Engine Porn (beyond ... saturation)
  • Replies 4.9k
Yeah maybe conceptually but having a car that doesn't surprise people it isn't smoking ,, seems like a better idea in real practice.
speaking of awesome concepts i got this one off the celica forums the other day
When a cat is dropped, it always lands on its feet, and when toast is dropped, it always lands with the buttered side facing down. I propose to strap buttered toast to the back of a cat; the two will hover, spinning inches above the ground. With a giant buttered cat array, a high-speed monorail could easily link major metropolitan areas.
That's from a commercial from like 5 years ago......fucking internet kids.....
I might catch some flack for saying this, but running a rotary engine on ethanol solves the main issue of carbon build up on the seal. It also runs cooler than gas with a relative EGT difference of 267 degrees F. There are guys running ethanol without oil injection.
Then why not propane? Seems like that could solve all the problems? Plus make it easier to boost.   B)
3" line right off the tank
 Now I'm having impure thoughts Freak. 3" intake straight off the tank. instant 200 psi boost baby.
I was thinking ceramic composite rotor with graphene shell. Running Hydrogen. Why just hint at a solution.
Was it the username (chevysrule83), or the fact that the LS uses an I-head OHV pushrod design developed by David Dunbar Buick in 1902.
The Oldsmobile's 1949 Rocket V8 has the same valve train as the LS. Materials and manufacturing may be different, but fundamentally it is the same internal cam, pushrod, rocker arm, two valve per cylinder "technology" as the 49 Olds.
The fact is, Chevy isn't using the I-head OHV design because it's the best, they use it because it's cheaper to produce than the superior DOHC 4 valve design.
You've never read the story about the LS development project then. Google it and read it. They clearly had their work cut out for them, but their goal was to convince their test drivers that the pushrod LS was a better "feeling" type of driving experience, as compared to the LT5.
I am not going to argue the merits of a pushrod arrangment, but you have to admit, the LS is a pretty nice engine, in any configuration.
Just to clarify a horse actually produces about 15 HP at peak output.
I doubt this very much. A horse can probably exceed one HP briefly but the HP is based on what a horse can do reliably over at least one hour to get a more accurate measurement. A human can exceed one hp but very briefly and maintain about 1/10 hp.
The L20B is based on 746watts = one hp. By no stretch of the imagination does is 'briefly' make 1,500 hp.
Why the doubt mike? I know how a horse power is measured. I stated that a horse can make about 15hp at PEAK output, which is a very short period of time, but can be done.
People might thing the L20B can make a peak output for a short time. Is it really 15 times as much?
The difference being that a mechanical device cannot increase its power output like a horse. If a horse could produce at peak output all the time then the measurement would be different
Mechanical "horsepower" is equivalent to 745.7 watts of energy output. When mechanical power output was first being measured, horses were the common unit of power of that age. Naturally the horse would be used as the standard unit of measurement. The only issue being, the actual power output of a horse is a totally arbitrary measurement when you consider not all horses are equal.
The first video was very impressive. Serious horsepower! The second one made me feel weak.
