Zonargx Posted December 23, 2021 Author Report Share Posted December 23, 2021 Yea I did i have the s14 wiring diagram. With the lock tab on top the left is light and right is sense. This is Matt i was thinking on running the senses to a new wire and hooking it up to the fusebox switch source Quote Link to comment
banzai510(hainz) Posted December 23, 2021 Report Share Posted December 23, 2021 (edited) your 521 T connector the orignal one will have the 12v switchable. 521drawingelectrical.bmp Edited December 23, 2021 by banzai510(hainz) Quote Link to comment
banzai510(hainz) Posted December 23, 2021 Report Share Posted December 23, 2021 (edited) on stock 521 T connector N is yellow wire F white blk stripe F means Field I think KA L is Line S Sense How you convert I dont know 521drawingelectrical.bmp Edited December 23, 2021 by banzai510(hainz) Quote Link to comment
Zonargx Posted December 23, 2021 Author Report Share Posted December 23, 2021 (edited) My truck didn’t have t connection so I went of the diagram. White/black was my L or field f im the old alternator and sence yellow wire. The yellow has to be connected to a switch source right from what Matt said old harness was cut and just had female connectors and the new and I don’t have the plug for the la so I’m using female connector like how it was on the older l16 alternator before the swap Edited December 23, 2021 by Zonargx Quote Link to comment
Zonargx Posted December 23, 2021 Author Report Share Posted December 23, 2021 i followed what this how to diagrams Quote Link to comment
banzai510(hainz) Posted December 23, 2021 Report Share Posted December 23, 2021 (edited) well one of the 521 wires the yellow or the blk /white is switched from the Key I have to go check that out to be sure. but Im off line for awhile in a couple mins damn that the drawing I was looking for if its wires this way as the drawing and you dont have a electric choke relay then have the alternator check out Edited December 23, 2021 by banzai510(hainz) Quote Link to comment
thisismatt Posted December 23, 2021 Report Share Posted December 23, 2021 So...I'm not sure, or I'm wrong. Either way, my sense wire is hot all the time on my 521 (I just went out and checked), but maybe the KA alternator can't be, or is defective. My truck sits for long periods and doesn't drain the battery. Quote Link to comment
thisismatt Posted December 23, 2021 Report Share Posted December 23, 2021 According to a 350z FSM, its sense wire is also directly (fused) to the battery, so I'm not sure what's up if not a defective alternator... Quote Link to comment
Zonargx Posted December 23, 2021 Author Report Share Posted December 23, 2021 Based of the ka diagram it’s also straight to the battery with a fuse Quote Link to comment
Zonargx Posted December 23, 2021 Author Report Share Posted December 23, 2021 This is a diagram I drew of how my wiring is on my truck Quote Link to comment
d.p Posted December 23, 2021 Report Share Posted December 23, 2021 Looks like something a 3 year old would draw. Hehe 1 Quote Link to comment
Zonargx Posted December 23, 2021 Author Report Share Posted December 23, 2021 So now I’m thinking what if my battery won’t charge good like has a dead cell does the sense wire detect it’s low and try to make the alternator work this using power and then draining the battery? Sorry I’m not that experience with car in-depth electrical stuff just the basic Quote Link to comment
mklotz70 Posted December 24, 2021 Report Share Posted December 24, 2021 I doubt this will add any answers, but maybe some clarity. The continuity tester is like the ohms setting on a multimeter. It has a battery inside it that will turn the light on when the circuit is completed...in other words, has continuity. There are higher end test lights that look like yours that do multiple types of tests....continuity being one of them. You do not have that. Your test light lights when there is an external battery (voltage) providing the juice. When you connect the ground cable to ground and then the tip to something providing voltage, it will light. Be careful putting it in series because if the drain(load) is too high, it will burn out the bulb. So, putting the test light between the neg term on the batt and the battery cable(disconnected) will show small drains(current flow), but if you were to turn your key to start, you'd probably burn the bulb out because of how much load(current) it was trying to pass. You multimeter's amp setting probably only handles 10mA.....which is not much. Most users kill this function trying to check current by doing the same thing that burns out the bulb in the test light....putting it across a load drawing too much current. This may answer some questions about the alt connections... http://datsun1200.com/modules/mediawiki/index.php?title=IR_Alternator_Conversion_Wiring It does say in there that the F wire to the alt is constantly hot, even when the car is off. Alternators do not have permanent magnets in them like generators. They require a small amount of external voltage to "excite" the windings. They create a field(EMF) that induces the voltage into the main windings once the the pulley is spinning. The secondary windings have to be moving for this to happen....no motion, no volts. Once it start spinning, the main(battery) output of the alt is looped back to the N(S) to keep providing the "excite" voltage. That's the white/yellow jumper. It's constantly HOT because it comes directly from the battery. The diodes should stop it from back feeding or draining the battery. The F terminal is basically the same as the B, but not made to handle as much load.....so it goes to the CHG(IGN) light or other meters/test indicators. Your WR/WB jumper is simply to make the CHG light work. So.....connect the batter cables......then connect the grd clamp of your light to the neg term. Remove the S line from the alt and probe it....it should light your test light, proving it's always hot as it should be. The big wire on the back of the alt should be hot as well. Once turning, it puts out a higher voltage than the battery and charges the battery. With the motor running, that wire should have about 14.4 volts on it. If not, you probably have a bad alt......make sure the S wire is hooked back up first. Hopefully, I'm right on all of this. It's been a really long time since I've even looked at this stuff. The 1200 page has some great info on it....default to it if I'm wrong about any of this. lol I should have been in the shop an hour ago. Gotta run. Good luck! Quote Link to comment
