bagged 620 super short (big update)
nosh1t
yeah beebani talked me out of any doggy shit
hope i can get some stuff done with some help from a club member
im doing his notch so should at least get a days work on the datsun over the week end
it will lay rocker on 17's fine
  • 1 month later...
  • Replies 96
  • 1 month later...
hey guys no update on this latly its packed up in the back of my work shop
till i move to the new shop
basicaily it all got too much for me and the work to go on it the rate i was moving was going to be anouther year (body work brake lines and all that because i didn't know any better back then)
and also i haven't had a mini truck on the road in other a year so i feel like a looser lol
when i get back to it at the end of the mouth
i just order re-5s and re-7s and some adjustable bushes for a custom a arm
and i will make upper arms when i get my tube bender
same thing with the rear a lot of tube work
i have built one truck sence i stop working on this for a mate
and im working on getting my navara back on the road
not pictures of the datsun but update none the less
who needs mc brother rails lol
when i got it
much faster work then the datsun
but all the more expersce to use on the datsun
will be lengthen narrowing the frame and all that
shock grauds and a oldschool single cab on the back
lots of mods anyway will have the datsun frome in paint soon and upper bags and rails done
but i don't own a tube bender yet
so bear with me this thing won't die just need to get to the new shop which is 12 mins drvie from my house
hey guys came arcoss some problems (roof chop)
laws in nsw where i live you have to have head room fromt the head liner
is 5 inch foward from where your ass is and 2inchs up
is the center point
from there you need 835 mm 34 inchs ruff
so i need a really low seat and extremaily custom floor pan
i wanted to roof chop this 6 inchs so that i would have a smaller back window and a low roof line or overall body drop and roof chop
because where im from the hight is not measure from the door its measure from the roof like limbo
also looking for a v6 or v8 that fits in with out tonching the frame
  • 3 weeks later...
hey guys been working on this latly trying to get it done i have made a mad list and im going to work my way thou the list till its done
ordering a tube bender tomorrow
going to mount that like so and then run some bend tube arms off the side for my wheel a-line-ment (spelling sorry)
fixing that huge z i had
heaps of photos don't yah think
ok so i got that z all fixed up its only 8mm hard to tell
all my bolt in cross members will be that high up (no reason really)
time to start on my center bearing cross member
taking all the brackets and tabs that where on the bottom of the frame
bent the hell out of it to get it to where i wanted it
check it was where i wanted it took some measure ments
then i cut 5mm of each end and pulled it rite down
welded it up and smoothed it off
got a bit more to do on that but trying to make it look factory
welds
random photo
good to be back on the datsun heaps pumped to get it done
hey guys small update
but planing to have it done in 15 days so i have a lot of work a head of me
getting a tube bender and notch kit with dies for 34mm and 43 mm
hoping to have the frame done and in prima not mounting of air gear or shock and no bump stops
so got some photos from last night
finally getting there
bent them up and getting every thing ready
any wya im off to go do some cuttin and welding now see yahs
hey guys
i figure i have 13 days to do about 58 hours work but yah never can be sure
didn't go down last night and got down there late today after going out of my way to get my tube bender
so needless to say i didn't get heaps done at all
marked where the ground would hit the plate
made a carboard template
cleaning all the dirt dust and rust out of the frame
welded the bottom of the notch to the side of the frame
cut the leaf hangers off
well hopefully i can get some mates to help after monday night meet
and hoping sunday dose better
hey every one
got heaps done today
leaf hangers gonnnnne!
cleaning up ready for control arms and so on
ok so been working on this for ages marking it 15mm below the bottom of the frame
once i clean it up i think it should look pretty sweet
fill in holes
now i just have to clean it all up and flip it over and straight on to the upper bag mounts
and i gotta weld the diff brackets up
  • 2 months later...
The build looks good.
A couple comments:
There's nothing wrong with parralel 4-links. Street rodders have been using them for years and there is NO problem with handling. The only thing is the IC = infinity, so getting traction under hard accel can be an issue, but most bagged trucks, aren't being used for drag racing. ;) Chris Alston Chassisworks sells parallel 4-link kits, as do other companies.
