jesusno2 Posted November 2, 2013 Author Report Share Posted November 2, 2013 J rock wait till ya get solid heims under a 510 wagon going south talk bout loud! It sounds like the whole rear end is gonna fall out! Lol theirs no doubt that it will transfer road noise etc. But theirs always a trade off somewhere in a build. Im not a huge fan of urethane bushings either cause they creek and grown but they take slop outta a suspension right quick! Datsun trucks are tuna cans all the sound deadning material in the world wont even cure that. Quote Link to comment
jesusno2 Posted November 17, 2013 Author Report Share Posted November 17, 2013 Oh wow, you go guys. I honestly thought y'all were pros with that quality of work. Good luck with the project :) Yes, thank you. Anybody can do it just takes practice. Me and Boarlin have been building stupid stuff for a long time we still screw stuff up you shoulda seen the first welds we ever put down WOW! not good, we still go through our share of cut off wheels. 1 Quote Link to comment
jesusno2 Posted December 8, 2013 Author Report Share Posted December 8, 2013 OK, any body guys please chime in. At this point it would be very helpful, cause we are not paint and body guys, I understand some of the basic stuff but that's about it. Here is a pic of the driver side door. Skimmed the whole door and knocked it down with 36 grit. What's the next step? the bare spot are obviously high, so do ya pound those down or build the panel up some more? is sanded enough? 521 doors are so flexy the whole panel just bows and flexes around when your sanding on it, its retarded. http://img.photobucket.com/albums/v633/jesusno2/20131208_144343_zps2a2fd281.jpg Quote Link to comment
mklotz70 Posted December 9, 2013 Report Share Posted December 9, 2013 I'm not a body man either, but I would think that you'll need to grind the filler back off and shrink some of the high and low spots. It flops around because there's too much metal for the area it's trapped in. Hopefully, you'll get an answer from someone that actually knows :) Quote Link to comment
]2eDeYe Posted December 9, 2013 Report Share Posted December 9, 2013 You should pick the Keepers brain on this one. :) Quote Link to comment
Z chopper Posted December 9, 2013 Report Share Posted December 9, 2013 You should pick the Keepers brain on this one. :) I think I suggesteda while ago about sending it to Keeper and get him to do the work Quote Link to comment
jrock4224 Posted December 9, 2013 Report Share Posted December 9, 2013 glazing putty ...blocked with 60-80 grit........ then a high build primer then u will be blocking and sanding a re repriming till straight .. use some guide coat ..... I like to seal my fillers with epoxy before I go to a high build pimer....... it done right u will hate block sanding about half way through the project 1 Quote Link to comment
jesusno2 Posted December 9, 2013 Author Report Share Posted December 9, 2013 I think I suggesteda while ago about sending it to Keeper and get him to do the work That would be nice but who learns how to do something by paying someone else to do it LOL. Our time is basically free at this point. Have a hard enough time scraping up the cash just to buy supply's at this point anyways. James demands good money for his hard work which I'm sure is worth every damn penny, and I dont blame him. We both hate this kinda work mainly just due to lack of knowledge and drive to do this type of work Quote Link to comment
jesusno2 Posted December 9, 2013 Author Report Share Posted December 9, 2013 glazing putty ...blocked with 60-80 grit........ then a high build primer then u will be blocking and sanding a re repriming till straight .. use some guide coat ..... I like to seal my fillers with epoxy before I go to a high build pimer....... it done right u will hate block sanding about half way through the project I thought you laid down epoxy first to seal the bare metal? Quote Link to comment
jrock4224 Posted December 9, 2013 Report Share Posted December 9, 2013 why if your gonna do body work and sand most off (sanding epoxy sux too ... its like sanding a eraser) ...and im not a fan of putting filler over anything but bare metal .....i told all my customers that did use epoxy under filler if the epoxy delaminates whats that gonna do to your filler and 99% of all fillers are designed to be put over a metal substrate....so i just lock all my filler down with a good epoxy ..... stay catalyzed through out he project too ....most epoxys give u a week to re coat with out sanding and if not a red scotch bright is more then enough to get your high build primer to stick to it..... Quote Link to comment
jesusno2 Posted December 9, 2013 Author Report Share Posted December 9, 2013 Ok im on a learning curve this is the first rig ive ever really tried to do body work too. I havent had good luck in the past with any of it always looks like shit Quote Link to comment
jrock4224 Posted December 10, 2013 Report Share Posted December 10, 2013 just ask i can help u anyway possible.... Quote Link to comment
jesusno2 Posted December 10, 2013 Author Report Share Posted December 10, 2013 Ive just been watching video's and everyones layin down epoxy and then a high build primer and going on from their. i guess it depends on how good your body filler is in the first place lol Quote Link to comment
thisismatt Posted December 10, 2013 Report Share Posted December 10, 2013 Filler or epoxy first is huge internet debate #35083221. What about etch primer? Quote Link to comment
jrock4224 Posted December 10, 2013 Report Share Posted December 10, 2013 not a fan of anything acid based either ........ nothing likes to go over it......the internet is no place to debate lol Quote Link to comment
jesusno2 Posted December 10, 2013 Author Report Share Posted December 10, 2013 I think filler on bare prepped steel. But after that its gonna be about budget best bang for the buck. Primer is expensive and im sure we are gonna have to block this thing 1000 damn times 1 Quote Link to comment
Charlie69 Posted December 2, 2014 Report Share Posted December 2, 2014 Any updates Quote Link to comment
Laecaon Posted December 2, 2014 Report Share Posted December 2, 2014 Due to the politics of Ratsun, this thread will likely never be updated again. You have a better chance at finding it on FB. 1 Quote Link to comment
boarlin Posted December 5, 2014 Report Share Posted December 5, 2014 not really anything to update been working on other projects ,only thing that has happened is I recently stripped the cab down to metal 2 Quote Link to comment
jesusno2 Posted December 30, 2014 Author Report Share Posted December 30, 2014 I will be updating again soon for any of ya following it. got some plans in the works. 5 Quote Link to comment
Charlie69 Posted December 30, 2014 Report Share Posted December 30, 2014 Great news bring on the pictures! Quote Link to comment
Cpl620 Posted December 30, 2014 Report Share Posted December 30, 2014 o love the suspension work on this thing. so many awesome truck builds coming around... 1 Quote Link to comment
jesusno2 Posted December 30, 2014 Author Report Share Posted December 30, 2014 thank you 1 Quote Link to comment
konig209 Posted February 3, 2015 Report Share Posted February 3, 2015 Quick ? Will the stock ca turbo clear the steering comlumn? 1 Quote Link to comment
