My 77 KC 620
Farmer Joe
this was the other news.
i broke a ]2edeye KA motor mount...
stephen... what do i do?
im gonna take it off here soon to see how much really broke..
edit, this pic is crap... ill get it wiped off and get a better one. but you can still kinda see how it popped the weld.
  • Replies 1.1k
welp, still waiting on a day off to pull out the motor mount and weld it up..
it has a flat again in the front thats making it lean way to the passenger side. had me worried i broke something underneath suspension related.
it does pretty well in the snow.. i just need to weld the rearend already. itll happen before canby, thats for sure.
i did get a list of have to do's before canby:
1. build the rear 3 link setup.
2. replace the timing set in the KA
3. put the s13 cam in it.
4. get a new set of rockers/lifters from a stanza at the yard.
5. convert frontend to balljoints and disk brakes.
6. test it all out before canby...
im helping a friend get a 620 on tuesday. top secret project that might come to canby with us!
more to come...
That second pic is a little better. Definitely due to my earlier welding technique and your heavy right foot. :lol:
 After this batch of mounts I am putting together is done they will all be 3/16 and fully welded like I do now. I'll send you a set of them when they are ready. :)
i figured out why the mount failed...
2 out of the 4 mount to block bolts were gone. the rear 2 that are obscured by the exhaust manifold.
didnt even notice they were gone. i took it to canby on 2 but put them in after the trip. they have since jumped ship..
so my fun filled night of getting sideways and burnouts was too much for jus the front 2 bolts. bam..
lol.. stephen, its up to you if you wanna send another pair.. see if i can break those? :)
i always figured the leaf springs were the weakest link in this whole cobbled mess.. well see how the mounts hold up when i get my 3 link in and make this thing a little more solid in the back... the axle is getting welded too, so well see fairs..
why stanza rockers/lifters.? just curious.
its got the KA24e in it.. just the FWD one.
all the valvetrain is the same as a RWD engine. the head is the same too. just the dist is mounted to the rear of the head..
the lifters in a few of mine are going bad, and they bleed out alot.. im just hoping to knab the stanza ones since they have alot less miles on em..
now that i think about it, im curious if the stanza cam is any different than the truck cam....
Got it... I knew they had FWD SOHC KA's and the lower mileage makes sense. I was really hoping you were gonna tell me about some "free" performance upgrades by doing so :)
right? itd be neat if there was a secret there...
looked it up and i cant find a specific answer on the specs of the stanza cam..
the truck cam is 232dur and .390 lift. i have an s13 cam, and thos run 240intake dur, 248 exhaust dur and .409 lift... this will be a giant upgrade. lol
Niel when you do the 3 link will you bag it too or run coilovers ?
& i can verify if you raise the gas tank 2 inches it WILL be above the frame & not scrape.
& do what i didnt do strong enough..weld some flat stock from the axle to the frame before pulling the leafs & leave em until your lower arms are in place :confused: :rofl:
its getting coilovers on the back.. i got a set form a late 80s subaru wagon.
ive got some angle iron i was gonna use to lock the axle in place with.. good on ya for the reminder!
and now, the pictures of the busted mount..
and hes the fixed mount! good as new!
i had to take it for a drive to test the new welds...
http://www.youtube.com/watch?v=NA_mR4Vef-0
the sound really sucked in the video... i dont know if my camera sucks or if the truck is just noisey...
