bagged 620 super short (big update)
nosh1t
g'day everyone i'm ryan and this is my 620
plans there are no plans
only plan is to get it done
AT ALL COSTS!!!
list
body droped with shock floor and shock engine on 20 inch black chrome rims.
roof chop and round tail lights and a custom dash and gear stick
tilting/lifting bed with weld in tailgate every thing fench or shaved
and custom cnc grill with retgal head lamps
and thats all i can think to list for now
heres the photos like all good builds
the start
started to shave in some spare time
checking out hilux buck seats with some taller friends (roof chop)
time to cut the crap and get in to it
some parts for the notch came
got it down to bare metal
tacking stuff in and checking it as you do
4 set up and tacked in
making smoother for a better finsh (was plasma cut)
notch cover
still working on this should round the ends and insides of it
and thats where my fuel tank will get moutned later
and a joke me my old man folling around lookslike where slumming it
had to make space so moved it out side
thats where its at rite now i have started on the front end and still working one the brakets and fab work like upper bag mounts and rear cross member
ryan.
  • Replies 96
yeah famerjoe pinion angle had to google it haha
its set up rite the 4 link and the yok and there 20 inch rims so it is what it is all i can change is the driveling and crossmember which is in bad shape anyway
anyideas as to what could fix that
Believe it or not a drive shaft U-joint that is on an angle does not turn at a steady speed. If you imagine looking down inside the driveshaft tube at the bent U-joint, you will see that it spins in an elipse or oval. It speeds up and slows down as it turns and because it is mechanically connected to the engine mass which tries to turns at a steady rate, there is vibration. As far as driveshafts go, less angle is better, however with any angle, vibration can be reduced by having two U-joints arranged at each end so that the acceleration/decelerations will mostly cancel each other out.
Obviously the two U-joint angles must be the same or equal for this to work. The angle at the transmission to the drive shaft must equal the drive shaft to the differential. As shown below:
http://i138.photobucket.com/albums/q251/datzenmike/Tranny/transdriveline.png[/img]"]transdriveline.png
In the case of a two piece drive shaft the same applies. Treat each half as a separate drive shaft. Input must equal output.
BTW BEEBANI gave me the tutorial on this. I only hope I remembered it correctly.
thanks heaps dat i knew it was a problem but i was offair to go agest what i know about the yoka being per and all that
but your way of explain it is too easy im going down to my work shop to fix that and get it to lay out on the floor
/Q
thanks
ryan.
Liking the round notches & good progress! Was wondering..whats the P next to the license plate?
in australia we have a licencing system where you are on a provisional licence for 3 years - during that time there is a power to weight ratio limit on cars, and also total ban on driving performance cars ( turbo/supercharge or V8)
lookin good, is there going to be enough clearance for the 20's up front?
how far are you going to body drop it?
looks like you got a L series engine and some disk brakes on there already and bag on bars I see, good choice and looks like a cracker of a work space and I see 4 grinders in 1 pic, why on earth do you need 4?
When are you planning on having finished by?
finsh date hmmm
wel 4 grinders one im a carpenter so two are work grinders
and the other 2 was a deal at a magnamart shop in ablino park rail its like bunnis
and it was when i broke a work grinder
20 inch rims will be fine in the rear
and pushing it in the from
boday droped to the rocker and not like how you done it peanut because i will need the inch half or what eva it was you cut off
i'll be running a 30 by 30 4 mm wall on the ground and weld that on the back of the rocker and make the tub line up
far as the from gose have to z notch the front of the frame 85mm (2 and half inchs rought translation) or maby 2 inchs if im lucky with the changes im going to do to the bottem control arm
done nuthing to day but check measure ments and figure out the front end and the pinnio angle issue (where i fucked up)
layin have to make the cross member go up 35 mm (inch and a half)
genrall ride hight
ryan.
g'day ratsun
well i got rite back in to it today and hit it slow
with out any steel suppers opened and no 4mm plate to make a notch for my front end.
motorivation plus
and i all so had the time burn my hand a+ for enought because i burn it good got two fingers and my thom is white
i work on as any one would do
so i got some new toys
measure up before un bolting the bottem control arm
mark a center line and square that up and cut it off making it esayer to make template
so then i cut the bottem control mounting patten out
flat dics (grind off bers) till smooth
and got it ready to be used as a template for making the blot holes out
clean it up ready for welding and marking out
marked it out like so
plasma cut it out, cleaned it up and marked the mounting holes out
looking good
clean
its not finshed but its enought to bolt it back on so i did
there we go
and i took the engine out because im going to have to z the front of the frame tomorrow
ryan.
thanks for reading and comments
Cool, its always good to see another bagged datsun. You may want to look into lowering your drive shaft hoop with the upper links mounted on it. Your geometry would be much more correct a good bit lower, right now it looks like you have no instant center at all. Just my 2 pennies.
coming along nicely, keep up the good work!!!
wow, looking good. deffinately digging the progess of your work. The notches in the back flow with the frame pretty good, wish I would have done that on mine a little better.
like airedout said about your driveshaft hoop, lowering it could help your geometry out alot. Other than that, it looks really good. Nice welds too, looks like you got alot of heat into them.
lol thanks peanuts yes that is why i had to z the frame and pitty i have oready done so
but main reason is that im using 20 insh wheels and they will have no camber at ride hight
and i still need to do what you said and make a custom upper arm but i will do that when i can get some steel
with the rear end i see no problem with the 4 link set up or the hoop
so not sure
thanks anyway
ryan.
