What I'm working with!
uberkevin
  • Replies 3.2k
H233 axle, clutch type lsd. These can be rebuilt and by adding or subtracting plates, you can change the breakaway torque from the 60 ft/lb range to above 250ft/lbs. Very tunable, but few gear ratio options, and most of then are for crawling/off-road.
There is a decently common 4.3 gear ratio.
I was wrapping her up today, putting water in the radiator making sure fuel lines were tight. Got water up to the the water pump and it started to leak. After taking the pump off I seen the gasket was all fucked up??? Idk! What happened to it. So I picked up a new gasket and goo'd that shit up. So I've gotta wait tell that drys and change my clutch Annnnd bleed it..
Oh. And I've got a reeeaallly low tire.
Got two days off after tomorrow..
  • Like 4
