KELMO Posted April 17, 2023 Report Share Posted April 17, 2023 17 hours ago, MikeRL411 said: Painting that plate with non authentic colors amounts to counterfeiting a plate, Well, he went from blue to black so... Go big or go home says I. Quote Link to comment
six2ohyea Posted April 17, 2023 Author Report Share Posted April 17, 2023 It’s vinyl wrap. Can easily come off. Would it be legal to wrap it with blue and yellow? Quote Link to comment
Stoffregen Motorsports Posted April 17, 2023 Report Share Posted April 17, 2023 (edited) 20 hours ago, six2ohyea said: Do you have a photo of them on hand? Not on hand, but I can snap one. Actually, here's one of the same wheels on my Rover. Edited April 17, 2023 by Stoffregen Motorsports 4 Quote Link to comment
six2ohyea Posted April 17, 2023 Author Report Share Posted April 17, 2023 Oh cool and the Datsun hub cap pops right on? I’ll def be keeping an eye out for some on sale 1 Quote Link to comment
six2ohyea Posted April 26, 2023 Author Report Share Posted April 26, 2023 Got my Datsun Clarion stereo Blue tooth in. Unfortunately it’s too small for the insert area. Hopefully the stereo install place can make it fit. Looks like this specific stereo goes into the dash. (Would fit perfectly). Unfortunately I have AC vents that I want to restore eventually in that area. BTW these buttons are awkwardly long… Quote Link to comment
six2ohyea Posted April 27, 2023 Author Report Share Posted April 27, 2023 Hadn’t driven the truck in 2 weeks. Had to turn the key between 3-4 times and pressing down on gas pedal to fire up. Realized shortly that the truck was leaking. It smelled like gas and oil so was a little confused. The leak stopped once I turned off the truck and started again. Drove it around for a bit and no leak. Gas and oil levels are good. Did I cause a flood? Oh and found a hole in my Transmission FML. VIDEO Here’s the hole. 2 Quote Link to comment
Crashtd420 Posted April 28, 2023 Report Share Posted April 28, 2023 (edited) That hole is normal, I believe it's just a drain..... My guess is incase of seal failure you dont want the oil trapped with the clutch disc.... No idea on the leak, possibly flooded as you stated.... Edited April 28, 2023 by Crashtd420 1 1 Quote Link to comment
Stoffregen Motorsports Posted April 28, 2023 Report Share Posted April 28, 2023 You could see a fuel leak or just smell gas? Loose carb mounting nuts maybe? Quote Link to comment
six2ohyea Posted April 28, 2023 Author Report Share Posted April 28, 2023 Yea, fuel was leaking and it smelled like gas. But the leak stopped after turning off and on again. 2 Quote Link to comment
six2ohyea Posted April 29, 2023 Author Report Share Posted April 29, 2023 Finally got my Dashtop cover 2 Quote Link to comment
EDM620 Posted April 30, 2023 Report Share Posted April 30, 2023 4 hours ago, six2ohyea said: Finally got my Dashtop cover Where did you get that from? Quote Link to comment
six2ohyea Posted April 30, 2023 Author Report Share Posted April 30, 2023 33 minutes ago, EDM620 said: Where did you get that from? Datsun Garage. They just stocked up 1 Quote Link to comment
six2ohyea Posted May 2, 2023 Author Report Share Posted May 2, 2023 Interior parts are in. 😎 3 Quote Link to comment
Stoffregen Motorsports Posted May 2, 2023 Report Share Posted May 2, 2023 On 4/28/2023 at 7:42 AM, six2ohyea said: Yea, fuel was leaking and it smelled like gas. But the leak stopped after turning off and on again. Find the leak. It could kill you. 1 2 Quote Link to comment
six2ohyea Posted May 2, 2023 Author Report Share Posted May 2, 2023 FML.. this guy glued the floor mat. Also looks like there is some rust.. 2 Quote Link to comment
six2ohyea Posted May 3, 2023 Author Report Share Posted May 3, 2023 Also wanted to change the shift boot. Not sure this will work. The base of the boot is significantly thicker than the previous one. top is old vs bottom new. Shipped from Z car depot 2 Quote Link to comment
EDM620 Posted May 3, 2023 Report Share Posted May 3, 2023 As long it it makes a good seal, keep out the fumes from underneath. Expect you'll find rust through up where the cowl and firewall meet - typical of the 620's. Prime reason why the carpets get wet then floor rusts. 1 Quote Link to comment
six2ohyea Posted May 3, 2023 Author Report Share Posted May 3, 2023 Got the speaker spacer vinyl wrapped and kick panels installed. 2 Quote Link to comment
six2ohyea Posted May 3, 2023 Author Report Share Posted May 3, 2023 On 4/17/2023 at 8:57 AM, Stoffregen Motorsports said: Not on hand, but I can snap one. Actually, here's one of the same wheels on my Rover. Just scored a set for $80 3 Quote Link to comment
Stoffregen Motorsports Posted May 4, 2023 Report Share Posted May 4, 2023 16 hours ago, six2ohyea said: Just scored a set for $80 Sweet! Quote Link to comment
]2eDeYe Posted May 5, 2023 Report Share Posted May 5, 2023 Some nice work going on up in here. B) 1 Quote Link to comment
six2ohyea Posted May 8, 2023 Author Report Share Posted May 8, 2023 Took most of not all the adhesive from the floor panels. (I went the chemical route) Now I just have some rust and a small hole in the floor. What else should I do to prep the floor? Going to be placing deadening mats and carpet. Quote Link to comment
EDM620 Posted May 8, 2023 Report Share Posted May 8, 2023 Remove as much rust as you can, wire wheel or whatever. Apply rust inhibitor/paint (POR15) and let dry very thorougly. Consider undercoating the bottom, same prep. Have you checked the cowl for leaking? Attack that now while interior is stripped. 1 Quote Link to comment
