Guest DatsuNoob Posted December 13, 2008 Report Share Posted December 13, 2008 I was thinking of this tonight as I was driving to work, after some asshole decided to slam on his brakes on the freeway. If I was in my truck, I woulda locked 'em up for sure, and ended up on the guardrail. Wondering how involved of a process it would be to install ABS on a 620? I thought it would be cool to have it on a switch so I can turn it on and off. I'm sure alot of you know, 620 brakes seem to lock up real easy. Just getting ideas for my build. Quote Link to comment
ggzilla Posted December 13, 2008 Report Share Posted December 13, 2008 Shouldn't be too hard. A lot of trucks only have it on the back wheels, to prevent unloaded pickup from swerving. Quote Link to comment
ariascarlos1990 Posted December 13, 2008 Report Share Posted December 13, 2008 I wish I had ABS today! I was going around a corner and just slid into a curb.... My airdam is fucked :( Quote Link to comment
Skib Posted December 13, 2008 Report Share Posted December 13, 2008 I wish I had ABS today! I was going around a corner and just slid into a curb.... My airdam is fucked :( :( bummer. my Z breaks lock up hard lol Quote Link to comment
ariascarlos1990 Posted December 13, 2008 Report Share Posted December 13, 2008 yeah it sucks. Ill just get another from steroid....:D Quote Link to comment
Llittle_Llama Posted December 13, 2008 Report Share Posted December 13, 2008 fix the old one. i am looking for a computer for tpms of of a titan. i have the sensors and am thinking of installing it on the 620, i know off topic, but just saying im on the same track with the new shit.... Quote Link to comment
datzenmike Posted December 13, 2008 Report Share Posted December 13, 2008 Be careful. I have serious problems with the big three's commercials about ABS and their computer controlled reactive suspension etc.etc. It's is a great safety device but the ads make it seem like it will keep you from even having an accident... which is BS. If people feel safer they will drive faster and with less caution. No one drives faster just because they have a seat belt on. Its the same with ABS. As long as you know it's and your limitations they are a great device. In a panic stop, when the brake pedal starts to vibrate from an activated ABS you are in serious trouble. It's way too late to wonder if you should have been more careful or going slower. Quote Link to comment
Llittle_Llama Posted December 13, 2008 Report Share Posted December 13, 2008 now thats smart thinking. thats why so many kids are getting in accidents no days. parents buy them subbies aand they think "i have AWD, i CANT lose control" and then die. Quote Link to comment
]2eDeYe Posted December 13, 2008 Report Share Posted December 13, 2008 I can stand the abs on our xterra, the abs on my G aint much better... I like old school abs, pump the pedal. That's all the electronic systems are doing anyways. Quote Link to comment
banzai510(hainz) Posted December 13, 2008 Report Share Posted December 13, 2008 I have ABS brakes on all my Datsuns. Follow car and call out Mississippi 1 ,2 and 3 times froma known point and that should be good enough and do the speed limit. Buy good tires Its alot cheap also. Quote Link to comment
Cuts metal like mad Posted December 13, 2008 Report Share Posted December 13, 2008 Your putting a LOT of work into that 620... so when you drive it, take it easy. Don't fall victim of being in a rush or getting angry about a few feet of road, its not worth it. You don't need ABS, when you get the truck on the road drive slower and more carefully... Look at Hainz, hes been driving datsuns since before I was born (JK OLD MAN!! HAHA)... and thus far no reports of locking up the brakes and smashing one. Quote Link to comment
banzai510(hainz) Posted December 13, 2008 Report Share Posted December 13, 2008 the 521 brakes do kinda suck,lock up on the rears and been some close ones thats why I drive slower now Quote Link to comment
MikeRL411 Posted December 13, 2008 Report Share Posted December 13, 2008 Just remember this. With standard brakes, on an icy intersection if you slide you fishtail into traffic and have a good chance that you will get creamed in the rear and walk away. With ABS you slide head first into the intersection and will get T boned, right in your driver's door. You might not walk away. Bottom line, follow to 2 or 3 second rule, increase distance in winter. Don't wait until you get to the intersection before starting to slow down. There is a place for tire chains, if it's that bad, unless it's an emergency stay home. Quote Link to comment
BEEBANI Posted December 13, 2008 Report Share Posted December 13, 2008 I have 4-wheel discs on my 620, so I have no idea what your whining about. ;) abs is gay, and I hate it on my 05 xterra, just a nuisance. Quote Link to comment
datzenmike Posted December 13, 2008 Report Share Posted December 13, 2008 All things equal, ABS will stop you faster.... keep this in mind when following too close behind a newer vehicle. He can stop in a shorter distance than you. When I raised my 620 and installed 33" tires I drastically altered it's ability to stop. The added 600-800 lb didn't help. Had a few wake-ups at stop lights. I approached at what I thought a normal speed but had to press harder and harder, the weight transfers to the front and the rears lock up for the last 10 feet with a big screech and you look like an idiot. Wet roads were way worse causing a side to side slide. I adjusted for a year, by leaving 4-5 car lengths. On someones advice I got and installed a Willwood adjustable pressure valve in line to the back. I just kept turning the pressure down till the back brakes would just start lock with the fronts. Now I can cram on the binders with out worry about rear lock up and the back skating around. Wet pavement is much improved. Quote Link to comment
