Stoffregen Motorsports Posted May 19, 2023 Report Share Posted May 19, 2023 You destroy them when removing them. I forget what they're called, but you can find them at any hardware store, or at McMaster-Carr or https://www.clipsandfasteners.com 2 Quote Link to comment
Stoffregen Motorsports Posted May 19, 2023 Report Share Posted May 19, 2023 Push nut. https://www.google.com/search?client=firefox-b-1-d&q=push+nut 1 1 Quote Link to comment
EDM620 Posted May 19, 2023 Report Share Posted May 19, 2023 Stoffregen is correct on both counts. Don't try to save them as they are spring steel and will be damaged during removal. Most hardware stores should have a few different sizes. Use a socket that fits the perimeter and just push the new one on. 1 1 Quote Link to comment
six2ohyea Posted May 21, 2023 Author Report Share Posted May 21, 2023 Some sweet pick ups from the Datslocos swap meet. Including (I think) an OEM original painted grill and badge. And a full center console with OEM hitachi radio and A/C controls 1 Quote Link to comment
six2ohyea Posted May 22, 2023 Author Report Share Posted May 22, 2023 Decided to pull the the dash to do a dash cover repair. Hit a couple of hiccups. #1 dash insert was held in by 1 stripped screw. 🤦🏻 so had to pull the dash as one hole piece. Anyone know a way to remove this screw? 1 Quote Link to comment
six2ohyea Posted May 22, 2023 Author Report Share Posted May 22, 2023 BTW my 620 came with A/C. Is it capable to run again? I know it used Freon Quote Link to comment
datzenmike Posted May 23, 2023 Report Share Posted May 23, 2023 Well if you can find any R12 away you go. It's no longer manufactured or used since '94. But R134a isn't compatible in R12 systems and it needs to be converted. 1 Quote Link to comment
six2ohyea Posted May 23, 2023 Author Report Share Posted May 23, 2023 1 hour ago, datzenmike said: Well if you can find any R12 away you go. It's no longer manufactured or used since '94. But R134a isn't compatible in R12 systems and it needs to be converted. Any more info where I can read up on this? Quote Link to comment
six2ohyea Posted May 23, 2023 Author Report Share Posted May 23, 2023 Painted the headliner trim pieces and bolts to go with the black headliner that will be installed. Quote Link to comment
720_Jeff Posted May 23, 2023 Report Share Posted May 23, 2023 17 minutes ago, six2ohyea said: Any more info where I can read up on this? This seems to be a pretty good explanation of what is required. https://studentlesson.com/how-to-convert-your-car-ac-r12-system-to-r134a/ 1 Quote Link to comment
EDM620 Posted May 23, 2023 Report Share Posted May 23, 2023 11 hours ago, datzenmike said: It's no longer manufactured or used since '94 R12 is a major ozone depleater (ozone O3 is in the stratosphere and absorbs the intense UV-B from the sun) which is why it became banned. I'm assuming the AC was a dealer installed item and not from the factory. Aftermarket kits were a big thing in the 70's & 80's as many cars didn't have factory AC or at least hadn't been shipped from the factory with. I worked as an installer for a couple years (air, cruise, stereo) and we could put AC into nearly anything, available space was usually the limiting factor. I saw some claims that you can still buy R12 (no longer manufactured but cleaned and reclaimed) however switching to R134a is a better choice. 1 Quote Link to comment
Stoffregen Motorsports Posted May 23, 2023 Report Share Posted May 23, 2023 Did you get that screw out yet? Vice grips... 1 Quote Link to comment
six2ohyea Posted May 23, 2023 Author Report Share Posted May 23, 2023 Been calling around to see if any shop can help me with the conversion. If no luck might have to do a delete. Wish me luck! Quote Link to comment
