Valentine
skyblue
  • Replies 1.6k
So of course you fix something and something else breaks or starts to break.
Engine haas developed a high pitched weezing sound. I think its coming from the distributor. Busta advised me that it's probably a bearing in the dizzy. Has anyone replaced distributor bearings before? and where do i get bearings for a matchbox dizzy? The easier option is just slap some pertronix on a spare dizzy from busta's stash.
If it's a belt, you can run the engine and spray a little water on the belt to see if it's the noise. If it's a belt, the water will silence it instantly. This will save you the trouble of going through the unbolting trouble. Quick and easy like. Bearing should be easy to replace as well, if that's what it is? Had a similar noise but found it to be my cam chain guide and you know how that turned out! Hopefully it's just a loose belt.
update
installed the pinion angle shims. went with 2 degrees.
driver's side.
A8483192-16D8-46BD-913D-88A4DEFF686C_zps
passneger side.
F6508832-78A9-4DBB-BA9D-252AACEA8A99_zps
5C130519-B605-4D7F-A2C0-23CD78ED4177_zps
Also I finally installed the front eye leaf spring bushings.
9BE052F4-C667-41EB-B001-A6C8CD1923CE_zps
2279C64D-E867-4E39-9A5F-0BF5AA1CC505_zps
Used these. they fit great on the 720 4x4 leafs.
1DACC865-B72F-4A65-B14A-4F93D17A17B9_zps
These are what where on the 4x4 leafs when i got them. the hole diameter was bigger than stock 521 so they where in there kinda loose. I believe they are for a 620 cause that's what the leafs where on before i bought them from eagleadam.
2DCE9E85-7FAE-41AC-8913-53A285537D71_zps
I also raised the front a 1/2 inch to even it out and more clearance.
0D18E036-12E8-4FE3-9D55-E3EF2916E9EB_zps
Drove her home and she's definitely smoother on the freeway.
She's almost ready for Canby! just gotta deal with the dizzy noise, replace the brake master cylinder and adjust the valves one more time.
sunlight shot for motivation
1606A67D-024B-43C9-8738-279FD34FC35C_zps
51,638 mi
  • Like 3
the 620 guys claim 1.75" but i have also heard 1.5".
I crunched some numbers and my truck measured 27.5" from ground to fender well opening in the rear. after 3" blocks that put it at 24.5".  after 4x4 leafs it now sits at 23" even.
so in my case the 4x4's lowered it 1.5"
Edited by skyblue
Around one and a half inches.
But that depends on what spring you are replacing.
Thank you and thats good to know.
  • 4 weeks later...
ok so I got a Wilwood 1inch brake MC because the master i got with the Canby truck brakes started leaking. I got a chance to swap it out at bustanut's shop. Started last night and should have taken a few hours. But, this is a Datsun and if something can go wrong it will. Turns out the threads on the inlet are standard. And the lines I got with canby truck are metric. yay. so i had to leave the truck at the shop overnight.
old and new
A604FB3F-CE3C-4DD6-9784-B4AD613E04F5_zps
where i left off
BA860341-E5AB-4CBB-8955-138BA73D8993_zps
kalani stopped by
5821F95C-2208-430F-B632-ADD054EBB917_zps
Thought i could get some adapters, but parts store didn't have any so i bought new lines. Bending them took longer than expected but got them done. so now my lines all match and MC doesn't leak! canby here we come!
9E85EA6A-99F2-439D-90A9-15D16FF29287_zps
And finally installed the Wilwood prop valve I got from hobo last canby. lol
85B03A1A-AE4A-4E9E-BB1B-293AAB6664A6_zps
B7682300-472F-4A7F-937F-464E5B4916CA_zps
A few small things left like cleaning and maybe do valves again hot.
51,686 mi.
  • Like 6
Looks good vegan. Now scrub that engine bay. Plenty of shine I see cumming out under that hood.
Thanks. But, let's get one thing straight, just cause I eat vegan burgers doesn't make me vegan.  :ninja:
and yea, i know it needs a good cleaning. I was waiting for you to say something.
Wait.....Engine shinny......Brake master shinny......Where's the rest of the shine?? Looks sweet though. Glad to see you're back on the road again!!
don't forget the shiny new carb. lol
