The Now-Named 620
Pumpkn210
After further inspection....
This truck was never finished!
The wheels dont fit right(spokes sitting on drums)
The brakes, clutch, and engine NEVER had fluid in them. And the rears are hooked up wrong(no bleeders)
The drums are stuck on(too much extra metal)
The interior of the cab and bed were never painted or finished(apparently)
Gettin the wheels to fit right-ish and workin on the brakes today, carb and fuel tomarro, and then to the fun finishing things!
Come on down and give a helping hand, or some parts! I gotta get it on the road by SUNDAY! ;)
isn't the frame all done up to
Like you wouldnt believe!!
  • Replies 147
first off, the tires are a bit on the large size...
I also say the underside has a little chrome and pin-striping.
Did I forget to mention the Wheels are Frakin Huge?
Motor has never ran!
I wonder if that intake and carb would work on my goon...
And more pin striping
I think Nuckin Futs would be a good name. what do the rest think?
Clutch Master from pip in and dont wanna bleed <_<
Brakes are still full of air and I think the drivers rear is leakin :angry:
Baught a STACK of spacers today and some washers for the whels :rolleyes:
Although... I did get the headlight assemblies and high beams in, need reg beam bulbs :unsure:
But altogether a productive half day, will check in with oics this evening!
Will try to start it up in the mornin! ;)
I had to clean out the clutch slave to get action, and it is now bleed and working! The fluid is comin out clean, but Im still a little worried about the brakes... Got the fuel lines hooked up and cleaned out, gonna try to start it in the mornin... Heres the oics of it in its current state...
Still Need:
Upper Rad Hose
Outter Headlights
Pass Turn Signal
And I will be at the show on sunday!
%85 sure...
