freekwonder Posted May 27, 2013 Report Share Posted May 27, 2013 Its an auto ecu freek, they have a higher idle. for some reason my idle is still up around 1500 rpms. It's starts low (round 1000) then jumps up after a bit. I know the auto will be a little higher, but isn't that around double? Quote Link to comment
Guest roseyroseyrose Posted May 27, 2013 Report Share Posted May 27, 2013 oooohhhhhh. i never peeled the plastic off that same sticker. woops! now i know for next time... :confused: Quote Link to comment
DatMo Posted May 27, 2013 Report Share Posted May 27, 2013 realized my civic center console doesn't fit.... time to sell more. Quote Link to comment
Guest roseyroseyrose Posted May 27, 2013 Report Share Posted May 27, 2013 and i forgot to insert the quote so no one knows what im talking about. and i dont own a dime. :blush: Quote Link to comment
edekalil Posted May 28, 2013 Report Share Posted May 28, 2013 Found my lower control arms, now just have to figure out how to change the bushings out. Also found a set of pedals I will need to make my automatic a stick shift. Even though the clutch on the left looks just like the one on a 510 it does not have the little L shaped piece of metal welded on with an adjustment screw. I will have to add that. Also got my 4 speed shifting again, for some reason the lever at the other end from the shifter had slipped out of position and was not contacting the other levers to put it in gear. Eddie Quote Link to comment
zianian Posted May 29, 2013 Report Share Posted May 29, 2013 Drove it very stupidly. Didn't get busted. Luckily. Also didn't hit a deer with it. But an on coming car sure did. I also didn't hit the big garbage pal that was blown by the wind into my lane. It was a good day... so far. Quote Link to comment
demo243 Posted May 30, 2013 Report Share Posted May 30, 2013 Pushed her back into the garage... after she had to spend an unfortunate night outside... poor datsun Quote Link to comment
jrock4224 Posted May 30, 2013 Report Share Posted May 30, 2013 realized my civic center console doesn't fit.... time to sell more. oics pm me so i can see if i want ... Quote Link to comment
jovial_cynic Posted May 30, 2013 Report Share Posted May 30, 2013 Installed the top-mount SR intake and turbo. Realized /afterwards/ that I had to clock the turbo, and had a neck of a time getting the exhaust-side bolts loosened. I managed to get it sorted out. Next up: wiring! Quote Link to comment
DatMo Posted May 31, 2013 Report Share Posted May 31, 2013 oics pm me so i can see if i want ... ima try and see if i can get it to fit Quote Link to comment
67_1600 Posted May 31, 2013 Report Share Posted May 31, 2013 Got my new rims and tires installed yesterday. Now I just need to get her lower (among a million other things)... 2 Quote Link to comment
banzai510(hainz) Posted May 31, 2013 Report Share Posted May 31, 2013 the 510 is too good for them wheels. You wont be able to loert the front much with those wheels. Most time those wheels are for a 240z. off set it more out. I had a set of those and took to the recycler Im thinking stock hubcaps slammed down=Pimpin Quote Link to comment
67_1600 Posted May 31, 2013 Report Share Posted May 31, 2013 the 510 is too good for them wheels. You wont be able to loert the front much with those wheels. Most time those wheels are for a 240z. off set it more out. I had a set of those and took to the recycler Im thinking stock hubcaps slammed down=Pimpin I do plan on swapping the wheels with some that have less offset, but they're what I had so I went with them. I don't mind the idea of steel rims with hubcaps but I want a 14" wheel. Whatever I go with I want it to be period correct and the slots fit the bill in that respect. When I do finally get around to lowering, I won't go more than an inch or two. Quote Link to comment
banzai510(hainz) Posted May 31, 2013 Report Share Posted May 31, 2013 at least 3in up from maybe 2 in back otherwise youll have drivline issue hitting the body. nice wagoon!!!!!!!!!!!!!!!!!! Quote Link to comment
DatMo Posted June 1, 2013 Report Share Posted June 1, 2013 waiting for my coilovers to be shipped. widened the metal piece that door panels slide into. I need a window regulator. not in any rush and want fair pricing. still cant decide if i want to do the diy coilover setup. I don't wanna tuck and everyone says it slams the car. Quote Link to comment
Datsunscom Posted June 1, 2013 Report Share Posted June 1, 2013 Today I started my 510 and dialed in the idle on the standalone ECU. Amazing how a swap into a different car can require a fairly significant change of ignition settings. Quote Link to comment
zianian Posted June 2, 2013 Report Share Posted June 2, 2013 Guess who went country cruisin, freeway screamin', yardsale shoppin, and Dyno Day get togetherin' yesterday... All with OUT their oil filler cap. Yup.... Me. What a MESS. But still... Was relieved it was only that hole in the valve cover thingy spitting oil all over everything. Not a busted block or head or anything. Oh yeah.... Ya know that Datsun 240 race car Hotwheels just made a copy of? Met the dude that owns/races that bad boy. Took him for a ride. He felt up my rear end too (searching for my clunk). His Z buddies want me (my car) to come to thier shows. And he wants to get my baby blu all dialed in handling wise. Very cool. Was a good day. Plus... I bought 2 more window AC units too. Those suckers are selling like hot cakes. (Rear brake disc kit paid for ;) Quote Link to comment
DatMo Posted June 2, 2013 Report Share Posted June 2, 2013 Still lookin for a regulator. Gonna buy mr2 inserts. 1985 rears but dont know if i should uby the kybs or monroes. the guy i bought my struts from said the Kyb ones need modding. cleaned out trunk and gonna cut some hemp board i bought for a rear board. Quote Link to comment
DISLEXICDIME Posted June 2, 2013 Report Share Posted June 2, 2013 i ran a 225 7inch coil over with sw20 mr2 4 way agx on this car 2 Quote Link to comment
DatMo Posted June 2, 2013 Report Share Posted June 2, 2013 i ran a 225 7inch coil over with sw20 mr2 4 way agx on this car that thing's pretty badass Quote Link to comment
TENDRIL Posted June 2, 2013 Report Share Posted June 2, 2013 changing my exhaust ...again... pics to come Quote Link to comment
r0p0doe Posted June 2, 2013 Report Share Posted June 2, 2013 Made her my piggy bank to get her back on the road, hoping I forget I have $ stored in there. Quote Link to comment
TENDRIL Posted June 3, 2013 Report Share Posted June 3, 2013 i cut a piece of my car, sorry guys Quote Link to comment
the510keeper Posted June 3, 2013 Report Share Posted June 3, 2013 i cut a piece of my car, sorry guys Cool idea 1 Quote Link to comment