Zonargx Posted December 24, 2021 Author Report Share Posted December 24, 2021 (edited) So then my diodes are probably bad because they drain my battery ? It didn’t use to do this before even after the ka swap. Everything is still wired the same. If after removing the sense and light goes off that stops the drain once plugged in the diodes drain it. Are the diodes grounding out or something? Reason my test light goes on with any metal Edited December 24, 2021 by Zonargx Quote Link to comment
mklotz70 Posted December 25, 2021 Report Share Posted December 25, 2021 (edited) Short answer...yes, it sounds like at least one of the diodes is shorted. Long answer.... Sounds like you have a multimeter. If so, go to the ohms/resistance setting. Hopefully, it's auto ranging, but if not, a setting in the middle is a good place to start...200? 2000? If it's auto ranging, ignore the comments about changing the range. If it's not, you'll need to keep switching the range from lowest(to check a sort) to highest(to check an open). Touch the leads together. It should show a short....zero ohms or really close....that proves that the meter is working. Disconnect the wires(all) from the alt. Put the neg lead to the case of the alt and touch the pos lead to the E on the alt.....you should get zero(or near zero) ohms. This proves you have a good ground(continuity between the case and the E terminal. Now touch the pos lead to the other terminals on the alt. Set the range to the largest selection and it should still show an open(really high ohms....meg ohms). If the alt is bad, you'll probably see a very low reading. To see the lowest ohm reading, turn the range down on the meter. Reverse the leads.....pos on the E or case and neg on each of the terminals. The B post(main alt output) should be an open with the leads on this way and then a low resistance when the leads are switched to the other way. There's lots of videos on YT about how to test the alt with a meter.....check some of those out. I'm so rusty at this stuff, I may just be muddying the waters. lol This is a good vid, but way more involved than what you need. At the 12 min mark, he does the test I just described. Check the vid for his AC test....if a diode is bad, I think the AC volts will be high. ....more good info... https://www.yesterdaystractors.com/cgi-bin/viewit.cgi?bd=farmall&th=1082507 ....and if you want to know everything about how the alt works...... chrome-extension://efaidnbmnnnibpcajpcglclefindmkaj/viewer.html?pdfurl=http%3A%2F%2Fwww.metroplexalternator.com%2Fuploads%2F1%2F5%2F2%2F8%2F15280940%2Fcharging_system_theory.pdf&clen=1653762&chunk=true Edited December 25, 2021 by mklotz70 Quote Link to comment
Zonargx Posted December 30, 2021 Author Report Share Posted December 30, 2021 (edited) Checked the alternator it was good. I just hook the sense to an ignition on switch source and hasn’t drain the battery so far so I’ll just leave it like that for now thanks for the help everyone thanks thisisMatt for the ignition source tip Edited December 30, 2021 by Zonargx 1 Quote Link to comment
datfast Posted October 29, 2022 Report Share Posted October 29, 2022 can anyone tell me what the space between the cab and box on my 521 is supposed to be? have tried looking it up but cannot find specs anywhere, thanks Quote Link to comment
NC85ST Posted October 31, 2022 Report Share Posted October 31, 2022 Need to be more specific. Pictures of the area you’re talking about would help. Quote Link to comment
Stoffregen Motorsports Posted October 31, 2022 Report Share Posted October 31, 2022 I'd say it needs to look right and fit properly. Generally, if the cab and bed mounting bolts are all centered in their bolt holes, it's going to be correct. You probably won't find a spec anywhere, except maybe an old body shop repair guide. Quote Link to comment
Haug Posted November 4, 2022 Report Share Posted November 4, 2022 Can anybody help me out with an aftermarket steering wheel and adaptor for a 1971 PL521. Original would be preferred but gave up on that on. Been looking for the longest time sure could use some help. HAUG Quote Link to comment
mainer311 Posted November 6, 2022 Report Share Posted November 6, 2022 Most Datsun steering columns are the same. The Grant adapter works for 510’s, 240Z’s, etc. Quote Link to comment
datzenmike Posted November 6, 2022 Report Share Posted November 6, 2022 I agree. I had a zx wheel on my 620 and the same one is now on my 76 710. There was a gap on the truck clam shell but the splines were compatible, the 710 was a perfect fit. Datsun steering wheels are too thin, like trying to hold onto a coat hanger wire. The zx was thick and soft padded for excellent grip, don't care for hard plastic or wood. The zx was also slightly smaller diameter than the Datsun ones so the steering was a bit quicker. I did try one from a 90s Nissan car and the spline was smaller 1 Quote Link to comment
Stoffregen Motorsports Posted November 6, 2022 Report Share Posted November 6, 2022 Momo, NRG, Grant and even LeCarra all make hubs for Datsuns. There are others, but I'd start with these mfg's. 1 Quote Link to comment
mrbigtanker Posted November 8, 2022 Report Share Posted November 8, 2022 (edited) On 11/4/2022 at 9:06 AM, Haug said: Can anybody help me out with an aftermarket steering wheel and adaptor for a 1971 PL521. Original would be preferred but gave up on that on. Been looking for the longest time sure could use some help. HAUG If you can wait I'll give you an older used MOMO one. Ill even deliver it to Dong beach for you. Will fit any 6 bolt aftermarket wheel. Edited November 9, 2022 by mrbigtanker 1 Quote Link to comment
Haug Posted November 16, 2022 Report Share Posted November 16, 2022 Thanks, I cant wait too much longer though, been looking for months (more like years) do you have a part # by any chance. I'll be looking still. 1 Quote Link to comment
