"Swamp thing" JBC 510 racecar
Icehouse
  • Replies 852
9 hours ago, ]2eDeYe said:
What an adventure. Crazy that weld went like that, it is pretty old though.
They are a forged unit!  Somehow it just broke.  I was talking to a rally buddy who races 510's he says that happens to them from time to time.
Well its off season time for the JBC team. I have been lacking in my participation on this thread so here is some more of what has been going on in no particular order.
The Honda engine swap project is turning out to be a project indeed. These engines are already engineered to fit other cars like a Miata with after market support so hurray for them. We on the other hand have to make just about everything ourselves. Don't get me wrong, we love doing this stuff, it just takes time. I thought this was an interesting picture of how much space we have to fit the crossmember. It really shows the balance shafts in the oil pan that dictate the limit of how far we can go trimming things away.
Our valve cover modification was a team effort. We used our "half hood" tool to see how much room we had. If the race car didn't have fresh paint, we could just trim the hood braces and be done with it. Since we plan to also use this engine in a few of our street cars too, we decided to modify the valve cover so the engine can fit without cutting the hood. We made a total of 3 modified valve covers for our planned projects. Jeff let me have some time on his Mill to remove the material from the front of the valve covers.
He then proceeded to be the magician with the welder and close the covers back up with some sheet aluminum. Here is the before and after shot I took at work after running them through the parts washer.
The exhaust header recipe is as follows:
Honda S2000 stock exhaust header from the 2.0L engine
Honda Accord K24 exhaust flange
A section of stainless tubing Jeff ordered from somewhere
The outer cylinders lined up just fine with the K24 flange spacing. The center 2 cylinders required some modification. Lots of time cutting and grinding later we managed to get things lined up. We still need to modify the bottom end to fit the 510 but it looks promising. Here is a pic of the header mocked up in the test car.
I had a trip to the local Pick n Pull junk yard to obtain some stuff for the project. The Acura TSX had been picked over already pretty well. Engine gone, wire harness cut to pieces etc. I did manage to get the engine ECU, throttle motor controller and some wiring connections we would need.
Time to figure out the wiring. Jeff picked up a sheet of plywood and we got started. I found the systems and wiring information for the Acura TSX so we got to work sorting things out. We got most of the connections and extra wires sorted before we got too tired. Not a good thing to do late at night.
Edited by Trophy24
Some more racing fun.
How much gas are we going to use this weekend? We go through about 10 gallons every 2 hours so it adds up quickly. Here is Jeff at the local filling station.
A few shots from the pits on a nice sunny day for racing!
And one of me trying to figure out how to go faster!
We store the car in the off season at my house. I finally moved it off the trailer and into the garage. Since I was driving it, it seemed like a good idea to go get the mail while I was at it!
Safely tucked away for the winter. Or until we take it apart to install the Honda engine!
Edited by Trophy24
  • Like 5
42 minutes ago, Trophy24 said:
We should be training somehow in the off season.
Seriously as a picture novice, any tips on how to fix the orientation in the thread would be appreciated.
Pretty certain the forum doesn't have the option.  Have to save them correctly on your pc/phone and reupload
On 10/8/2023 at 10:56 AM, chester said:
should look into the rsk type s oil pump it is smaller and a common swap for higher rpms
Other teams run the 2.0L RSX pump on their K24 engines and have issues with hours of vibration rattle sensors to death and bolts loose.  So we opted to leave it for reliability.  Our car already has a terrible vibration at high speeds we don't want it any worse.   That's also why we want to keep the stock ECU.
I see. It was an idea, and it would make the oil pan easier to make since it is smaller. hopefully you guys can get it going and it works for you
  • 3 months later...
Okay kids, we are less than two months away from our first race in 2024 but before we get you updated on all the K24 progress over winter, I thought I'd share some pics of some of the cars we raced with last September.  Because - well - race cars are awesome!
