well here. :thumbup: So, as it turns out, I can't find my keys for this car ANYWHERE... :sleep: So I ordered up some Solex locks for it. B) Stock lock hole... Needs one side widened for the Solex lock cylinder... Locks in! The one for the trunk worked a treat as well, just had to tweak the arm to line up with the stock actuator... ^_^ Whipped up a trans crossmember and Tim kindly welded it together for me... :thumbup: Didn't get any photos of the finished product, but I will next time. :thumbup: Installed the extra wide B210 radiator and some new hoses... The previous owner cut some of the core support away on the right side for an oil cooler. I'll have to make a panel to cover that so all the air actually goes through the radiator like it should... :thumbup: If you look closely, you can see I had to make a bracket to go across the gap so the radiator was firmly mounted on all four corners. Now it's in there and it's very secure. :thumbup: I like the look of the stock heater box, but since I had no plans to run a heater... :rofl: I took the heater box apart and completely gutted it. Went from 12 pounds down to about 2 pounds. B) Gonna keep all the flapper doors in it so I can still use it as a fresh air device on warmer days. :thumbup: 1 Link to comment
datsunfreak Posted February 24, 2014 Author Report Share Posted February 24, 2014 Had a few minutes this morning so I bolted on the header and carbs for what I hope is the last time. :thumbup: I had been waiting on these to show up, and since they did on Friday, I went ahead and bolted it all up... 1 Link to comment
datsunfreak Posted March 1, 2014 Author Report Share Posted March 1, 2014 Took the trans crossmember off and modified it slightly for better exhaust clearance. Pipe tucks up a lot closer now... Finally got my column seal/surround installed. That was an asswhip... Cut the carpet to fit around the column... Got the brake master installed, new hard lines from the master to the distribution block, vacuum advance hose fitted, little cone filter fitted to the valve cover, and a few other things I'm probably forgetting... ^_^ 1 Link to comment
Kirden Posted March 1, 2014 Report Share Posted March 1, 2014 Looking sweet man. I just noticed your hard lines though. Are they wrapped? Link to comment
datsunfreak Posted March 1, 2014 Author Report Share Posted March 1, 2014 Previous owner painted the hard lines while painting the engine bay. Then he decided they looked goody in white (duh) so he wrapped them in hard plastic wrap normally used for wrapping a wiring harness. It's taking all my self control not to take them out and make new ones... :rofl: The new hard lines I installed on the master came black coated already. :thumbup: Link to comment
Kirden Posted March 1, 2014 Report Share Posted March 1, 2014 The black looks good from the pics. I couldn't do the plastic covered lines though. With a bay that clean, it'd have to be redone :P Link to comment
datsunfreak Posted March 1, 2014 Author Report Share Posted March 1, 2014 Well, we'll just wait and see if they last or not... :rofl: Link to comment
datsunfreak Posted March 1, 2014 Author Report Share Posted March 1, 2014 Decided to finally finish my stacks too. Almost done... Decided to stick with the brushed look for now. May polish them later... 2 Link to comment
dimlight65 Posted March 6, 2014 Report Share Posted March 6, 2014 I've just about got the wiring diagram done so I should be able to finish his harness this weekend... dang, I just jinxed it, didn't I? Link to comment
datsunfreak Posted March 7, 2014 Author Report Share Posted March 7, 2014 I've just about got the wiring diagram done so I should be able to finish his harness this weekend... dang, I just jinxed it, didn't I? You won't finish it. Double jinx. Counteracts your jinx. :rofl: Link to comment
Duncan Posted March 7, 2014 Report Share Posted March 7, 2014 Tim kindly welded it together for me... :thumbup: Your friend Tim needs to wear some gloves. I've learned and re-learned that the hard way a few times... The 1200 is looking badass, though :thumbup: Link to comment
datsunfreak Posted March 7, 2014 Author Report Share Posted March 7, 2014 Your friend Tim needs to wear some gloves. I've learned and re-learned that the hard way a few times... So has he. :rofl: 1 Link to comment
dimlight65 Posted March 8, 2014 Report Share Posted March 8, 2014 Your friend Tim needs to wear some gloves. I've learned and re-learned that the hard way a few times... If it is the "burning yourself with the part" issue... meh, fingerprints are overrated. If it is the "you're going to get skin cancer from the ultraviolet light" issue... feh, something's going to kill me someday. 2 Link to comment
datsunfreak Posted March 8, 2014 Author Report Share Posted March 8, 2014 My smoked E-codes came in today... B) 2 Link to comment
goes2fast Posted March 8, 2014 Report Share Posted March 8, 2014 My smoked E-codes came in today... B) Where did you get these? Link to comment
datsunfreak Posted March 8, 2014 Author Report Share Posted March 8, 2014 Where did you get these? Ebay. Got them installed today. Took may more work than I wanted it to... :rofl: Tried a few different grill options. None really jumped out at me. We shall see... Put the stacks on too. Turns out they actually do touch each other... :rofl: :rofl: :rofl: Spent most of the time working on the wiring some more. Hope to have that done next week. :thumbup: 3 Link to comment
datsunfreak Posted March 9, 2014 Author Report Share Posted March 9, 2014 I kinda dig it too... B) Link to comment
ggzilla Posted March 9, 2014 Report Share Posted March 9, 2014 What about the coupe grille with the center surround painted silver? Coupe eyebrows are black, Truck eyebrows are silver. Link to comment
datsunfreak Posted March 9, 2014 Author Report Share Posted March 9, 2014 What about the coupe grille with the center surround painted silver? That's actually the next thing I'm going to try... :rofl: 1 Link to comment
KiloTango1200 Posted March 9, 2014 Report Share Posted March 9, 2014 damn that looks good The pictures don't do it justice. I saw it today in person and it looks Waaay better than the pictures show. Link to comment
datsunfreak Posted March 11, 2014 Author Report Share Posted March 11, 2014 New engine bay tag. Got a new one because mine was faded, and because this one says A15. B) Link to comment
datsunfreak Posted March 11, 2014 Author Report Share Posted March 11, 2014 1487 ... typo? No idea... Link to comment
ggzilla Posted March 11, 2014 Report Share Posted March 11, 2014 Factory Service manual says 1488 Link to comment