When installing a non-paralel 4-link, I would add adjustable attachment points. If the IC is wrong you can actually end up with less potential traction than using parralel, or even leaf springs.
If I were to do a stock floor body drop, which is the only bdoy drop I would do, I would likely go to using round turb for the section under the cab. Stacking Tube can provide a very strong frame rail. Also running a hoop towards the trans tunnel, then adding a raised "back-bone" through the trans tunnel to add a little more strength can work well. Not an easy thing to do, but has been done and works fine. The other thing to do is solid mount the cab to the frame, add some bracing to the cab, as this will also act as a stiffening member of the entire chassis, allowing a shorter frame rail, to lay rocker, but not have to worry about chassis flex.
Any new updates?
yeah i guess i could put a update on
kool man i accauly can't do most of that where im from
like mount the cab to the chassis
and cutting the chassis down
and thing to do with leafs and 4links
very tuff engineer he wouldn't go for any of that trust me i wanted to cut the rails down
update side i now have sr20de half cut (200sx s14)
so planing on having rack and pinion steering
and a new engine
sence last time i have re mounted my brake booster
cab
front end
started doing wheel tubs
tacked the whole body drop up
only tacked because of the old engine has had it
and not sure how much room the new one will take up
rear bag mounts
random rush repair
i have more photos i'll put up any thing in closer detail at request catch yahs i gotta run off to work :(
could a admin please change the tread title to :ryans 620 (bd 'n' sr20de)
Hey Nosh, glad to see some more progress finally. Just curious, in the close up of your brake booster, is that taken with the pinch on the ground? And what size wheels and tires are you running? Just trying to get an idea of wheel clearance available, since you brought it up in my project.
Thanks bud. Lookin forward to seein some more from ya.
yeah man just be carefull is all im saying
mine has 16s on it with hight profile
can fit 17s by 7inch wide which is a very small wheel
thats with low profile tires i can't tell you what size in inchs but 604mm over all diameter
the brake boaster is most up 70mm back 100mm and to the rigth 20 mms
be differnt for you anyway being that yours is on the other side of the truck
there is 20mms wheel clearance in the wheel tubs
and the pitch is 45mm below the ground
that almost 2 inchs
just haven't cut it off yet
i have a lot of work ahead of me
and just lost my full time job so i can be full time working on my truck
thanks man
not really concerned with the booster itself, was just referencing the picture.
your pinch is below the ground? you dropping to the doors?
I'm Canadian, I speak metric too :P 605mm would be just over 2 feet or 24 inches, and a 225/30R20 is about 25.5 inches tall, if you're dropped 45mm (~2inches) and have 20mm (~1inch) to the wheel tubs, I think I can stuff 20's in there after all, just gonna have to bust out the sawzall, welder and 16ga steel and throw my reservations out the window.:lol:
thanks for the help dude. sorry to hear bout the job, but at least you got the datto to keep you busy. Git 'er Done!
  • 5 months later...
hey guys been working on this a lot latly was trying to get it ready to go to a show even had a old school mate help me out
i wasn't happy with the old 4 link or the old notch they wouldn't have left me much room to mount any thing under the tub or any room in the tub
and i like the look of the super shortys so thats what im making it now
this is how it was before as you can see in the rest of the build
and the changes i have made as follows shorted 4link by 100mms
made new 4 link cross members with tube bender
and moved the notch towards the cab 320 mm (about a foot)
got the air bags in the front there re 5s
front end
made some 5mm plates to hold the blots in place while tighting them up
so i finally cut the sills off and put some 40mm rhs in there
to bend this i used two tables and a big 2 inch by 2inch rhs and a degress bevel clamp down on a bench and pushed the sheet metal till it hit the degress that i wanted
i like the stace that it has now short and fat and with out the tube looks a little bit hot rodie to me
im keepign it this colour because i don't feel i could find a better colour for it
as all the trucks over here seen to be blue im not going with blue
more work on the 4 link
tub mounts and 4 link and bag mounts just need to plate the under side of the frame
so thats all for now hope you guys agree with my chanegs progess and so on
heres some other stuff i was testing out
180 degress
180 degress bent sheet metal using a 4 inch wide tube clamped to a bench this is how i plane to roll out my tub corners and so on
