uberkevin Posted April 30, 2022 Author Report Share Posted April 30, 2022 My guess is, it was dropped into the tank. Nothing like that on the diagram. Doesn't matter all that much anyway. Quote Link to comment
uberkevin Posted April 30, 2022 Author Report Share Posted April 30, 2022 32 minutes ago, uberkevin said: Looks car/engine related however. Quote Link to comment
datzenmike Posted April 30, 2022 Report Share Posted April 30, 2022 Some threaded carburetor throttle shafts have two flat spots that are like that. Where ya been? Quote Link to comment
uberkevin Posted April 30, 2022 Author Report Share Posted April 30, 2022 Been around, just be working and saving. Lots of life happening around here, chickens, garden, new to me 1st gen 4runner was gifted to me from my wifes uncle. It been in the family since 89 or so. Bought a new Subaru Crosstrek 2021, about 7 grand left on that. Still living with the in laws so that's... nice.. its not bad.. Still at costco. Just been living life. Still have the 521. Been sitting there. Think I stopped driving it 2 years ago after a few belts got torn to bits. A few to many small problems while driving made me park her. Pulls a ton to the left. Drive side wheel Still pokes out an inch more the the passenger.. Torsion rods I found never had the C clips holding them in.. that's scary. Don't think they were ever put in right to begin with, I do know they weren't in for years.. before I bought the truck... years ago. So I've been slowly taking everything apart and slowly really slowly doing small things to her.. 50 year old truck needs more love. I still don't have a shop or garage to do much work in so really only do things in the summer weather.. I miss driving it so much tho! Quote Link to comment
uberkevin Posted April 30, 2022 Author Report Share Posted April 30, 2022 Ka24de still in there.. need new 521 rubber mounts.. idk where I'll get them.. I'm going to be adding a fpr in the future. Need to make sure the tps is in spec, need to make sure I have a working maf.. cold air intake had some leaks that I had to take care of.. Problem I haven't found a solution to is a new throttle cable. I made one myslef.. but I suck!!. and I kept having fix and adjust all the time! Ya know heavy footed Kevin... I've been leaning to slow down everything I do. Been listening to alot of books to help my mind. Real books. Not Harry Potter. Quote Link to comment
uberkevin Posted April 30, 2022 Author Report Share Posted April 30, 2022 Just a few I've listened to. I've listened to most several times! Listing to them helps me understand them a bit better then reading them. Quote Link to comment
uberkevin Posted April 30, 2022 Author Report Share Posted April 30, 2022 Also! Been debating a frame swap.. Haven't gathered all the info needed Been meaning to look into that. 720 frame is the easiest way to go if I'm not mistaken just need to dig a little deeper into what needs to be done. Wayno where ya at!? Haha 😄 Quote Link to comment
]2eDeYe Posted May 9, 2022 Report Share Posted May 9, 2022 On 4/30/2022 at 1:04 PM, uberkevin said: Ka24de still in there.. need new 521 rubber mounts.. Get the 620 mounts, they are a better design. Quote Link to comment
uberkevin Posted November 13, 2022 Author Report Share Posted November 13, 2022 4 Quote Link to comment
uberkevin Posted November 13, 2022 Author Report Share Posted November 13, 2022 Got another.. a little cleaner. 70' A few oddball things done. Picked it up from Spokane but I guess it was a Montana truck. L20b, was told it was out of a 75' Still has single points. Looks like stock carb, so stock crap exhaust manifold that the carb sits on top of. Base of carb is definitely leaking. P.o told me it was having some type of fuel problem and was running bit rough. And it was. I picked this up running, started in 25° snowy weather with just a few pumps, drove it on and off the trailer four separate times along with about two blocks of driving. Parked it. Ran a few errands came back.. no start. Turns over strong however.. Spark plugs were pretty dirty.. after cleaning still no spark.. that I seen.. Think my M.m to coil was reading almost 5 volts. Not sure what's up yet. Haven't touched it much yet. Put to Tdc and pulled the dizzy. Got a pertronix on the way.. mostly because I don't wanna deal with points at all.. Thought I'd share the new to me Datsun. I might start another page I'm not sure yet. I guess the only question I have is do I wire the pertronix two wires to the coil directly or to the coil resistor. I'll post more photos in the sunlight. Been working a ton.. ya know Costco.. it's the season.. 2 Quote Link to comment
]2eDeYe Posted November 13, 2022 Report Share Posted November 13, 2022 Wow, very nice truck. Good to see you with another one. I think the petronix does away with the resistor, but I would check that to be sure. Quote Link to comment
uberkevin Posted November 13, 2022 Author Report Share Posted November 13, 2022 5 minutes ago, ]2eDeYe said: Wow, very nice truck. Good to see you with another one. I think the petronix does away with the resistor, but I would check that to be sure. The little amount I looked into it so far I think I keep it. But like you said I'll check that better to be sure. It's alot nicer then my other one. 😆 But it has its flaws forsure. Pretty rust free but the rust it has is in odd spots. The l20b was installed uhh... very different and something I've never seen. Definitely not a stock 521 4speed. Custom transmission mount. Exhaust ran kinda odd. Little things I'll be getting pictures of. 1 Quote Link to comment
datzenmike Posted November 13, 2022 Report Share Posted November 13, 2022 I imagine if it was a dogleg 5 speed you would have said so. That leaves a 71B which would need a modified 521 mount. The '75-'77 car and truck L20Bs were the terrible co-joined intake/exhaust manifold. Maybe it has car or 620 mounts that were on it. Geeez... pictures!!! Quote Link to comment
uberkevin Posted November 13, 2022 Author Report Share Posted November 13, 2022 37 minutes ago, datzenmike said: Geeez... pictures!!! 😆 😂 I know.. I know.. but lately it been dark when I go to work and when I get home. Big photo dump most likely tomorrow if all works at like it should. Quote Link to comment
uberkevin Posted November 13, 2022 Author Report Share Posted November 13, 2022 Definitely not a dogleg. Quote Link to comment
uberkevin Posted November 13, 2022 Author Report Share Posted November 13, 2022 1 Quote Link to comment
]2eDeYe Posted November 13, 2022 Report Share Posted November 13, 2022 There ya go. 🙂 Quote Link to comment
uberkevin Posted November 13, 2022 Author Report Share Posted November 13, 2022 That should do the trick.. Back in 09' Good'ol Ratsun. 1 Quote Link to comment
thisismatt Posted November 13, 2022 Report Share Posted November 13, 2022 Nice truck 1 Quote Link to comment
mainer311 Posted November 14, 2022 Report Share Posted November 14, 2022 Wow, that thing is so nice! Quote Link to comment
uberkevin Posted November 15, 2022 Author Report Share Posted November 15, 2022 https://photos.app.goo.gl/UKqApRAzGAXuvAgP6 Test. Quote Link to comment
uberkevin Posted November 15, 2022 Author Report Share Posted November 15, 2022 https://photos.app.goo.gl/aTm7uPPni1hBqXFX9 Not working like I want. Not sure howni was able to upload the first photo of the truck on the trailer. Uploading seems harder now.. wtf. Quote Link to comment
uberkevin Posted November 15, 2022 Author Report Share Posted November 15, 2022 (edited) I guess I'm older so it's clearly harder. Edited November 15, 2022 by uberkevin 1 1 Quote Link to comment
uberkevin Posted November 15, 2022 Author Report Share Posted November 15, 2022 (edited) Edited November 15, 2022 by uberkevin 1 Quote Link to comment
uberkevin Posted November 15, 2022 Author Report Share Posted November 15, 2022 1 Quote Link to comment
