Engine Porn (beyond ... saturation)
  • Replies 4.9k
I may be partial to this but hot-boats have the best engine porn around:
580 C.I. single dominator, plate nitrous system (no longer have this motor in the boat though)
0578def4-5c00-4634-a3de-d3a2d71eb2a8_zps
red boat is also ours, green/black boat is a friends (blown gas w/ carbys)
1073283_10203417429168817_47934960987889
Sonnys Racing Engines 802 C.I (This is a STREET driven PUMP GAS sub 8 sec car)
Gasser Porn:
When you see it  :w00t:
Alfa 1750:
Sundance Datsun powered boat:
Ratty homegrown turbo build:
Up close and personal w/ a NHRA pro stock car:
I got my laughs for the day.
Was it the username (chevysrule83), or the fact that the LS uses an I-head OHV pushrod design developed by David Dunbar Buick in 1902.
The Oldsmobile's 1949 Rocket V8 has the same valve train as the LS. Materials and manufacturing may be different, but fundamentally it is the same internal cam, pushrod, rocker arm, two valve per cylinder "technology" as the 49 Olds.
The fact is, Chevy isn't using the I-head OHV design because it's the best, they use it because it's cheaper to produce than the superior DOHC 4 valve design.
Its also the most reliable platform ever made, there is no question about it, ohc is not "superior", its reliability is not up to par, sure some dohc designs are well designed, and they work, till they blow up, fords dohc problems go back for 2 decades, they cant seem to get it right
The fact is, Chevy isn't using the I-head OHV design because it's the best, they use it because it's cheaper to produce than the superior DOHC 4 valve design.[/size][/font][/color]
And with large displacements it makes plenty of power below 6K.
Ford made all aluminum block and head, 4 valve DOHC engine 70 years ago.
Damnit.
Non it didn't, the measurement of horsepower is the same. Its just that 1 horse=15 horsepowers
Now I need to go to those Chevy forums I was just bragging on.  I thought I had my intel direct from the Horses mouth.
sorry
i hate underpowered antique pushrod engines ,, alot of  "enthusiasts" think that they are still relevant in todays high performance world  but i find no evidence whatsoever to support that way of thinking.
ccrp_1009_01_o%2B8000hp_top_fuel_engine%
  • Like 3
Pfft, only like 8000hp, no big deal
