ka24de 210
80datson
OE 210 mudflaps FTW!!!... sorry that drop of white stuff must be from datzenmike fapfap'n :P
13s with disk hiding behind em. im amazed they cleard
seem to have a fluid leaking from the brake line. from the rubber part that screws on to the T-split. maby be the brass O ring? i probably messed it up when i installed it. have a spare to replace if its damaged.. also rear sway FTW!
  • Replies 309
what kind of 210 stuff do you have??
Sorry that I let you hanging, buy was watching the football game that day , Not much like the complete dash for the 79,intake manifold for webber A14, gas pump,set of 13"by 7 wheels, and some small poket stuff, need to clean my garage and also fund my project. I tryde to go back the next week to take more part off the 210 79 wagon at the junkyard., but it was gong. I saw that you needed some parts like the winsheld, I was thinking taking it off, but no luck.:(
  • 4 weeks later...
if u how much i'm on your nuts, and i can can't even give you a descent link the get yourself a strut bar. i bought my strut bar on ebay the brand name of the strut o bar is CUSCO. what rear end are you using "THE BIG h165" means nothing to me, because i'm a noob better question is what car did your rearend come off of. to repeat your 210 witha KA in it is sexy as shit.
Did the 200SX control arms/links line up okay with the 210 body mounts? How well did the spring mounts line up? Springs kinda look like they are "leaning" a little to the inside in that pic.
also last night i took out the small rear axle set up and installed a h165 with rear disk brakes/sway bar/ and i get atleast one inch and a quater on each side wider wheel base which is a plus.
Big bad h165. rear disc brakes and rear sway bar!!!!
small one out..
and the big h165 in. now there will be no restrictiions :D
