RatVonDude Posted March 7, 2015 Report Share Posted March 7, 2015 Late to the party, I know. But I call bullshit. There are to sides to Washington. The wet side and the dry side. Colored people on the West-that's moss. Colored people to the East of the mountains-Mexicans. Whitey's don't tan out here. Too much dust in the air to stay outside. I hate the wind. you forgot about the Laplanders, the hidden bubble on the scan tron that nobody ever checks. btw spray tanning is done indoors, but I can see how dust could contaminate the carrot juice Link to comment
laotsu Posted March 7, 2015 Author Report Share Posted March 7, 2015 btw spray tanning is done indoors, but I can see how dust could contaminate the carrot juice or out, the tents and spray guns are portable Link to comment
Dolomite Posted March 7, 2015 Report Share Posted March 7, 2015 Can I use yours then? I just about collapsed a fuckin lung on that one, scared the dog sleeping by my feet half to death and woke up the baby. 1 Link to comment
datzenmike Posted March 7, 2015 Report Share Posted March 7, 2015 Thanks, stalled on the launch pad.... ONE! ...... Link to comment
505plus5 Posted March 7, 2015 Report Share Posted March 7, 2015 Wait! Bird flying by! Link to comment
captaingamez Posted March 7, 2015 Report Share Posted March 7, 2015 This became This, took aboot a 1 1/2 hrs Picked up a bit ago, brought it back to life, Its going beside the g-9700 Go big how much did you get it for? I got mine about 6 months ago for freakin $10, I still cant believe it. 1 Link to comment
datzenmike Posted March 7, 2015 Report Share Posted March 7, 2015 Some moron painted it BLACK???!!!!!! Sacrilege!!! DOOFUS, Link to comment
RatVonDude Posted March 7, 2015 Report Share Posted March 7, 2015 Some moron painted it BLACK???!!!!!! Sacrilege!!! DOOFUS, well they coulda put 16 by 9 inch rims on it.... Link to comment
laotsu Posted March 8, 2015 Author Report Share Posted March 8, 2015 I liked it better black Link to comment
laotsu Posted March 8, 2015 Author Report Share Posted March 8, 2015 so this happened today any suggestions on how to get it re-seated? any opinions on the wear on the cam? Should be ok right? Link to comment
laotsu Posted March 8, 2015 Author Report Share Posted March 8, 2015 I just discovered these guys hard hitting beats! Link to comment
laotsu Posted March 8, 2015 Author Report Share Posted March 8, 2015 you can blame this guy Link to comment
laotsu Posted March 8, 2015 Author Report Share Posted March 8, 2015 just in case you philistines whinge aboot no Datsun Link to comment
MicroMachinery Posted March 8, 2015 Report Share Posted March 8, 2015 so this happened today any suggestions on how to get it re-seated? any opinions on the wear on the cam? Should be ok right? Ah, finally some pics in your build thread.. To re seat it, just loosen the adjusting nut on the opposite side until you can wiggle the rocker arm with your fingers. Turn the crank until the cam lobe is pointing straight up(to give you more clearance). When you have enough clearance, via the adjustment nut, simply lift the rocker arm off, turn the little pad 90 degrees and sit it back in. Now's a good time to check/adjust the rest of your valves as well. As long as you don't see any big gouges on the cam, it should be OK. Link to comment
laotsu Posted March 8, 2015 Author Report Share Posted March 8, 2015 Ah, finally some pics in your build thread.. To re seat it, just loosen the adjusting nut on the opposite side until you can wiggle the rocker arm with your fingers. Turn the crank until the cam lobe is pointing straight up(to give you more clearance). When you have enough clearance, via the adjustment nut, simply lift the rocker arm off, turn the little pad 90 degrees and sit it back in. Now's a good time to check/adjust the rest of your valves as well. As long as you don't see any big gouges on the cam, it should be OK. nothing on the lobe but the second pic shows a gouge right nest to the tower. I don't think it would be enough to throw the rotating mass off or nothing. Thanks Micro Link to comment
MicroMachinery Posted March 8, 2015 Report Share Posted March 8, 2015 Oh that? ...don't sweat that. 1 Link to comment
datzenmike Posted March 8, 2015 Report Share Posted March 8, 2015 Or get a long screwdriver/pry bar. Slip it under the cam from the spark plug side, (but not on a cam lobe) and lift up on the handle end to pry down on the valve spring retainer to compress it. Slip the rocker back on. Now check ALL valve clearances to prevent this happening again. Link to comment
MicroMachinery Posted March 8, 2015 Report Share Posted March 8, 2015 Or get a long screwdriver/pry bar. Slip it under the cam from the spark plug side, (but not on a cam lobe) and lift up on the handle end to pry down on the valve spring retainer to compress it. Slip the rocker back on. Good way to find yourself in an unpleasant situation. I've both slipped off the spring, giving myself a nice boo-boo as well as ejected the valve retainers this way.. luckily, the valve didn't drop. In a pinch, you can do it this way; just be careful. Link to comment
TENDRIL Posted March 8, 2015 Report Share Posted March 8, 2015 he must have never done a vale adjustment Link to comment
