bagged 620 super short (big update)
nosh1t
  • Replies 96
g'day ratsun im glad to say i have joined the lowerd almost
so heres a unfinsh update as it was 9:40 on new years when the last photo was taken and i need diner
so as i was saying i need to z the front end and as peasnuts point out i will have to mod the upper control arms
i seem to be missing a photo but you get the point left side done
ok when eva i build some thing weather its a house or table i always want it square plum and parallen
so that level is square and will be used to measure off
i then make the mark of where the center of the notch will be later
plum the lines down
braces the frame
oh shit you will notice some thing thats not bracesed i swear do not try this at home ha ha
with that problem made and then corrected i move on
yeah photos say it all
move it out of the way and clean it up
there some photos so you can see the notch start i guess
i will plate this later
tomorrow before starting on mount the air bags i will get this braces better
and plate the iner frame rails so it dosen't flex where the plate is on the z
and with the z it was cute with a 3mm grinding blade and its a 5mm plate so its 2mm out but thats fine
nice work, wish i had empty garage space to do the same to one of mine...
this is the best website, using the brain to build instead of the wallet!!!
love the wheels...what kind are they???...black candy powdercoated???
The way your 4 link is setup right now you have no instant center, which will cause adverse handling affects. Think of instant center as an imaginary line coming off your link bars. In a properly setup 4 link, the imaginary line will meet close to your front bumper at ride height (when you lower link is parallel to the ground). It looks something like this:
From the looks of your link setup, it looks like the upper links are angled upwards, away from the lower link. You have plenty of room in your hoop, before you get too much further, i would deff be looking into lowering it a little bit. Just trying to save you some headache.
that makes no sence because every line will meet up
unless the parral
this is accauly a shock 4link like out of a box or what eva but i guess i will look in to it its still only tacked in
g'day very unproductive day to day
how eva progress is good
got some spitted out upper control arms (quik and doggy)
will re do them with tub arms later or re-do the ones i made to day
frist setup was flat to the tabe and nexted to the stock one
this was not good enought
quik test showed i need to go a bit more
there they are pretty... NOT
start clening it all up. and grab som measurements.
bag notch
same sdame
quik picture over picture
i will look in to it im now running late to go out will finsh this post later
Ryan, the thing you really need to look at is whether or not the bars are parallel at ride height. If they're not, then they need to be adjusted. At ride height, your lower bars should be somewhat parallel with the road also.
Your lower should be parallel to the ground at ride height, and the front of your upper should be slightly pointed towards the ground.
Your getting the idea with this pic. Now you just need to imagine the instant center point (the point where the 2 lines meet) around the front of the truck (front bumper).
g'day ratsun
i'll like to show my appreciation to some of the guys on here for help in point out my mistakes and stupid lol
farmerjoe, greiggy, datzenmike, peanut2425, airout, hacked521 and beebani
yeah appreciate it guys
question for some one who knows is 20mm enought clearaces for wheels when fully layed out ?
parents droped by and had a look at my truck to day they where very inpressed i think before i finsh it they will want me to lower there camry lol
so heres a list of what has to be done
front uper bags
rear upper bags
rear bottem notch is to be plated
75mm rails inside the old rails making it a kool 80mm rail
custom tube body mounts
front cross member to be droped
notch for the z at the front (can't get any steel till after i go back to work sucks)
also welding to day finsh a tip off and looked for the bag of new ones i brought coudn't find them
so i had to creak out the old gasless sucks huh
and some pictures
i will make notch plates later this is only for now
had to tack these in with gasless not bad
it dose clear relax
g'day ratsun
good it all tired up to day farme should be finsh tomorrow if a metal supplier is opened
got those gusset done so not i can finsh the front end
picture of some welding
cut off the front hoons and fould they where filled with tree back and shit
got the cab back on
a mock up price of steel metal i will have to make that as a rocker
what do you think ?
i keep forgeting to take photos
but i got all that cut out read for new body mounts and 80mm frame rails
tell me what you think about the rocker
that 4 link looks a lot better man, and yeah like bonvo says, just incase u weren't going to already gusset the bottom too. I can't really invision how that sill would look, so I can't give u an opinion. Would u be doing it to the tub too? And have you measures up all your hood to engine clearance and all that stuff, can u run stock hood or will you have to run a cowl or something of that nature?
shock hood will be fine if i do the rocker sill thingo
other wise i would have to section the fenders and make the hood more level and would change the hole look of the truck
so thats why i have to do the sill
with the gusset there only temp as i said ealyer because i will plate the sides when i ge some steel
only weld the gusset in so i could keep on with the mock up of the engine mounts and all that crap
peanuts whats your msn man ?
these that sill set up so tell me what yah think
and i'll make the bed match
I think that the new sill will look terrible, ruins the bodyline of the truck. Defeats the purpose of bagging it to make it low.
Sorry, but it's just my opinion. And it's your truck, build as you wish.
