Zonargx Posted November 29, 2020 Author Report Share Posted November 29, 2020 (edited) I’m gonna have to get some at the auto parts I have ngk plugs right now. When I bought the truck I did a basic tune up on it and bought ngk but don’t remember what they were. There more likely not those since I just had the auto parts give me what was recommend Edited November 29, 2020 by Zonargx 1 Quote Link to comment
Zonargx Posted November 29, 2020 Author Report Share Posted November 29, 2020 I looked them up and they are (ngk standard copper 4922) 1 Quote Link to comment
Crashtd420 Posted November 29, 2020 Report Share Posted November 29, 2020 1 minute ago, Zonargx said: I’m gonna have to get some at the auto parts I have ngk plugs right now. When I bought the truck I did a basic tune up on it and bought ngk but don’t remember what they were. They are more like not those since I just had the auto parts give me what was recommend You probably got the right plugs but my guess is they are the resistor type.... If you want to go one step further a good set of low resistance plug wire an help too... I think it was recommended to have them below 1000 ohms of resistance... I bought a make you own set from Msd, I believe, I bought a V8 kit so I have extra wires if needed... i can find the part number if you like.... 1 Quote Link to comment
Crashtd420 Posted November 29, 2020 Report Share Posted November 29, 2020 2 minutes ago, Zonargx said: I looked them up and they are (ngk standard copper 4922) Yup those are the br6es.... The b6es are 7432.... 1 Quote Link to comment
Crashtd420 Posted November 29, 2020 Report Share Posted November 29, 2020 Did you ever catch the info on counterfeit plugs.... Definitely buy from a reputable source... 1 Quote Link to comment
Zonargx Posted November 29, 2020 Author Report Share Posted November 29, 2020 (edited) I’ll look into the wires also but so it’s best I get b6es over the BP6ES . My pistons aren't flat and I bought the plugs from autozone right around the corner from my place Edited November 29, 2020 by Zonargx 2 Quote Link to comment
datzenmike Posted November 29, 2020 Report Share Posted November 29, 2020 My 710 is BP6ES and '78 620 was BPR6ES. This is for an L20B. Both are projection. Projection plugs run hotter thus better self cleaning at lower speeds. At higher speeds they are cooled by the inrush of air and fuel. They are closer to the center of the combustion so the flame has a shorter radius distance to travel out to the edges than if the plug was on one side and it had to travel the diameter distance. Shorter burn time means the ignition can be retarded. 2 Quote Link to comment
Crashtd420 Posted November 29, 2020 Report Share Posted November 29, 2020 29 minutes ago, Zonargx said: I’ll look into the wires Incase you wanna check this out.... https://www.amazon.com/dp/B001BDSVOM/ref=cm_sw_r_cp_apa_fabt1_yI.WFbFHAMCKV?_encoding=UTF8&psc=1 500 ohm per foot, its 8mm diameter too and I believe stock are 7mm.. I did have to open up the clip on top of the valve cover a little... Comes with the crimp tool too... 1 Quote Link to comment
Zonargx Posted November 29, 2020 Author Report Share Posted November 29, 2020 I place the order on the plugs already. Going to install my alternator bracket now. Thanks for for the help guys 2 Quote Link to comment
Zonargx Posted December 1, 2020 Author Report Share Posted December 1, 2020 @mainer311 I believe I saw some pics of your sound system set up a while back I believe it was a topic of the carpeting re done? Didn’t you have some mids installed on your door panels? I want to install some.... all I have right now are some 3 inch teeter from when I had my old 73 Chevy c20 but I want my mids. I’m sound dampening my truck in a few days probably Saturday or anyone else have how to install ideas or that they've done ? Quote Link to comment
mainer311 Posted December 1, 2020 Report Share Posted December 1, 2020 Yes, there are 6-1/2” in the doors. They are 2-ways, with a directional tweeter in the center. The previous owner cut the holes to mount 5-1/4”, but I managed to get 6-1/2 to fit. It’s very tight. The window crank gear rack comes down and is very close to where he cut the holes. If I had done it my way, I would have built a custom center console that fits over the transmission hump, and had 2 angled speakers in that. I may still do it this way if I ever get replacement door cards. Quote Link to comment
d.p Posted December 1, 2020 Report Share Posted December 1, 2020 I thought about speakers but in the end I just use a JBL flip 4 which hits hard enough for me. 1 Quote Link to comment
datzenmike Posted December 1, 2020 Report Share Posted December 1, 2020 2 hours ago, mainer311 said: Yes, there are 6-1/2” in the doors. They are 2-ways, with a directional tweeter in the center. The previous owner cut the holes to mount 5-1/4”, but I managed to get 6-1/2 to fit. It’s very tight. The window crank gear rack comes down and is very close to where he cut the holes. If I had done it my way, I would have built a custom center console that fits over the transmission hump, and had 2 angled speakers in that. I may still do it this way if I ever get replacement door cards. Poor separation with that, more like mono. Or better yet get something larger like 8" 'subs' for the custom enclosure and again move the hi range choice farther apart. Low frequency sound is non directional, you can mount anywhere even under the seat. High frequency needs to be farther apart to fool your ears with the illusion you're in a larger room. I have a pair of what used to be called 'biscuit' tweeters. Like a small cookie sitting on the dash on each side facing up. The high frequency sound projects upward and reflects off the inner windshield producing the illusion of a larger room. Mid range speakers are more in the 6 1/2" range so leave in the doors or as far apart as available. 2 Quote Link to comment
