The silver bullet
vents in and painted black, watch out they break very ez. Did actually break one, but had a few layin around
rear window installed with new rubber and chrome :)
I'm hoping this will be our next drivable Datsun
Yep we have 20+ Datsuns in the yard but no drivers WTF
  • Replies 173
More fun times
Lesson for the day RUST
Here is the hood but it's been sitting and people love touching shinny metal. Check out this pics, finger prints
No need to resand, but metal prep works great. Metal prep leaves a coating on the metal to protect it from rust. If I do not use metal prep the metal would rust under the clear
Now how pretty
Rust is gone.
Vic stripped the apron and it looks great, We hammered it straight, and also metal prepped it
Decided to rust a pattern in this hood
I sanded the metal prep off the areas I want to rust.
Then clear
I'm still unsure how fast it will rust under the clear, but we will see
  • Like 5
More fun times
Now how pretty
Rust is gone.
Then clear
this is a very cool option I cant wait to see how it turns out
Oh yea it looks great too good work guys and gal
Hood shocks
Hooking up steering parts, The boots were jacked, but the tie rods were tight so we found 3 oem boots and 1 urethane boot.
Cleaned it all up ran a tube of grease through the tie rods before installing new booties, and bango :)
And the reversed center link
I am totally digging this build/concept. Although after all the "aftermarket additions" you found in the 59' you're probably a little let down when you open a hood/trunk/glove box and find some of the marijawhatsits! Lol
Can I asked where you sourced the hood struts and how easy they are to install?
Look up like a 2003 Grand Cherokee. Short struts, and then you just need to get the ball studs. Easy. Though mount in same place as James else you will have clearance issues.
There ez to mount, I think I pulled these from the trunk of a newer Audi. Unfortunately I did not have ball studs like I put on Rusty Bird
but a drill and some bolt work just find. The shocks from a BMW trunk work great too.
