'73 1200 Coupe Project, aka Timmy
Still wary of swapping the seats in the B210 cause of that stupid cat hump though...
Yeah, you're kind of screwed there.   :rofl:
My buddy Tim's B210 has the same problem. We've had hell trying to fit a seat in it at a usable height. Almost seems like race buckets are the only way. I'm half tempted to cut the floor out of an earlier car and weld it in. On a '74-75 B210 it's a LOT easier...   ^_^
The only thing I'm not a fan of is the seat belt guide at the top. Makes them look a little too modern imo.
Not too worry, those are going away if at all possible.
  • Replies 1.9k
Dug out my spare pair of lower side trims. One wad dented, but I was able to straighten it with a wood dowel, a hammer, and some patience...
1625692_10152110985212983_64167799874624
Straightened, polished, and installed. Don't know if I love it, but it's way better than staring at 5 holes in the body...    :rofl:
10157391_10152110985217983_9096877877617
Took the new rear side markers off and got rid of the residue left behind by the old lights, and the leftover double-sided tape from the badges that were on the quarters above the light...    :thumbup:
10155561_10152110985227983_3129559821891
What size Watanabes you running, I wish I could afford a set like those.If I only had your money.
BRIDE sells rails for the cat side. Then you can fit any seat to it.
I still have the 1200 seat rails with flat crossbars welded to them, so I can actually use those to fit any seat I want.  ;)
:fu:
Sorry, I thought we were talking about my car. Since this is a thread about my car. :rofl: :rofl: :rofl:
Sorry, I thought you were talking about Tim's B210.
No really though what size wheels are they and did you buy them used or ?
14x7 -9 Konig Rewinds with Watanabe caps, 15mm spacer on the front (still not flush enough), and a 25mm spacer on the rear (still not flush enough).
The "problem" with these flares is they need either reeeeally wide wheels or reeeeally deep offsets.  :rofl:
At some point I think I'm going to order some 14x8 Bassetts in -25 up front and -38 out back.
Still waffling on whether to use the 14x8s (big stretch), or the 14x7s (tiny stretch), which is basically the only reason I haven't ordered them yet...
Something along these lines...
  • Like 3
They are Konig Rewings with Wat caps on them... and I think they are 13x8s.
Shit, I wish they came in 13x8s... I'd rock the hell out of those...   :rofl:
And for reference, this is a 14x8 with a 165/55-14 (my current size)...
I could switch to a 185/55-14 for the 14x8, but then I'd basically be exactly where I am now stretch-wise and be 10mm taller, so...
Understood. You should seriously go post that info in his thread, though. He never reads mine...   :rofl:
Yes I do, I just don't post very often.
Looks like a rim looking for a place to get damaged! :rofl:
Can you find any wide low profile 14s? Because I can't.
And honestly, because I like the way it looks and drives.
Buy 15 inch wheels, like I did! Time to enter the modern word, maybe 16s or 17s.  :fu:
My tires are the same height as the original 12s, do your research!
That's not even what I said. I said too tall for a 1200. Not taller than stock.   :rofl:
I have no use for tires that are the same height as stock. Sorry, but it's not what I want for my car. If you like them, cool.
This topic is now closed to further replies.