mainer311 Posted December 1, 2020 Report Share Posted December 1, 2020 (edited) 3 hours ago, datzenmike said: Poor separation with that, more like mono. Not if they're facing different directions. Think about it: the driver's side door speaker is firing into your leg and bouncing off the wall on the other side of the cab. Your head is completely out of the zone that the mid-woofer is projecting to. Not to mention...this is a 521, not a bus. Then again, I don't know much about audio. Edited December 1, 2020 by mainer311 3 Quote Link to comment
Charlie69 Posted December 1, 2020 Report Share Posted December 1, 2020 An audiophyle? Quote Link to comment
Zonargx Posted December 1, 2020 Author Report Share Posted December 1, 2020 Damn Mainer hahaha. another question I have already made to order on the b6es plugs and both places seem to not have them them both places replace the order for bpr6es coils Am I ok running those cuz all I been ready is pretty much negative comments on them going bad prematurely Quote Link to comment
mainer311 Posted December 1, 2020 Report Share Posted December 1, 2020 (edited) 22 minutes ago, Charlie69 said: An audiophyle? Yes, but one who believes in practicality and data-backed science. I won’t go spend a $1000 on some oxygen free copper cables with magic boxes in the middle of them. There’s a lot of snake oil in the industry, and unfortunately, a lot of people buy into it. Edited December 1, 2020 by mainer311 2 Quote Link to comment
mainer311 Posted December 1, 2020 Report Share Posted December 1, 2020 3 minutes ago, Zonargx said: Damn Mainer hahaha. another question I have already made to order on the b6es plugs and both places seem to not have them them both places replace the order for bpr6es coils Am I ok running those cuz all I been ready is pretty much negative comments on them going bad prematurely I think you’ll be fine running projected in a stock engine, and the resistors don’t make that much difference, so if BPR6ES is all you can get, just use them. 1 Quote Link to comment
Charlie69 Posted December 1, 2020 Report Share Posted December 1, 2020 25 minutes ago, mainer311 said: Yes, but one who believes in practicality and data-backed science. I won’t go spend a $1000 on some oxygen free copper cables with magic boxes in the middle of them. There’s a lot of snake oil in the industry, and unfortunately, a lot of people buy into it. Well said! I like crisp clean tones with real bass not synthesizer noise!!! Quote Link to comment
banzai510(hainz) Posted December 1, 2020 Report Share Posted December 1, 2020 (edited) somebody is RICH$$$$$$$ with all those Fluke Meters How many does one need? Edited December 1, 2020 by banzai510(hainz) Quote Link to comment
datzenmike Posted December 1, 2020 Report Share Posted December 1, 2020 36 minutes ago, mainer311 said: Yes, but one who believes in practicality and data-backed science. I won’t go spend a $1000 on some oxygen free copper cables with magic boxes in the middle of them. There’s a lot of snake oil in the industry, and unfortunately, a lot of people buy into it. True that. LOTS of snake oil. Just like after market 'performance' parts. Technically 'better' but truly not worth $50 a HP. Quote Link to comment
mainer311 Posted December 1, 2020 Report Share Posted December 1, 2020 4 minutes ago, banzai510(hainz) said: somebody is RICH$$$$$$$ with all those Fluke Meters How many does one need? I did the initial setup of this class A amplifier in the engineering lab at work. Quote Link to comment
banzai510(hainz) Posted December 1, 2020 Report Share Posted December 1, 2020 we use Fliukes at work also. I found a Fuke 70 at the Pawn shop and got it at home. But I also have a old Simpson analog also and a Tripplett analog. Don't pop the Fuse!!!!!!!!!!!!!! Quote Link to comment
Crashtd420 Posted December 1, 2020 Report Share Posted December 1, 2020 1 hour ago, Zonargx said: Damn Mainer hahaha. another question I have already made to order on the b6es plugs and both places seem to not have them them both places replace the order for bpr6es coils Am I ok running those cuz all I been ready is pretty much negative comments on them going bad prematurely Where are you going? They should be able to get them no problem, are you asking for the plugs for you truck or asking them for the specific plug..... I actually dont see them available through autozone, they have the -11 but not the regular b6es, but it seems like napa, advance auto, and oriellys have them... 1 Quote Link to comment
Zonargx Posted December 2, 2020 Author Report Share Posted December 2, 2020 Yea I was already able to get a hold of some from Napa and they will probably be ready tomorrow. Oriellys couldn’t find them either. Napa has them it was $15 just to deliver home haha that’s more than a set of plugs so I’m just picking up Quote Link to comment
