Engine Porn (beyond ... saturation)
  • Replies 4.9k
quad turbo 4 cylinder motors anyone? :P can do it on some of the 720's too :P
Rube Goldburg Performance.^^^
owen developments uk 2006 its 4 500cc turbochargers on a 4 cylinder motor
http://www.owendevelopments.co.uk/article/19/QUAD_TURBO_KIT/
This is the first known quad turbocharger installation ever to be built for a four cylinder engine as a research and development project by Owen Developments.
The project was to evaluate how small the manufacture of a turbocharger would have to be in order to produce sufficient speed not only to achieve atmospheric pressure but additional boost for each of the four cylinders.
This project illustrates the design and manufacturing capabilities of Owen Developments in this highly specialised field and is a good example of where future high performance engines may ultimately end up.
I'm curious what the advantages are of a tiny turbo for each cylinder over one large. The explanation of what they were trying to achieve is very vague. "in order to produce sufficient speed not only to achieve atmospheric pressure but additional boost for each of the four cylinders." If all they're doing is to reduce vacuum at the intake for better fuel economy, this seams like an excessively complex and expensive solution. In fact, the heat sink would make this set up totally counter productive for any performance gain. Just because you can doesn't mean you should.
The British have been guilty of trying too hard to be clever only to wind up making things much more complicated than they need to be. If you've ever worked on a Norton motorcycle engine you know what I'm talking about.
Tah-done
Tah-done
sorry, but the intake on a 4th gen accord isn't even near the center of the hood
If the picture was a 4th generation Accord then Matt was saying it was better than any Nissan made from '90-'93. He didn't say any of the other Japanese makes, just Nissan. I don't agree, but not from knowing for sure, just brand loyalty. Shortly after and certainly by the end of the decade Nissan was in a financial tailspin. The cancellation of the Z car in '96 sent up warnings. Nissan hasn't made or done anything since that was worth a damn. The GTR and the 'new' 350Z are to Nissan what the Corvette is to GM.... a technological super-car, something no one here will ever afford to own or drive.
Now if Matt had said something against a Datsun, well we would have to step outside. The '90-'93 Nissans?.... meh, not so much.
