laotsu Posted September 1, 2014 Author Report Share Posted September 1, 2014 so to be clear, if I put a bottle at the end of my radiator vent hose and use a '78 on rad cap my radiator will refill itself from the runoff when it cools? Link to comment
tr8er Posted September 1, 2014 Report Share Posted September 1, 2014 Unless your two exhaust pipes are fighting each other over multiple confrontations, they're duals, otherwise they're duels. With some of the shit that passes on here, I'm getting called on a vowel... I do try to be a good writer so I accept the correction. You should hear me talk. Tanker and Tiki and Hainz probably have a pretty good idea of how that sounds. Small kine different. Link to comment
tr8er Posted September 1, 2014 Report Share Posted September 1, 2014 Where does one acquire the valve cover vent hose with a flame retardant filter? I've never had an issue, but I'd hate to blow my weber up. Link to comment
datzenmike Posted September 1, 2014 Report Share Posted September 1, 2014 so to be clear, if I put a bottle at the end of my radiator vent hose and use a '78 on rad cap my radiator will refill itself from the runoff when it cools? Yes. The bottle must already be part to half full and the hose submerged. 1 Link to comment
laotsu Posted September 1, 2014 Author Report Share Posted September 1, 2014 Brilliant! Link to comment
nismo24096 Posted September 1, 2014 Report Share Posted September 1, 2014 Just going to leave this here.. I see its like pulling teeth to get stickers so I thought I might just do my own. still need to put the .net on it. 1 Link to comment
VFR800 Posted September 1, 2014 Report Share Posted September 1, 2014 Jennifer Lawrence nude pics are legit as are the Kate Upton ones. :thumbup: Link to comment
hobospyder Posted September 1, 2014 Report Share Posted September 1, 2014 Jennifer Lawrence nude pics are legit as are the Kate Upton ones. :thumbup:wait what? Link to comment
VFR800 Posted September 1, 2014 Report Share Posted September 1, 2014 ^^^^ http://www.reddit.com/r/TheFappening/comments/2f44n0/new_celeb_leaked_pics_all_in_one_place/ Link to comment
datzenmike Posted September 1, 2014 Report Share Posted September 1, 2014 Brilliant! Like the PCV valve and charcoal canister the coolant recovery is so simple in operation I don't know why it wasn't thought of sooner. Every summer the coolant not recovered has to be replaced (usually with water) and come winter, your anti freeze protection is lower and needs to be 'topped up'. The rad cap has the usual tight seal that is only releases when the cap is removed or the rad exceeds the 13 PSI spring to release pressure and coolant out the over-flow hose. In the center of the cap is another one way valve that only opens inward, also connected to the over-flow hose. Everything works the same when engine is hot and system pressurized. Any coolant expelled will cause a void under slight vacuum once the engine cools. The smaller one way valve is sucked open and the over-flow pipe becomes a drinking straw in the coolant recovery bottle. Coolant is sucked in to replace that which was expelled and the rad stays full. Link to comment
VFR800 Posted September 1, 2014 Report Share Posted September 1, 2014 http://www.abc.net.au/news/2014-09-01/chibatman-japans-answer-to-the-dark-knight/5709962 Link to comment
smoke Posted September 1, 2014 Report Share Posted September 1, 2014 ^^^^ http://www.reddit.com/r/TheFappening/comments/2f44n0/new_celeb_leaked_pics_all_in_one_place/ So happy about this. 2 Link to comment
datzenmike Posted September 1, 2014 Report Share Posted September 1, 2014 Give me a huge fucking break. Had to look up those names. Nothing is by accident in Hollywood and no press is bad press. I doubt the 'hacker' had to work hard to get these.... and what idiot would pose for and keep naked pix of themselves anyway??? I don't. They aren't for the most part flattering either. (not mine, I mean them) 1 Link to comment
VFR800 Posted September 1, 2014 Report Share Posted September 1, 2014 Give me a huge fucking break. Had to look up those names. Nothing is by accident in Hollywood and no press is bad press. I doubt the 'hacker' had to work hard to get these.... and what idiot would pose for and keep naked pix of themselves anyway??? I don't. They aren't for the most part flattering either. (not mine, I mean them) Link to comment
smoke Posted September 1, 2014 Report Share Posted September 1, 2014 Too much thought went into that. Naked girl from hunger games, I'm in. 2 Link to comment
flatcat19 Posted September 1, 2014 Report Share Posted September 1, 2014 I'm stoked on those Kaley Cuoco pics. Link to comment
smoke Posted September 1, 2014 Report Share Posted September 1, 2014 Yeah, I would try my best to ruin that. 1 Link to comment
r0p0doe Posted September 1, 2014 Report Share Posted September 1, 2014 So happy about this.You guys broke the fuckin link before I got to check it out, thanks a lot -_- 1 Link to comment
flatcat19 Posted September 1, 2014 Report Share Posted September 1, 2014 Yeah, I would try my best to ruin that. Wouldn't need to try so hard after I'm done with it. Although you may be waiting in line for a while. Link to comment
flatcat19 Posted September 1, 2014 Report Share Posted September 1, 2014 You guys broke the fuckin link before I got to check it out, thanks a lot :sleep: Still works for me. 1 Link to comment
r0p0doe Posted September 1, 2014 Report Share Posted September 1, 2014 That's bullshit Link to comment
flatcat19 Posted September 1, 2014 Report Share Posted September 1, 2014 No. You're bullshit. Or your browser is. Link to comment
r0p0doe Posted September 1, 2014 Report Share Posted September 1, 2014 Chrome isn't working for that link for once. Link to comment
flatcat19 Posted September 1, 2014 Report Share Posted September 1, 2014 I'm on Chrome. Link to comment