Stoffregen Motorsports Posted May 23, 2023 Report Share Posted May 23, 2023 You really don't need to go through all those steps to convert to 134. Change the o-rings and install the R134 fitting and give it a shot. Yo should have a shop do the filling because it needs oil and the correct amount of refrigerant at the right pressure, but that is not expensive. Maybe a couple hundred bucks tops. Here's that fitting - https://www.amazon.com/Retrofit-Fitting-Conversion-Conditioner-Refrigerant/dp/B07SZKY6R1 1 Quote Link to comment
Stoffregen Motorsports Posted May 23, 2023 Report Share Posted May 23, 2023 I have a shop up here that I use for all my A/C stuff. If you're willing to travel 100 miles, he does a lot of custom A/C work. 1 Quote Link to comment
six2ohyea Posted May 23, 2023 Author Report Share Posted May 23, 2023 27 minutes ago, Stoffregen Motorsports said: Did you get that screw out yet? Vice grips... I did! 22 minutes ago, Stoffregen Motorsports said: I have a shop up here that I use for all my A/C stuff. If you're willing to travel 100 miles, he does a lot of custom A/C work. 100 miles isn’t too bad. Where abouts? Quote Link to comment
Stoffregen Motorsports Posted May 23, 2023 Report Share Posted May 23, 2023 1 hour ago, six2ohyea said: 100 miles isn’t too bad. Where abouts? Shingle Springs (just before Placerville) 1 Quote Link to comment
six2ohyea Posted May 23, 2023 Author Report Share Posted May 23, 2023 49 minutes ago, Stoffregen Motorsports said: Shingle Springs (just before Placerville) Perfect! My pops lives in Eldorado Hills 1 Quote Link to comment
Stoffregen Motorsports Posted May 23, 2023 Report Share Posted May 23, 2023 Nice. Drop it off with Jonboy, stay at your parent's place. Done and done. 1 Quote Link to comment
six2ohyea Posted May 23, 2023 Author Report Share Posted May 23, 2023 7 hours ago, Stoffregen Motorsports said: You really don't need to go through all those steps to convert to 134. Change the o-rings and install the R134 fitting and give it a shot. Yo should have a shop do the filling because it needs oil and the correct amount of refrigerant at the right pressure, but that is not expensive. Maybe a couple hundred bucks tops. Here's that fitting - https://www.amazon.com/Retrofit-Fitting-Conversion-Conditioner-Refrigerant/dp/B07SZKY6R1 These O- rings? Link: https://www.autozone.com/cooling-heating-and-climate-control/a-c-system-o-ring-gasket-kit/nissandatsun/620 Quote Link to comment
Stoffregen Motorsports Posted May 23, 2023 Report Share Posted May 23, 2023 1 hour ago, six2ohyea said: These O- rings? Link: https://www.autozone.com/cooling-heating-and-climate-control/a-c-system-o-ring-gasket-kit/nissandatsun/620 Yep! 1 Quote Link to comment
Crashtd420 Posted May 24, 2023 Report Share Posted May 24, 2023 13 hours ago, six2ohyea said: These O- rings? Link: https://www.autozone.com/cooling-heating-and-climate-control/a-c-system-o-ring-gasket-kit/nissandatsun/620 I'm not 100% sure but I think you need a special lubricant/oil or something for the orings .. I got a bottle of something with the universal kit I used to add ac to my 521... 1 Quote Link to comment
Crashtd420 Posted May 24, 2023 Report Share Posted May 24, 2023 This is something like what I got... https://www.oreillyauto.com/detail/c/murray-climate-control/chemicals---fluids/grease---lube/graphite-lubricant/1efe28ee2d3e/murray-climate-control-4-ounce-silicone-o-ring-lubricant/mry0/59019 1 Quote Link to comment
datzenmike Posted May 24, 2023 Report Share Posted May 24, 2023 O ring lubricant... ... more click bait. 1 1 Quote Link to comment
iceman510 Posted May 24, 2023 Report Share Posted May 24, 2023 It's essentially used as an installation aid to reduce friction and chances of damage to the o rings when installing. The slightest nick can cause a leak. Very essential in a production environment, maybe not so essential at home when doing just a few joints if you take your time. Typically it is the same as the lubricant used in the system for the compressor. 1 Quote Link to comment
