GoonLuv Posted June 6 Report Share Posted June 6 What's everyone using for strut inserts in 280ZX struts when fitted to a 510? Im using T3 weld on coil overs if that makes a difference. Quote Link to comment
datzenmike Posted June 6 Report Share Posted June 6 I think KYB, Koni, Bilstein whatever will fit a stock length 280zx strut Quote Link to comment
yenpit Posted June 7 Report Share Posted June 7 If you are simply cruising in the 510, buy a good quality insert ie KYB, Monroe etc. If you drive "spirited" and/or some track day events, spend more mulla on a higher quality insert ie Koni, Bilstein etc. If really serious, buy an adjustable insert! Quote Link to comment
Draker Posted June 8 Report Share Posted June 8 I went with kyb gas adjust inserts. Quote Link to comment
datzenmike Posted June 8 Report Share Posted June 8 If you have never had the struts apart they may still have the original oil bath dampers in them. These can be 'renewed' and firmed up by replacing the old thin hydraulic oil with something thicker for about $15. Quote Link to comment
GoonLuv Posted June 16 Author Report Share Posted June 16 Thanks for the replies guys. Other than Rockauto I am not sure where to look for these. Rockauto only has KYB Excel-G's. Im sure those are probably fine I mostly drive around town with the occasional spirited back roads driving. Quote Link to comment
Stoffregen Motorsports Posted June 17 Report Share Posted June 17 (edited) Try Ground Control - https://groundcontrolstore.com/ They used to sell off the shelf parts, yet the strut inserts are not listed on their website. I prefer Tokico inserts over KYB. Edited June 17 by Stoffregen Motorsports Quote Link to comment
fiveoneO Posted June 19 Report Share Posted June 19 I too prefer the Tokico's over the KYB's. I did just hear that Koni is now selling inserts for the 280zx. You may want to look into those. 1 Quote Link to comment
banzai510(hainz) Posted Tuesday at 08:18 PM Report Share Posted Tuesday at 08:18 PM (edited) On 6/19/2022 at 9:02 AM, fiveoneO said: I did just hear that Koni is now selling inserts for the 280zx. You may want to look into those. I would do these if possible. I have the old orange Koni adjustable(retraction) going down is nothing but pull up is Hard to soft depends on setting. I got these cheap years ago. If your just a normal driver now I would as find soem cheap gas shocks. those yell konis are alot.$$$$ Edited Tuesday at 08:23 PM by banzai510(hainz) Quote Link to comment
datzenmike Posted Tuesday at 09:21 PM Report Share Posted Tuesday at 09:21 PM Hey, how are they adjusted? Do you have to remove to get at them? Quote Link to comment
banzai510(hainz) Posted Wednesday at 09:39 PM Report Share Posted Wednesday at 09:39 PM On 6/28/2022 at 2:21 PM, datzenmike said: how are they adjusted? Do you have to remove to get at them? Yes. push the shock all the way down then you can fell it engage then do a 1/4 turn then pull up on the strut. youl can fell the reisistance. most like a slip ring with holes around it. most likely making the holes smaller for the oil to pass thru Orange D shocks. Stoffregen would know more on these Quote Link to comment
banzai510(hainz) Posted Wednesday at 09:42 PM Report Share Posted Wednesday at 09:42 PM (edited) here is a idea https://classicgarage.com/510610710810.html 280zx is the length now people want for the shorter struts so these might not work anymore if you want to go low. the rear will be fine Edited Wednesday at 09:44 PM by banzai510(hainz) Quote Link to comment