Bleach Posted December 13, 2008 Report Share Posted December 13, 2008 I have studded tires on my Z now... someone slammed on their brakes to avoid a BBQ in the road yesturday (they could see it in front of them for a mile) I had to brake and release 3 times to keep those tractionless tires from skidding. Good solid disc brakes and good tires should be enough. Quote Link to comment
datzenmike Posted December 13, 2008 Report Share Posted December 13, 2008 ....and the sparks flew, you stud. Quote Link to comment
yello620 Posted December 13, 2008 Report Share Posted December 13, 2008 Back to the original question, If you were to install front spindles and a rear differential from a Frontier, that should give you the wheel speed sensors to run the ABS system. Now you would have to get all the brake fluid plumbing correctly installed to an ABS pump system and get it the proper power system. This would be a huge project to take on, and most likely would be expensive before it was all done. Jason Quote Link to comment
datzenmike Posted December 13, 2008 Report Share Posted December 13, 2008 Frontier axle assys. are wider than 620s. The sensors are in each wheel? Best to find a complete system and swap it over. Quote Link to comment
yello620 Posted December 14, 2008 Report Share Posted December 14, 2008 I didnt say to swap the entire axle assembly, swap the differential third member. The rear sensor is in the top of the third member. Quote Link to comment
Guest DatsuNoob Posted December 14, 2008 Report Share Posted December 14, 2008 I have 4-wheel discs on my 620, so I have no idea what your whining about. ;) abs is gay, and I hate it on my 05 xterra, just a nuisance. Wow! go easy dude, I was just stating that 620 brakes lock up like a S.O.B. This is my 3rd vehicle w/out ABS, and I've noticed how stopping is so much better on a newer car like my crappy Toyota. That's all. I always maintain a fair stopping distance between myself and other drivers. I cant stand it when people cut into my gap, or get in front of me and hit their brakes. I think every 620 owner would agree that the stock braking system of a 620 has major room for improvement. I will be getting all wheel discs in the future. Quote Link to comment
datzenmike Posted December 14, 2008 Report Share Posted December 14, 2008 I didnt say to swap the entire axle assembly, swap the differential third member. The rear sensor is in the top of the third member. Assumed the Frontier had something larger than the H-190 in it. Doesn't it run the larger H-233 or C200 like a Hardbody or Path? Quote Link to comment
yello620 Posted December 15, 2008 Report Share Posted December 15, 2008 My understanding is that the early 4 cylinder frontiers still used the H190 and the 6 cylinder trucks used the larger rearend. It should be completely possible to use the H190 from a later D21 because some of them also had rear wheel abs. But the front abs didn't appear until the frontier to the best of my knowledge. Some serious research would need done on this to get this completed. Research beyond our little internet discussions. Quote Link to comment
datsunaholic Posted December 15, 2008 Report Share Posted December 15, 2008 Newer cars have better brake systems than anything from the 70s, even ignoring the ABS. That being said, since I own nothing with ABS and seldom drive cars with it I've found that I get a a lot of trougbe WITH ABS than without it, and I don't drive cars with ABS thinking it'll stop better. My Dad's Durango ABS system engaged when I thought it shouldn't have (I guess one wheel wanted to lock on some leaves by the curb) and I almost went through an intersection because of it. You could feel the brakes let go. And I absolutely hate the rear-only ABS on trucks. My Mom's Ranger has rear ABS. The auto MFGs spent years and millions telling everyone ABS let you "stomp and steer". Then put ABS in a truck in the back only, and you plow headlong when the fronts lock and you can't steer at all. Ran into a bulkhead that way. My fault for taking the turn too fast, but when I felt the pedal pulse I didn't helease the brake to turn as I normally would have. Quote Link to comment
BEEBANI Posted December 15, 2008 Report Share Posted December 15, 2008 Wow! go easy dude, I was just stating that 620 brakes lock up like a S.O.B. This is my 3rd vehicle w/out ABS, and I've noticed how stopping is so much better on a newer car like my crappy Toyota. That's all. I always maintain a fair stopping distance between myself and other drivers. I cant stand it when people cut into my gap, or get in front of me and hit their brakes. I think every 620 owner would agree that the stock braking system of a 620 has major room for improvement. I will be getting all wheel discs in the future. That was easy, I have a rough sense of humor. meant nothing by it buddy. I know how the stock braking is on these muthas, that's why I provide the services that I do. Nobody respects our rigs, and just cuts us off or passes us all the time assuming that these are slow pieces of shit. That's why I love it when I can blow the doors off of some new overpriced piece of shit with my rattlecanned datsun! Quote Link to comment
