uberkevin Posted November 24, 2022 Author Report Share Posted November 24, 2022 1 minute ago, Crashtd420 said: That mod has been done before... But that's not a bad price for the neccessary machining... Not bad at 125$ no bit shipping the transmission stuff might be a little spendy. Would be nice. Quote Link to comment
Crashtd420 Posted November 24, 2022 Report Share Posted November 24, 2022 Probably overkill but check this out... http://hokeperformance.squarespace.com/l-series-350z-6-speed-adapter Quote Link to comment
Crashtd420 Posted November 24, 2022 Report Share Posted November 24, 2022 Just now, uberkevin said: Not bad at 125$ no bit shipping the transmission stuff might be a little spendy. Would be nice. Just the front case with no guts isn't too bad on weight... it's just aluminum.... I have a front case I can get a weight and box measurements if you like, to give you an idea on shipping... it's not the L pattern, I did the bellhousing swap, this is the one I removed.... 1 Quote Link to comment
uberkevin Posted November 24, 2022 Author Report Share Posted November 24, 2022 15 minutes ago, Crashtd420 said: Just the front case with no guts isn't too bad on weight... it's just aluminum.... I have a front case I can get a weight and box measurements if you like, to give you an idea on shipping... it's not the L pattern, I did the bellhousing swap, this is the one I removed.... True just the front case wouldn't be to bad. No need for getting the weight. Haven't seen a ka 5 for a while. Not that I've been looking but still. 19 minutes ago, Crashtd420 said: Probably overkill but check this out... http://hokeperformance.squarespace.com/l-series-350z-6-speed-adapter This is awesome! Also fun A bit much forsure. Idk if that transmission would fit in the transmission tunnel in the 521. Well. It could be made to fit.. but I don't wanna do that. Hope to get a 720 5peed and swap a old L transmissions front case I have onto it. Again. This l20b in this truck although I didn't drive it much, was eating a ton of gas. The valves are the nastiest I've seen. Almost looks wet caked on black carbon build up. Smell gas in oil. Imagine. Paint stripper looking black carbon. Can't tell but. I didn't spray anything it was like that when I took the manifold off around all 4 intake holes just kinda wet with gas. Kinda sketchy. Quote Link to comment
datzenmike Posted November 24, 2022 Report Share Posted November 24, 2022 56 minutes ago, Crashtd420 said: That mod has been done before... But that's not a bad price for the neccessary machining... I wanted the L case done for the larger 62mm counter bearing. No one near me would even look at it. Pussies. Quote Link to comment
]2eDeYe Posted November 24, 2022 Report Share Posted November 24, 2022 3 hours ago, uberkevin said: If there are two 720 5 speeds near me I'll grab it for you if you really want. I'll keep you posted. I'm going back to the yard when I can to also look into what transmission this 74 710 wagon has. But also!! Have you seen this? https://www.godzillaraceworks.com/drivetrainfs5w71c/l-series-bellhousing-for-240sx-5-speed-swap That's cool but I don't have a 5-speed 🙂 Quote Link to comment
datzenmike Posted November 24, 2022 Report Share Posted November 24, 2022 31 minutes ago, uberkevin said: True just the front case wouldn't be to bad. No need for getting the weight. Haven't seen a ka 5 for a while. Not that I've been looking but still. Idk if that transmission would fit in the transmission tunnel in the 521. The 71C was used on more than the KA engines. There are a lot out there that just need an L series front case. The '84-'86 300zx non turbo The '87-'89 Z24 and '90 and on 2wd KA-E and DE in the D21 and the 2000 and on Xterra The '86-'88 S12 200sx The 71B will fit the 521, many have done it. Probably a real oil burner with lots of blue smoke blow by. Goes out the valve cover hose and right down the carburetor. Take a look at the insides of the carburetor.... bet it looks just as dirty. Quote Link to comment
uberkevin Posted November 24, 2022 Author Report Share Posted November 24, 2022 11 hours ago, datzenmike said: The 71C was used on more than the KA engines. There are a lot out there that just need an L series front case. The '84-'86 300zx non turbo The '87-'89 Z24 and '90 and on 2wd KA-E and DE in the D21 and the 2000 and on Xterra The '86-'88 S12 200sx The 71B will fit the 521, many have done it. Probably a real oil burner with lots of blue smoke blow by. Goes out the valve cover hose and right down the carburetor. Take a look at the insides of the carburetor.... bet it looks just as dirty. The sort time I drove it she definitely was blowing lots smoke.. I didn't think anything of it because it was 25 degrees outside. Yo Mike there's a 79 280sx I believe right across from this 710 wagon I was talking about. What trans does that have? Quote Link to comment
datzenmike Posted November 24, 2022 Report Share Posted November 24, 2022 That would be the 71B 4 or 5 speed or a 3N71B automatic. The 5 speed was still an option in '79 but standard equipment in '80. It would be a Mid range and I had one. If it still has the struts GRAB THEM!!!!!!!! They have huge calipers and vented rotors and are shorter to begin with if lowering. Someone will buy them for their Datsun car... 1 1 Quote Link to comment
uberkevin Posted November 24, 2022 Author Report Share Posted November 24, 2022 3 hours ago, datzenmike said: That would be the 71B 4 or 5 speed or a 3N71B automatic. The 5 speed was still an option in '79 but standard equipment in '80. It would be a Mid range and I had one. If it still has the struts GRAB THEM!!!!!!!! They have huge calipers and vented rotors and are shorter to begin with if lowering. Someone will buy them for their Datsun car... I believe they are there. I'll see what type of price they're asking. Quote Link to comment
