Need Help... new to the scene
Dat-girl
Just run a small spacer to run those other wheels, looks like 3-5MM should do.
Red Blazer wheels 195/50/15s, Baby Moon caps and White Walls on that 521 would look UHMAYZING.
..... or...... I may be able to aid in importing some of those crazy Japanese wheels.... or.... build a custom set of wheels? :)
  • Replies 135
'70 through '73 240z wheel. The '74 model year 260z used the same wheel but had a Z in the center. I like it, dressy and comfortable. I have zx wheels in both my 710s because of this.
The wheel is definitely not a 70-73 wheel. They only used the phenolic resin wheel, some had the indents cut out, some just had the indents on the spokes. The 280z used the wrapped/foam wheel. Not sure what the 260 used. The center cap on the 280z steering wheel would twist off instead of pop off as on the 240z steering wheel.
Oh yeah, truck look better with the wheel covers off.
How about making the lowering block a tad shorter? instead of 3" switch to 2 1/2" that would cure the rub and you could use the other rims you wanted.
I don't want to switch them. I am going to be slamming it more so that will not help me any.
looks like a 74 260 they had foam and I think they said datsun then switched to z
70 to 73 smaller center cap push on that said datsun also only the wood wheels as far as I know
70 to 73 wheels and smaller push on center cap th_photobucket-33288-1345402791239.jpg?t=1345402792photobucket-33288-1345402791239.jpg?t=1345402792
off a 74 260 I parted out photobucket-33900-1345402772455.jpg?t=1345402773
on a 75 I picked upphotobucket-26323-1345402689841.jpg?t=1345402691
on another 75 havent located the horn button in the stash of parts but looks like a push on horn which would be early style
but I think solid indents and foam 74-75 not sure after that
early inside horn buttonphotobucket-29820-1345416893033.jpg?t=1345416894
late inside horn buttonphotobucket-1951-1345416877034.jpg?t=1345416878
I stand totally corrected. Was looking on the wrong page of illustrations. Def. not the early Z car but '73 or later
I was surprised to find an error in your post that never happens so I thought I would inform you but you already knew you just looked at the wrong page blah blah blah datsun
thanks for all your knowledge mike you are always helpful
Randy
Truck looks wicked.
Love the red/grey combo.
I'd rock the shit outta that. Then I would go drive it.
It will not be grey for too long hopefully. I don't like that the bed and cab are two diff colors and they fact that it is a spray can paint job
turn the torsion bar square nut out(release the jam nut) and dial it down.
back looks good also already so you have room(travel) to haul stuff
grease up the drive shaft grease nipple and the kingpins up front. Most people dont do this
We plan on lowering it more in the front and the rear. I can go about 1inch all the way around so thats what I am going to do. Thanks for the info on greasing things.
