datzenmike Posted May 3, 2011 Report Share Posted May 3, 2011 Pull the oil filter and check the contents. The bearing will shed fine flakes of material if going. If so you may be able to save it by dropping the pan are replacing the rod bearings now! If you keep going it will fuck the crank if not done already. If it's early, it can be saved for a gasket and some $50 rod bearings. If you have to run it, swap the oil for some 50 weight thick shit. Quote Link to comment
Guest 510kamikazifreak Posted May 3, 2011 Report Share Posted May 3, 2011 Worth a try. Check the alternator mount bolts to see if its them :unsure: Quote Link to comment
skunk Posted May 3, 2011 Author Report Share Posted May 3, 2011 Worth a try. Check the alternator mount bolts to see if its them :unsure: yeah i started checking for lose stuff first thing. yeah i knew it was missing one of them, but turns out its missing two of the three. put new bolts in, but there is still noise coming out of the engine itself. Quote Link to comment
Guest 510kamikazifreak Posted May 3, 2011 Report Share Posted May 3, 2011 yeah i started checking for lose stuff first thing. yeah i knew it was missing one of them, but turns out its missing two of the three. put new bolts in, but there is still noise coming out of the engine itself. :( That sucks. Very few L motors drop a bottom end Quote Link to comment
skunk Posted May 3, 2011 Author Report Share Posted May 3, 2011 Going to pull some shit apart tomorrow, see if i can pin point whats going on so i can start making a plan to get it fixed in the next 39 days.......... Quote Link to comment
Guest 510kamikazifreak Posted May 3, 2011 Report Share Posted May 3, 2011 For sure. Did you try a stethiscope (or a long screw driver) to listen to where the death knock is coming from? Quote Link to comment
datzenmike Posted May 3, 2011 Report Share Posted May 3, 2011 Forgot it was a car with a big ass X member. I still have 620 blindness. Rather than lift the motor out could you not support it on a hoist and disconnect the sway bar, tension rods and steering cross bar and simply lower the cross member with the LCAs attached? to access the pan? Quote Link to comment
skunk Posted May 3, 2011 Author Report Share Posted May 3, 2011 yes, Ed did yesterday. said it sounded like the top end. Took a look at the top and and all seems fine, going to check again tomorrow. maybe check the valve lash Quote Link to comment
Guest 510kamikazifreak Posted May 3, 2011 Report Share Posted May 3, 2011 yes, Ed did yesterday. said it sounded like the top end. Took a look at the top and and all seems fine, going to check again tomorrow. maybe check the valve lash Might be a loose valve seat :unsure: Have had that happen once before Quote Link to comment
skunk Posted May 3, 2011 Author Report Share Posted May 3, 2011 i really hope thats all it is. if not the next month is going to suck. I may toss my stock wheels back on and sell my wheels and tires along with my su set up to get the 610 back on the road asap. Quote Link to comment
DISLEXICDIME Posted May 3, 2011 Report Share Posted May 3, 2011 Skunk is your oil pan dented at all Quote Link to comment
izzo Posted May 3, 2011 Report Share Posted May 3, 2011 Worth a try. Check the alternator mount bolts to see if its them :unsure: True story, happened on my 521. Thought i had a rod knock too, turned out to be missing the bottom alt bolts :rolleyes: Quote Link to comment
skunk Posted May 3, 2011 Author Report Share Posted May 3, 2011 Skunk is your oil pan dented at all nope Quote Link to comment
mklotz70 Posted May 3, 2011 Report Share Posted May 3, 2011 if your eng is toast, the guy(Josh?) driving the red 521 with aluminum wheels is selling his 2.0/trans/rad....all in good running/working condition. He had a perfect dash pad in the truck and hung out with the cute blonde and brunette....he's also the one that loaded up an SR20 from Jeremy at the end of the day. Quote Link to comment
exit64 Posted May 3, 2011 Report Share Posted May 3, 2011 Skunk, I am also working on it on this end after Skib called me last night. I will shoot over to E&L after work and talk to Don over there. One of his buddies in The Dalles has a stash of Datto stuff so you never know. Should have an answer by 5 or so this evening. Quote Link to comment
skunk Posted May 3, 2011 Author Report Share Posted May 3, 2011 thanks every one, Im going to dig into the engine a bit more today and see if i cant pin point the noise. Quote Link to comment
Skib Posted May 4, 2011 Report Share Posted May 4, 2011 it may not be a bearing but theres alot of little noises and its very faint. were working on it today and getting rid of some of the loose shit and eliminating some of the other rattles Quote Link to comment
Pumpkn210 Posted May 4, 2011 Report Share Posted May 4, 2011 Datsuns do tend to be rattle traps! It did sound like somethin was wrong wit it though... Quote Link to comment
Skib Posted May 4, 2011 Report Share Posted May 4, 2011 It did sound like somethin was wrong wit it though... cant be 100% sure yet Quote Link to comment
skunk Posted May 4, 2011 Author Report Share Posted May 4, 2011 pulled some more stuff out of the engine bay, bolted down some things better. its still hard to pin point the noise, going to pull out the l20 intake/exhaust that bolted together and pull out the rest of the emissions stuff and ac stuff. see if getting all the extra crap out of there will help at all. I want to be 100% its not somthing stupid before spending money on stuff i dont need. Quote Link to comment
Rustina 510 Posted May 4, 2011 Report Share Posted May 4, 2011 Is it a efi or carbs? Quote Link to comment
Skib Posted May 4, 2011 Report Share Posted May 4, 2011 Is it a efi or carbs? what :huh: Quote Link to comment
Laecaon Posted May 4, 2011 Report Share Posted May 4, 2011 what :huh: He is suddenly on an EFI kick after that thread were you said EFI on the 1800 SSS was JDM ONLY. Quote Link to comment