datzenmike Posted November 25, 2022 Report Share Posted November 25, 2022 Your 521's 4 speed will have a wide ratio so not much advantage going to the 71B 4 speed but once converted, shortened driveshaft, transmission mount and driveshaft spline if you later get a 5 speed it drops right in. Quote Link to comment
uberkevin Posted November 25, 2022 Author Report Share Posted November 25, 2022 Little dash work needs to be done. So I puller it. Need to do something about this big hole. Cut back a little more then normal. 1 Quote Link to comment
uberkevin Posted November 25, 2022 Author Report Share Posted November 25, 2022 Oics Just cuz. 2 Quote Link to comment
uberkevin Posted November 25, 2022 Author Report Share Posted November 25, 2022 On 11/22/2022 at 4:38 PM, banzai510(hainz) said: I hope the L16 dist is a single point. most were 68-69 model year only.. Nothing ever goes as planned. Quote Link to comment
Stoffregen Motorsports Posted November 26, 2022 Report Share Posted November 26, 2022 What's under the padding on a 521 dash? Is it a full length metal plate? If so, chip off all the old foam and make your own foam pad. I think doing this would be a lot less hassle then trying to repair all the cracks, and a lot less prone to failure when done. Repairing cracks can lead to them opening back up. If you're going to have the dash covered with upholstery, the cracks can be seen under the fabric. I wonder if basic spray foam would be good enough. Or would a softer upholstery foam be better? This website has a lot of different types of upholstery foam - https://www.yourautotrim.com/foscplch.html Quote Link to comment
datzenmike Posted November 26, 2022 Report Share Posted November 26, 2022 Shag carpet will fix that. You almost need a textured mold made of the pad. Spray with Pam, coat with a liquid vinyl, pour in some expanding foam. Upside down cake. 1 Quote Link to comment
uberkevin Posted November 26, 2022 Author Report Share Posted November 26, 2022 (edited) 😀 Edited November 26, 2022 by uberkevin Quote Link to comment
uberkevin Posted November 26, 2022 Author Report Share Posted November 26, 2022 On 2/24/2013 at 3:46 PM, uberkevin said: So i've been doing a little work on MasterChief not as much as id like but still Here's a dashboard if been working on for a week or so, now that i don't have a job I don't mind sanding a shit ton. The filler im using is just a padded dash filler i got off line. sanding...sanding.. sanding. http://i46.photobucket.com/albums/f126/love2scream/DSC_0041_zpsa0efbc67.jpg Under it as you can see is my tailgate that i'm also sanding down. I want to get all the ugly little dings in it out and get it looking great again. heres the tailgate now.http://i46.photobucket.com/albums/f126/love2scream/DSC_0047_zps9ff8044e.jpg Also got a powder coating gun from eastwood.com. I was pretty stoked to finally power coat something so I picked and old heater cover i had. Its baking as i type so you'll see how the first coat is. here a tease... http://i46.photobucket.com/albums/f126/love2scream/DSC_0049_zps95619e6f.jpg Quote Link to comment
uberkevin Posted November 26, 2022 Author Report Share Posted November 26, 2022 (edited) Didn't work like I wanted. I'll be doing the same thing to the dash as I did to my other one. Picture on first page. Sued top. Did the same for Flatcat as well. Dash pad filler. Or basically bondo.. Sand sand sand. Edited November 26, 2022 by uberkevin 1 Quote Link to comment
uberkevin Posted November 26, 2022 Author Report Share Posted November 26, 2022 Got it! Like this 2 Quote Link to comment
uberkevin Posted November 26, 2022 Author Report Share Posted November 26, 2022 (edited) Like so. Edited November 26, 2022 by uberkevin 2 Quote Link to comment
uberkevin Posted November 26, 2022 Author Report Share Posted November 26, 2022 4 hours ago, Stoffregen Motorsports said: What's under the padding on a 521 dash? Is it a full length metal plate? If so, chip off all the old foam and make your own foam pad. I think doing this would be a lot less hassle then trying to repair all the cracks, and a lot less prone to failure when done. Repairing cracks can lead to them opening back up. If you're going to have the dash covered with upholstery, the cracks can be seen under the fabric. I wonder if basic spray foam would be good enough. Or would a softer upholstery foam be better? This website has a lot of different types of upholstery foam - https://www.yourautotrim.com/foscplch.html Thanks for the advice tho. I was thinking about maybe using some spray foam in the cracks, cut them down fill in with a little bondo type filler again 🤔 Idk yet. 1 Quote Link to comment
]2eDeYe Posted November 27, 2022 Report Share Posted November 27, 2022 On 11/23/2022 at 4:49 PM, uberkevin said: If there are two 720 5 speeds near me I'll grab it for you if you really want. I'll keep you posted. I'm going back to the yard when I can to also look into what transmission this 74 710 wagon has. But also!! Have you seen this? https://www.godzillaraceworks.com/drivetrainfs5w71c/l-series-bellhousing-for-240sx-5-speed-swap I am now in the market for 2 transmissions... Just destroyed the one you sold me years ago playing in the snow yesterday 🙂 Dash is looking sweet. 1 1 Quote Link to comment
Stoffregen Motorsports Posted November 27, 2022 Report Share Posted November 27, 2022 17 hours ago, uberkevin said: Thanks for the advice tho. I was thinking about maybe using some spray foam in the cracks, cut them down fill in with a little bondo type filler again 🤔 Idk yet. Expansion rate. It needs to expand at the same rate as the original material. I think regular Bondo would be too inflexible. Quote Link to comment
