Bagged and BD 67 V520
finney
I just felt like posting a pic.
This week, we had a baby girl, but i have managed o sneak a little time here and there.
I managed to
degrease wagon gearbox + paint
- Clutch slave totally fucked
- gearbox mount totally fucked
pulled gearbox from the 520 truck
- good clutch cylinder
- good gearbox mount - sitting in a tub of de greaser
Upper control arms on the wagon have rusted out
-pulled control arms from the truck
- also had just replaced the upper spindle bushings in the truck so pulled them out
Control arms are similar but the wagon arms are a slightly different shape. wagon arms are approx 1-.5" wider. Should be ok, just need to check the truck arms do not restrict lift
-arms sitting in a tub of de greaser
Also got another set of callipers - been working on rebuilding a set using the ones i had and these other ones. got most the clips i needed
10649973_10152679414434764_3778373398841
  • Like 6
  • Replies 285
today i fabricated a fastener to hold the battery
10710639_10152713880569764_2243216514422
Cut off a little bit of the driver side door sill
10277889_10152713880654764_7381551712867
Just a little rust….. Wire wheeled and neutralised with Ranex. can see where i spot welded the filler panel for the body drop
10646678_10152713880709764_3451528270402
Did the same with the Passenger side - this side was worse
10580058_10152713880594764_3248812623042
Before the passenger side was wire wheeled it and neatralised
10570417_10152713880774764_9164959733907
Had a massive shed clean up and threw out a couple of trailer loads of junk out of my car port. All in a days work. Love long weekends
10653499_10152713906674764_5363774539994
Also finished de greasing the gearbox mounts and started painting
  • Like 5
Not been able to do too much this weekend, hanging with the wife and the little one. Still working on getting something done each day. Yesterday mounted engine, today gearbox. Need to find a way to change the pulley on the alternator on this one off my Lexus. Fairly sure the stock J13 Alt will not run my accessories . Thoughts?10665102_10152729370429764_5231509069813
  • 1 month later...
Been a little while since I have been able to work on the old girl. Work - which is drinking beer and running a brewery and a now 10 week old little girl.
I marked out the sills on the 520 and started making the first incisions. I then fired up the welder for the first time in a couple of months to find it was shorting out. That put a holt on the first day i planned on working on her. Sunday morning I pulled apart the gun didn't really find any issues but put it back together and now everything is fine. Spent a few hours here and there tacking away.
10305327_10152817433239764_2950305668475
10353702_10152817433144764_1757248380868
10500577_10152817433204764_4290232526275
  • Like 3
  • 1 month later...
I am guessing Facebook has decided to chance something again, loosing all the linked images.
The chassis and the engine in the background - Full chassis build with true cantilever set up and 1uz with IBT's. 27 chev panels
as far as the V520 i have been fighting with it during my spare time for the past few weeks. I have fixed every leak in the air system - managed to have it at 145psi for 7 days. I got my axels back from the machine shop - Been there for 6 months. they were at a different shop for 6 months previous to that. drilled out to 5 stud and shortened one side 20mm.
Started putting the diff back together yesterday and ran into a whole heap of issues. still trying to work them out. will get there in the end, but having some issues with the spines and also somehow got the measurements incorrect. had to space the rims out with some spacers by 8mm to make some space between the chassis.
I guess thats what happens when you try and make custom billet wheels fit a tiny little 6 stud datsun.
  • Like 3
Axels
10426162_10152974462259764_4121636257496
10917257_10152974462224764_5221054201153
The machinist welded up the 6 stud holes as 2 of the holes interfered with the old holes - therefore hardening the steel, he ended up having huge issues drilling out the new holes. no idea why he decided to drill out what looks like a extra lot, i could not be F'ed asking, i just wanted them back.
the axel I shortened 20mm I expected to slip back into the diff centre, however it seems the splines are now to short, another measurement fuck up.
he thought he was making a ten lug?
what's up with the little holes next to the lug holes? look a little close to me but i don't deal with steel on a normal work day so i'm probably wrong
The little holes were for screwing/holding on the drum, they did that early, but quit doing it in the USA about when the 521 came out, maybe during the 520.
those little holes held a dust cover on the back of the axel. with the 5 stud being a smaller pattern, they got tossed in the bin.
because of the machined face on the axels the studs i used stick out a little past the face. drilled out the drums today. The second drum brake is a hell of a lot easier to put back together than the first time you do it. Also did some work on aligning the rear end as well as I possibly can with a tap measure.
10429491_10153006411324764_1232032409769
10858381_10153006411409764_1234403231084
All new Brakes
1495434_10153006411429764_83325175112312
Also picked up these steelies and caps off a mate, they have been sitting in a shed for the past few years since getting powder coated. They are all in great condition - The scuffed looking face is actually surfboard way from my car. I will not being running the billets full time, due to unwanted police attention.
10386268_10153006411354764_2890124466936
  • Like 4
