Farmer Joe Posted December 10, 2008 Report Share Posted December 10, 2008 so ive got this problem with my wiring. its not really a problem you could say, just something that really annoyin. so at night when i have my headlights on, when i push the brake, and the brake lights turn on, the headlights dim. they almost turn off sometimes. then, when i have my headlights on, and i use my turn signals, the headlights dim every time the signal strobes. and also, when i turn my heater fan on to high setting, the headlights dim. the combination of the heater and the brake light is what makes the headlight almost die out. now is all this caused by the heater, tail lights, turn signals and wipers all being on one primary circuit? now i know that anything can be done, but how hard would it be to isolate all these things to where the all get power separately? id just really like the truck to be a little bit more enjoyable at night. thanks a bunch! Quote Link to comment
dat521kid Posted December 10, 2008 Report Share Posted December 10, 2008 probably need to get higher amp alternator Quote Link to comment
bonvo Posted December 10, 2008 Report Share Posted December 10, 2008 just what i was thinking Quote Link to comment
ggzilla Posted December 10, 2008 Report Share Posted December 10, 2008 Naw, the smallest Datsun 35amp alternator can handle all those things at once. Maybe you have a bad ground wire? Or maybe corroded wire connections. Quote Link to comment
Cuts metal like mad Posted December 10, 2008 Report Share Posted December 10, 2008 Get yourself a relay on those headligts... Direct battery power through a relay should solve this, but not a guarantee Quote Link to comment
fastdadd Posted December 10, 2008 Report Share Posted December 10, 2008 someone told me that all the wires run off the electric system before it gets to the batt and if you rewire so it comes off batt you dont get that problem Quote Link to comment
Llittle_Llama Posted December 10, 2008 Report Share Posted December 10, 2008 could do what i did.... (ducks tomato) Quote Link to comment
hang_510 Posted December 10, 2008 Report Share Posted December 10, 2008 cleaning the fuse box and ALL the connections, especially the grounds! should solve the issues. or got the dwnshfter route... Quote Link to comment
scooter Posted December 14, 2008 Report Share Posted December 14, 2008 mine was doing this till i put on a 100 amp alternator.. but i DID find some really shitty connections when i changed it over... Quote Link to comment
72240z Posted December 14, 2008 Report Share Posted December 14, 2008 I agree with others that it sounds like bad grounds/connections. A higher output alt sometimes solves the problem but only because it makes up for the power being leached out. I would break out the multimeter and spend and afternoon checking every connection before spending money to band-aid the prob with a new alt. Quote Link to comment
lynchfourtwenty Posted December 16, 2008 Report Share Posted December 16, 2008 my truck does the same kinds thing but my lights dont die out, then jus dim a little when something is turned on like the heater or brakes an the also mildly blink with the blinkers.. its prolly a bad ground, these datto's are natorious for bad grounds, i havent really drivin my truck much since i replaced my alt, an voltage reg. pretty much after i fixed that stuff i went directly to a clutch / tranny job an havent completed that yet.. but im sure my truck will still do the same shit.. Quote Link to comment
DaTsUn72WaG Posted January 10, 2009 Report Share Posted January 10, 2009 If you have a bad voltage regulator it wont allow your alternator to put out as many amps as it should. which will make headlights dim and blinkers slower. i need a sew one in my 510 goon. Quote Link to comment
banzai510(hainz) Posted January 10, 2009 Report Share Posted January 10, 2009 wack the blinker can or reseat it. I would have a spare regulattor to swap in and ck that out. Your system putting out near 14volts at say 1500-2000rpm???????? Most sytems you can tell the lights dim when you put the brakes on or heater at the high setting. esp the 35 amper alternator. Quote Link to comment
]2eDeYe Posted January 10, 2009 Report Share Posted January 10, 2009 could do what i did.... (ducks tomato) Haha :) Did you relay your system yet? Quote Link to comment
coolioni Posted January 19, 2009 Report Share Posted January 19, 2009 I had a similar problem, what fixed it was putting new battery cables in. They were all corroded. When I had my lights on, my car steroe would not work, and when i had the wipers on it also turned the steroe off. Then my low beams both went at the same time, and all I could use were my brights. Quote Link to comment
