Z chopper Posted December 2, 2014 Report Share Posted December 2, 2014 a couple years ago wasn't there an engine swap at Canby? 1 Quote Link to comment
MicroMachinery Posted December 2, 2014 Report Share Posted December 2, 2014 Yesh 1 Quote Link to comment
hobospyder Posted December 2, 2014 Report Share Posted December 2, 2014 Last year had a tranny swap 1 Quote Link to comment
shacks510 Posted December 2, 2014 Report Share Posted December 2, 2014 I better start saving. I'm so down to go. 2 Quote Link to comment
Busta Nut Posted December 2, 2014 Author Report Share Posted December 2, 2014 I better start saving. I'm so down to go. That's the spirit!!! :thumbup: :thumbup: :thumbup: Quote Link to comment
Ranman72 Posted December 3, 2014 Report Share Posted December 3, 2014 I want to go to canby so bad. I'm just worried about a 900 mile drive each way. I need more power before then so I can keep up. my wife did it in a stock 1200 coupe a whopping 62 hp with 370 gears instead of 390 pulled 70 on most hills all the way there 2 Quote Link to comment
shacks510 Posted December 3, 2014 Report Share Posted December 3, 2014 my wife did it in a stock 1200 coupe a whopping 62 hp with 370 gears instead of 390 pulled 70 on most hills all the way there My 510 that currently has an L16, 5 speed, 3:90 rear end, and my rear tires 2" taller than stock (might as well have 3:70), then It'd help with mileage a bit. I can cruise 70-75 no problem. If I use 15mpg as my base accounting for different grades, stop and go traffic, etc., it'd cost around $400 JUST for gas. That's an expensive week. I better get a real job. Quote Link to comment
datsunfreak Posted December 3, 2014 Report Share Posted December 3, 2014 My 510 that currently has an L16, 5 speed, 3:90 rear end, and my rear tires 2" taller than stock (might as well have 3:70), then It'd help with mileage a bit. I can cruise 70-75 no problem. FWIW, all of my L16 cars got better MPG at 4000rpm than they did at 3000rpm. Quote Link to comment
shacks510 Posted December 3, 2014 Report Share Posted December 3, 2014 FWIW, all of my L16 cars got better MPG at 4000rpm than they did at 3000rpm. That may be true, but with my shitty 6.71:1 compression and over jetted Mikunis, my mileage isn't that great. I'm wasting a lot more gas because it's not all being burnt with low compression. I wish I had another usable head, or just had the money to get my L20 back together. At least that same amount of gas being used will have some power behind it. Quote Link to comment
datsunfreak Posted December 3, 2014 Report Share Posted December 3, 2014 That may be true, but with my shitty 6.71:1 compression Wow... :blush: Quote Link to comment
Ranman72 Posted December 3, 2014 Report Share Posted December 3, 2014 ouch on fuel my L16 worn out with downdraft weber got 20 to 24 no matter how I drove it my L20 duel webers gets 15 to 18 1 Quote Link to comment
shacks510 Posted December 3, 2014 Report Share Posted December 3, 2014 Wow... :blush: U67 with dish pistons. Closed chamber W53 that was on there is cracked, and this U67 was the only thing I had that I could use. I'm done with the thread jacking. Sorry Busta. 1 Quote Link to comment
edekalil Posted December 3, 2014 Report Share Posted December 3, 2014 Busta, Glad to see you got a motor up and running in your car. 1 Quote Link to comment
Busta Nut Posted December 3, 2014 Author Report Share Posted December 3, 2014 U67 with dish pistons. Closed chamber W53 that was on there is cracked, and this U67 was the only thing I had that I could use. I'm done with the thread jacking. Sorry Busta. Don't trip man.....I enjoy the convo....... Quote Link to comment
Busta Nut Posted December 3, 2014 Author Report Share Posted December 3, 2014 Busta, Glad to see you got a motor up and running in your car. Running.....clutch adjusted(I hope).....carbs synced..for the most part..... ........off for exhaust tomorrow..... Possibly more tuning tomorrow night........ Then the break in :thumbup: .........oh god!!!!......she sounds so beastly!!! :hyper: .........where's the vid dude?? Quote Link to comment
skyblue Posted December 3, 2014 Report Share Posted December 3, 2014 Running.....clutch adjusted(I hope).....carbs synced..for the most part..... ........off for exhaust tomorrow..... Possibly more tuning tomorrow night........ Then the break in :thumbup: .........oh god!!!!......she sounds so beastly!!! :hyper: .........where's the vid dude?? Oh yea. Lol. Here it is. 3 Quote Link to comment
edekalil Posted December 3, 2014 Report Share Posted December 3, 2014 Then the break in :thumbup: .........oh god!!!!......she sounds so beastly!!! :hyper: .........where's the vid dude?? Can't wate to see the video. Quote Link to comment
Busta Nut Posted December 3, 2014 Author Report Share Posted December 3, 2014 On her way for exhaust..... 1 Quote Link to comment
r0p0doe Posted December 3, 2014 Report Share Posted December 3, 2014 On her way for exhaust..... I was about to say man, you just fixed it 1 Quote Link to comment
Busta Nut Posted December 4, 2014 Author Report Share Posted December 4, 2014 So.... On my way back from the exhaust shop yesterday I slowly started to lose oil pressure..... ......by the time I was a mile from the shop my chain was rattling upon accel.......yikes........ Made it back and let it cool......started it back up again and pressure was right back up....... 25psi @ idle.... 55ish....revved..... Haven't had time to do much since..... .........ordered 2 more oil pumps......they came today...... .....1 KA oil pump....identical replacement.... .....1 OE L20 oil pump..... Oil filter will get replaced as well...... 1 Quote Link to comment
mrbigtanker Posted December 5, 2014 Report Share Posted December 5, 2014 your on it Antony,good job, duct tape the snap on pressure gauge to the window. right on :thumbup: 1 Quote Link to comment
Busta Nut Posted December 5, 2014 Author Report Share Posted December 5, 2014 your on it Antony,good job, blue tape the snap on pressure gauge to the window. right on :thumbup: Fixed.... :P 1 Quote Link to comment
mrbigtanker Posted December 5, 2014 Report Share Posted December 5, 2014 Fixed.... :P what eva 2 Quote Link to comment
freetheoranges Posted December 5, 2014 Report Share Posted December 5, 2014 :w00t: :thumbup:Dope shit, and the throwback photo I have Tues/ weds off next week the 9/10th if shop days either day, down to roll thru. Quote Link to comment
Busta Nut Posted December 6, 2014 Author Report Share Posted December 6, 2014 I have Tues/ weds off next week the 9/10th if shop days either day, down to roll thru. I'll be here Tuesday night........ Quote Link to comment