Here are some from turn 12 at The Ridge
large.09092023theridge(24).JPG.0ab1cd8d7
large.09092023theridge(25).JPG.149e820be
This team apparently has Phil and Steve Mahre for drivers.  You might remember them as Olympic medalists in the 1984 winter Olympics!
large.09092023theridge(26).JPG.a56985c79
large.09092023theridge(27).JPG.085957a9e
large.09092023theridge(28).JPG.df5071f01
large.09092023theridge(29).JPG.1a03937e7
large.09092023theridge(30).JPG.d1c380789
large.09092023theridge(31).JPG.43d82fde2
large.09092023theridge(32).JPG.8a279523e
large.09092023theridge(33).JPG.4aabc0822
large.09092023theridge(34).JPG.b60ea76c7
large.09092023theridge(35).JPG.c56e00575
large.09092023theridge(36).JPG.fc4aede1c
large.09092023theridge(37).JPG.4f6fae8f3
large.09092023theridge(38).JPG.5e5149719
large.09092023theridge(39).JPG.bad0b8cbd
large.09092023theridge(40).JPG.a0c6b22c8
large.09092023theridge(155).JPG.6e72b9ea
large.09092023theridge(156).JPG.1fcba835
large.09092023theridge(157).JPG.cd3c8fe1
large.09092023theridge(158).JPG.0504e854
large.09092023theridge(159).JPG.530fdf72
large.09092023theridge(160).JPG.c28bf313
large.09092023theridge(161).JPG.48489560
large.09092023theridge(162).JPG.a2dbcac3
large.09092023theridge(163).JPG.ef398566
large.09092023theridge(164).JPG.7088a736
Front straight
large.09092023theridge(165).JPG.0d1b2c0f
large.09092023theridge(166).JPG.9c6a8a55
large.09092023theridge(169).JPG.9192a7c8
large.09092023theridge(170).JPG.7ffdb64b
large.09092023theridge(171).JPG.2b6ac747
large.09092023theridge(172).JPG.3bb3b464
large.09092023theridge(173).JPG.54ba721d
Swamp thing is looking pretty beat at this point.  Auxiliary cooling unit in place of the headlights and apparently Jeff said he found a way to fold the front spoiler under the car...  That poor thing has sure taken some damage.  It's nice that we can just bend it back in shape unlike the fiberglass counterparts.
  • Like 3
The above photo was the first in my stack for September 10, 2023 at The Ridge Raceway.
See below for more.
Hey!  We're in 3dr place!!!  🤣 🤣🤣
large.09102023theridge(2).JPG.c2acd29b6a
A bunch of pics from turn 8
large.09102023theridge(3).JPG.82a0f08c64
large.09102023theridge(4).JPG.022765adc9
large.09102023theridge(5).JPG.23e4029934
large.09102023theridge(6).JPG.b85d5b57fa
large.09102023theridge(8).JPG.6d41005214
Quick shot of turn 1 - the track must have gone green.
large.09102023theridge(9).JPG.1c0f80526e
Jeff loves racing these guys...
large.09102023theridge(10).JPG.e6233ab6d
large.09102023theridge(11).JPG.ade3ac03c
large.09102023theridge(12).JPG.219caeed0
large.09102023theridge(13).JPG.8006cb10e
large.09102023theridge(14).JPG.c2002f500
large.09102023theridge(15).JPG.83da0e8ad
large.09102023theridge(16).JPG.0c5b55325
large.09102023theridge(17).JPG.0e3549992
large.09102023theridge(18).JPG.7ad361c0a
large.09102023theridge(19).JPG.be49496db
large.09102023theridge(20).JPG.c7c2d0494
large.09102023theridge(21).JPG.84be29641
large.09102023theridge(22).JPG.870248b5d
large.09102023theridge(23).JPG.e23280bb0
large.09102023theridge(24).JPG.6698d0721
large.09102023theridge(25).JPG.28bdad500
large.09102023theridge(51).JPG.126422204
large.09102023theridge(52).JPG.845cbde59
large.09102023theridge(53).JPG.3cb7a4bb8
Here the cars are exiting turn 12
large.09102023theridge(54).JPG.ffac1ff6a
large.09102023theridge(55).JPG.5aeb9f9e0
large.09102023theridge(56).JPG.1bfe46622
large.09102023theridge(57).JPG.dcc7a472e
large.09102023theridge(58).JPG.a1d3806e7
large.09102023theridge(60).JPG.cac72e838
large.09102023theridge(61).JPG.7579848b8
large.09102023theridge(62).JPG.f56c8d2aa
Now back at the top of 9
large.09102023theridge(67).JPG.8edaac68f
large.09102023theridge(69).JPG.9913b318f
large.09102023theridge(70).JPG.5fc442720
large.09102023theridge(71).JPG.2f0cb59af
large.09102023theridge(72).JPG.873bc4d80
large.09102023theridge(73).JPG.8607ae060
large.09102023theridge(74).JPG.009372c7d
That Escort in the weeds had a Kamm tail and a matching Kamm front - if there is such a thing!
large.09102023theridge(75).JPG.56198acb5
