skyblue
Valentine
4x4 ketchup mustard and extra cheese. 2 fries. Oh and nice truck.
Share this post
Link to post
I have bolted hijackers onto my 521 without any issues other than they rubbed on something(I don't recall now), they lasted for several years, after they rubbed thru I replaced them with some coil over shocks and I installed the overload air bags, when I had the hijackers I still had the stock bed floor.
Share this post
Link to post
Quit carrying heavy loads!  LOL
Share this post
Link to post
Lol.
I love that blue truck  esp the wheel set up,lowered
Thanks!
Share this post
Link to post
I love him he makes great drinks.
Share this post
Link to post
Does this truck have 4X4 leafs on it?
I went back a few pages, but the photos are gone so I gave up looking and decided to ask.
Share this post
Link to post
Yeah, but it's a truck!
my thoughts exactly. lol
It does. new shocks all around too.
Share this post
Link to post
So I went back a page and noticed something, you have the 2 piece drive shaft in it right now?
If you do look at the rubber piece that is bolted to the cross member at the carrier, if the rubber is deteriorating and the drive line can move to the side it could possibly start rubbing on the housing that holds the rubber piece in, that would make a metal to metal squeaking sound, and since the truck is lowered, the drive line itself might not know where it wants to be, it might not have squeaked at first till it settled into the position that caused it to squeak.
Also you might look at the drive line yoke going into the transmission, when lowered does the drive line compress all the way and force the front drive line piece/yoke farther into the transmission and maybe bottom it out, and the squeak was the yoke outside dust sheild either being forced to the side and rubbing the side of the tail shaft, or maybe the yoke is just being pushed to far into the transmission and the yoke inside is rubbing on the end of the tail shaft that holds the seal.
Share this post
Link to post
Then do not whine when you put heavy loads in a lowered truck!!!  LOL
What size blocks re in the back?
Do you have much suspension movement front and back before hitting stops.
Measure your rear bed hieghth empty and then load your bike and measure again.
Also wuth the bike loaded look under the truck at the drive line and the bump stops if you have any.
Measure the axlehousing to frame clearance loaded.
This is one of my favorite 521s so please do not "fuck it up"!!!  LOL
Share this post
Link to post
We can try to make them better though. It doesn't have to suck.
Share this post
Link to post
this post is for tanker.
did some wheel fitment with some titans i bought a few years ago. ran into issues. they don't clear the nubs on the hubs.
but got enough threads on the lugs to take pics. lol
hubs would need machining. rears would need grinding. not sure if i want to go to all that trouble. especially living in an apartment. on the fence.
  • Like 3
Share this post
Link to post
So if the wheel fits flush to the hub,then just get longer wheel stems. There cheap and doable. But titans are ugly in my opinion. Unless your Jrock. But its your truck and it will still look good, i just think there overdone.
Share this post
Link to post
they don't sit flush. that's the issue. I still think they're good looking wheels. If they cleared i would run them. but right now i don't think so.
Share this post
Link to post
You just need to open up the wheel bores. Can be done with a woodworking router and a rabbeting bit.
  • Like 3
Share this post
Link to post
What Matt said should work. Get tires mounted and make it work. The back will slide right on. And yes flush is key. And it will look good.
Share this post
Link to post
confirm on the router with rabbeting bit will work very well. They fit very well actually. If you want to run the Nissan centrecaps on the front, you may need to either run a small spacer or flatten the bearing caps a little
Share this post
Link to post
Think I might do this while I have my wheels off.
Share this post
Link to post
Those wheels are ugly anyway.
Share this post
Link to post
Hmmmm. Who do I know with a router?
Share this post
Link to post
seen this method done .....sketchy as fuck !!!!!  just take the hubs and a wheel and machine the hub
Share this post
Link to post
post a vid if u do ... home depot rents one
Share this post
Link to post
Not too bad, just make sure you do it with a 1/2" shank, not a 1/4".  I mill aluminum & brass fairly often with a router for stuff at work...
Share this post
Link to post
Not sure if i want to go to all that trouble. Stay tuned...
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
