Bagged and BD 67 V520
finney
  • Replies 285
sadly i got the J13 read to pull from the 520 truck today. The beginning of the end for the old girl
312066_10150389223504764_1770088136_n.jp
Its was a hard decision, I'm in mourining but, for the greater good the days were always up the day for the old girl when i found the V520.
Most parts will be used for the Van
J13
gearbox
New Radiator
both doors
Sills
rad support - single headlight conversion done the right way
Grill - Single headlight
Lower half of both front guards (rest repairs)
Steel Dash
Steering wheel - big old badass datsun original in great condition
One of the front upper control arms
fuel tank
visor
guard mirrors
other misc parts
Then I plan on turning the rear clip and bed into a bagged trailer to tow behind the wagon - project after i finish the wagon
  • 1 month later...
Woooo Did some work yesterday, first time in 4 weeks or so.
Yesterday I welded the underside of the floor and the filler plates. also welded the floor supports to the filler plates. I hate welding in confined space. I am 6'6 and there is not as high as it looks under there. 100 burning embers later i was happy.
10339630_10152385016834764_5632949317159
Folded up and welded in a couple of boxes to clear the exhaust cut outs in the gear box x member. Just incase engine plans on day change the chassis work is done.
1609996_10152385016589764_70487088531283
My Air compressors (see chassis pics) are located in front of the rear wheels and slightly protrude, as well as a small bit of chassis rail after the body drop and making the rear seat work. Folded up a couple of boxes to make some space. The driver side is welded in. the other needs to be welded in the same.
10308314_10152385016714764_3746778915550
j13 Motor is currently at a friends shop - getting re built. Struggling to find some oversize pistons though.
if anyone ever comes across some rubber for the rear windows and the rear windscreen for this bad boy please let me know :) I have a heap of hidden rust repairs behind the sliding window frame, the rubbers that hold the frame in place are in a condition that if i touch them they will without a doubt fall into a million pieces. what a prediciment
  • 3 weeks later...
Thanks.
Felt like doing some painting this weekend. Still a couple of small welding jobs to do to 100% finish, but a change was nice and rather motivating. POR15
10458881_10152467251819764_9729707892899
10453364_10152467251619764_6637798554620
Cant weld up that list filler panel on the back till i see the clearance with the chassis
thanks mate, For one i love coming on here and spotting my thread up top.
the engine builder has come up with something. I have no idea at this stage as to what though. I will let everyone know once i find out what he has done to the little old J13
its a good feeling knowing people enjoy the craziness of your build hey?
for the record.. i dont normally like too many bagged cars ... BUT THIS!!! HOLY FARKBALLS Im Impressed and honoured that its an AUS build!!
keep up the great work man !!
I have been slowly painting my chassis with POR15, goes on damn nice, but much more time consuming than a spraying. I have not done the front yet as i still need to drop the front horns for the Body drop 3" and also do the mounts for the front shocks.
I also finished off all the small bits on the underbody for the body drop, a few little  filler panels were needed. All seam sealed and ready to paint the underbody. again POR15 with a brush, will take a while.
I then have brake lines and fuel lines to do, Never done brake lines before, not looking forward to them, but sure once  dive in they will be easy.
10516743_10152499006409764_5184833711100
  • Like 4
