datsunfreak Posted January 29, 2012 Author Report Share Posted January 29, 2012 No time for work on the car, but did get a few minutes to pick up some goodies... :cool: Buddy of mine dropped this off today. '81 200SX rear axle, complete with disc brakes, e-brake hardware, links, and sway bar. ;) Link to comment
Z chopper Posted January 29, 2012 Report Share Posted January 29, 2012 is it possible that rear end is LSD? Link to comment
datsunfreak Posted January 29, 2012 Author Report Share Posted January 29, 2012 is it possible that rear end is LSD? We'll find out when I open it up to weld it... :P But I honestly doubt it. Never heard of any S110's having an LSD. Hey, stranger things have happened... Link to comment
dez Posted January 29, 2012 Report Share Posted January 29, 2012 can you measure that 200sx rear...wheel mounting surface to wheel mounting surface Link to comment
ggzilla Posted January 29, 2012 Report Share Posted January 29, 2012 It is a 1980-1981 S110 rear axle, drum-to-drum width is 54 inches. H165. They didn't come factory with LSD. But you can buy brand new ones. The last batch was $1100. Link to comment
datsunfreak Posted January 30, 2012 Author Report Share Posted January 30, 2012 can you measure that 200sx rear...wheel mounting surface to wheel mounting surface I'd be glad to. But it'll be a little while. ;) I'm going to measure both this and the stock axle to see exactly how much wider it is. Then I'm planning to widen the front track by a similar amount. I'm sure GG's numbers are solid though. Link to comment
ggzilla Posted January 30, 2012 Report Share Posted January 30, 2012 It is less than 1/2 inch wider than a stock 210, and we had one report that it bolts directly in, no welding or modification needed (except for probably the brake lines). Link to comment
datsunfreak Posted January 30, 2012 Author Report Share Posted January 30, 2012 It is less than 1/2 inch wider than a stock 210, and we had one report that it bolts directly in, no welding or modification needed (except for probably the brake lines). Damn... I was hoping it was at least 2-3" wider... :P Link to comment
dez Posted January 30, 2012 Report Share Posted January 30, 2012 the explorer 8.8 narrowed with 2 short side axles gives you a 56.5" rear (3" wider), 31 spline axles, disk brakes and a posi...not sure of you power goal but give you the extra track your looking for and if i decide to go on with my b310 project this is the rear setup im going with with some 300zxtt wheels Link to comment
datsunfreak Posted January 31, 2012 Author Report Share Posted January 31, 2012 not sure of you power goal but give you the extra track your looking for and if i decide to go on with my b310 project this is the rear setup im going with with some 300zxtt wheels Power goals are modest, no more than 150-160hp and torques. Most likely will do either a D21 KA24E (already got) or Frontier KA24DE (can get easily) with dual sidedrafts. This rear end ought to hold up to that just fine. Only other option I'm considering right now is an SR20DE, which will make less torque than that, so... The Explorer diff is a good option, just concerned about the size of the pumpkin. To run as low as I want to might require some floor mods to keep the diff from banging the floor. Plus keeping the driveline all Nissan certainly simplifies things. With a KA or Z20E trans, and the S110 diff, a 510 driveshaft should slot right in (shortened of course). Link to comment
datsunfreak Posted February 4, 2012 Author Report Share Posted February 4, 2012 Didn't get any work done, but did get it off the trailer. And that's a start... :P Link to comment
Z chopper Posted February 5, 2012 Report Share Posted February 5, 2012 hmmm do I see 6 datsuns in that ^^^oic? what are those fender mirrors on? Link to comment
datsunfreak Posted February 5, 2012 Author Report Share Posted February 5, 2012 hmmm do I see 6 datsuns in that ^^^oic? Sadly, there are about 6 more you can't see... :P Outside: '79 210 Coupe '71 1200 Coupe '71 1200 Coupe '72 1200 Coupe '72 1200 Coupe '73 1200 Coupe '80 200SX Coupe '78 620 LB '74 620 SB '86 300ZX '72 510 wagon '75 B210 sedan Inside: '73 1200 Coupe '71 Honda N600 '77 B210 Coupe what are those fender mirrors on? '58 Triumph TR3. There's also a '64 Triumph Spitfire right next to it. Link to comment
ggzilla Posted February 5, 2012 Report Share Posted February 5, 2012 Looks like the rare Chicken Hawk edition Link to comment
dez Posted February 5, 2012 Report Share Posted February 5, 2012 i want one of those 1200's Link to comment
Master-O-Turbonics Posted February 5, 2012 Report Share Posted February 5, 2012 It is less than 1/2 inch wider than a stock 210, and we had one report that it bolts directly in, no welding or modification needed (except for probably the brake lines). ya it bolts in and the brake lines should just bolt up... they are in the same location as on the 210. Link to comment
datsunfreak Posted February 5, 2012 Author Report Share Posted February 5, 2012 i want one of those 1200's Come on down! :cool: Link to comment
Dirttrack510 Posted February 5, 2012 Report Share Posted February 5, 2012 I'm digging this build thread so far, I love race cars :D I've actually been eye ballin' a B210 that's local here, so I can build a 210 race car myself. The "fast back" look is growing on me. :thumbup: (like I need another project, I only have 6 Dattos now) I guess they're like "Jell-O" cuz there's always room for another Datto :D Link to comment
Z chopper Posted February 6, 2012 Report Share Posted February 6, 2012 I guess for some Datsun are like Pokemon gotta catch them all Link to comment
Dirttrack510 Posted February 6, 2012 Report Share Posted February 6, 2012 I guess for some Datsun are like Pokemon gotta catch them all I resemble that remark :D :D :D :D Link to comment
datsunfreak Posted February 8, 2012 Author Report Share Posted February 8, 2012 ya it bolts in and the brake lines should just bolt up... they are in the same location as on the 210. Can you confirm the actual width difference? From that pic it looks like more than 1/2". Also, which arms did you use, 210 or 200SX? Link to comment
datsunfreak Posted February 10, 2012 Author Report Share Posted February 10, 2012 Special delivery from Nagoya. :cool: Surprisingly stiff, and seem to be well made. Should work a treat. ;) Link to comment
fisch Posted February 11, 2012 Report Share Posted February 11, 2012 Soooooo cool! What a great day to get the mail! Link to comment
