Draker Posted April 13, 2017 Report Share Posted April 13, 2017 That should do it! 2 Quote Link to comment
uberkevin Posted April 13, 2017 Author Report Share Posted April 13, 2017 Now I'm triple and quadruple checking what wires I'm about to put into the Can-am box. I was a little confused at first, but then realized I just needed to mainly pay attention to what's within the dotted lines. Esay enough.. 2 Quote Link to comment
KoHeartsGPA Posted April 13, 2017 Report Share Posted April 13, 2017 Good job, youngster! :thumbup: 1 Quote Link to comment
uberkevin Posted April 13, 2017 Author Report Share Posted April 13, 2017 Here are most all the wires I need to get from two different plugs on my s13 harness. I still need to get the Orange wire from the ecu end of the harness pin 34 and get a fuel pump wire. 3 Quote Link to comment
uberkevin Posted April 24, 2017 Author Report Share Posted April 24, 2017 url="http://s974.photobucket.com/user/uberkevin/media/20170424_114903.jpg.html"][/url] I wanted to have the fuel pump wire solo. So that still needs to go to FP1 on the can-am box. I'm pretty sure all the wires are where they should be. Any of you disagree? I've only had a few moments this week to do anything in the garage. Each time I'm out there I get so much closer. Just another step down. Off to work. 3 Quote Link to comment
Goldfish101 Posted April 24, 2017 Report Share Posted April 24, 2017 From memory that looks right, you need took hook up power and ground to the can am box and need ignition power on the key power slot 3 Quote Link to comment
uberkevin Posted April 24, 2017 Author Report Share Posted April 24, 2017 Forgot a picture. 3 Quote Link to comment
]2eDeYe Posted April 27, 2017 Report Share Posted April 27, 2017 Nice setup you got going on there 1 Quote Link to comment
uberkevin Posted May 1, 2017 Author Report Share Posted May 1, 2017 Finally got the DE started. 5 Quote Link to comment
KoHeartsGPA Posted May 1, 2017 Report Share Posted May 1, 2017 Congratulations, sounds great!!! 2 Quote Link to comment
Draker Posted May 1, 2017 Report Share Posted May 1, 2017 Wow.. nice work man! 1 Quote Link to comment
mrbigtanker Posted May 2, 2017 Report Share Posted May 2, 2017 Very nice. now it will look better mounted in something. 2 Quote Link to comment
uberkevin Posted May 2, 2017 Author Report Share Posted May 2, 2017 Lucky I have today free after a dentist appointment. I've gotta get the Automatic pilot bearing out of the end of the crank to replace it with the manual pilot bearing.. the puller I have isn't working unless I shapen the teeth. So I'll either do that or cut it out if need be. 1 Quote Link to comment
Crashtd420 Posted May 2, 2017 Report Share Posted May 2, 2017 Do you have a tap that might fit the hole?.. I read somewhere to run a tap into the bushing and maybe weld a nut on the end to adapt to a slide hammer.... 1 Quote Link to comment
]2eDeYe Posted May 2, 2017 Report Share Posted May 2, 2017 Get a bar of soap or some bread and a dowel or some type of rod that slip fits right into the bushing. Pack the soap/bread into the bushing and use the dowel to pack the stuff in there. Keep packing and pushing, use a hammer to drive the dowel in when necessary. The bushing will start to come out. Keep packing until it is out..Clean up the soap or bread mess and press in the new bushing. More entertaining and definitey more messy version. :lol: 3 Quote Link to comment
Crashtd420 Posted May 2, 2017 Report Share Posted May 2, 2017 I almost wish I had something to try that on.... interesting idea... the theory sounds good... 1 Quote Link to comment
flatcat19 Posted May 2, 2017 Report Share Posted May 2, 2017 Cut it with a screwdriver. 2 Quote Link to comment
]2eDeYe Posted May 2, 2017 Report Share Posted May 2, 2017 Soap is cleaner :rofl: 2 Quote Link to comment
hobospyder Posted May 2, 2017 Report Share Posted May 2, 2017 I watched redeyes way done with grease and a socket. 1 Quote Link to comment
uberkevin Posted May 2, 2017 Author Report Share Posted May 2, 2017 No need for that awesome technique. To bad really. I made the tool I had work. 3 Quote Link to comment
uberkevin Posted May 2, 2017 Author Report Share Posted May 2, 2017 Also took the flywheel to get resurfaced. 3 Quote Link to comment
flatcat19 Posted May 3, 2017 Report Share Posted May 3, 2017 How much did that run? Who did it? 1 Quote Link to comment
