72 620 truck KA Build - Tank.
Tank.
  • Replies 105
Rear Suspension
The 4 link is complete. It came out to be within a tenth of a degree of the transmission angle, so I am happy ended up there. It took me 2 hours to get the axle housing situated exactly where it was supposed to go.
I did have to drill a hole in the frame to act as a relief as the angle of the bracket interfered with the nut. I also welded on some tie down brackets to the housing to make trailering easy if needed.
Since the was made for an s10, the springs aren’t going to work for this. They are 7.2 inches tall, and I ordered 6 inch tall springs so I can get the ride height exactly where I want it. When those get here, I’ll post where it ends up. I would have had it on the ground rolling but I lost an axle bearing spacer somehow so I am currently trying to locate one. Otherwise I’m moving on to plumbing, fuel cell, and exhaust.
E1-F84-A61-6-E11-4-FF8-82-F9-57-B0171-E5
29-EDE713-2-E00-41-DA-BCF6-19-CF64-D0-F0
2-B0-D221-A-0-FF9-4-C3-C-93-A8-5-D08861-
4-A27-C553-A6-CC-4-CA0-8-E0-C-847-F890-A
572-FA6-AD-5-B73-4021-886-F-7-EB80-E3838
6-B61-BE12-B80-A-43-F8-895-B-303-F4-B4-D
8334-CF81-2-D39-435-B-A3-F2-30-A57162-A4
9-A33-C302-43-E0-4-D6-B-91-B2-FDB1-BC479
9-C54-A3-DA-64-F5-4-CD7-BC36-9-F688-A2-D
  • Like 7
Got a bunch of questions, sorry. How did you figure out which upper control arm to use? Were you just matching the length of the stock arm? What is the advantage? Clearance for the spring? And did you look at using a ball joint reamer on the upright, rather than welding in a plate for the stock ball joint? Is there an advantage to adjusting caster at the control arm vs at the strut rod? Seems like bushing bind would be the major issue there, and maybe this can all be heims jointed with enough effort, allowing more adjustment with less binding.
No worries, a couple of things went into my thought process for the front. Paying $600 for that just seems outrageous to me. But other than that, one, I knew I was using 720 lower control arms which extends the track width. Two, I knew if I was a little longer than the stock upper control arm, I would be in the ballpark for small adjustability so I was looking for something similar in size. And the adjustability is for toe, not caster, because it will bind the joints I currently have. But could easily swap to heim joints for cheap if more adjustability is needed for final alignment. You are correct in that caster can be adjusted with the strut rod.  I set the upper brackets in line with what would be stock caster. So you imagine a line drawn through the center of the brackets for both left and right, they intersect behind the truck. I did look into a reamer for the spindle but wanted to leave that alone incase I wanted to switch to a drop spindle or a different year (which I actually did switch to a Hardbody spindle), and keeping the parts needed from the same family makes it easier for me to keep track of. Now having said that, It would  have been easier (but more expensive, I think the correct bit was like $80) to ream the spindles rather than make plates to fit the upper ball joint so it I had to do it again, I would probably just do that knowing what I know now.
On the strut rods, I used sway bar bushings and can easily tighten the big nut on the front side to pull it more forward, or loosen to move more rearward (less caster). I'm anxious to get it on an alignment rack to see where it lands but with the way everything looks currently, it should easily fall in the green for caster and toe. I'll probably settle on a mild 1 to 1.5 degrees of camber and 3-5 degrees caster. It's just a fun mountain get around truck.
The strut rods have a very minor amount of adjustment, but that was to account for discrepancies in the frames...not for caster adjustment.  As Tank mentioned, there will be binding if things are moved much.  The factory caster was built into the spindle/dogbone as kingpin inclination.  The dogbone was set vertical and the kingpin tilts at 1.5deg(if I remember right).
And I installed the brackets of the upper control arm in line with where the oem mounting points where aimed. Which again, intersect behind the truck. Regardless, the heim joint part numbers that fit are 5/8-18 RH 1750506 and easy to install if needed. On the strut rod, there is about 1/2” in or out that it can be adjusted, which I have no idea what that would equate to for the caster adjustment. We shall see!
Edited by Tank.
Haven’t had much time to work on it lately, but the rear springs are swapped for a proper fit now. And the fuel tank is completely mounted. I moved the rear crossmember back some, drilled some holes in it and welded nuts to it. That’s the mount for the rear of the straps. For the front mount of the straps, I used a t bolt and some brackets on the coil over cross bar. Drilled holes, inserted the t bolt, the folded the strap around the t bolt and welded it. Now it can be tightened up against the bottom of the bed crossmember. Which is what the angle iron is representing.
The tank is an all in one unit from Tanks Inc that has baffling, pump, sump, and fuel sender.
C7817-E06-1-A90-427-B-98-FA-C57-B0020571
971093-B8-664-A-45-BC-B8-C4-D31280-D107-
6239-C44-B-3196-4836-86-D4-2-F5076823-C2
970-FCC76-0908-40-AF-B1-B4-2346-B439-F3-
9-A2-C0-E59-B677-401-B-B3-CC-4768-DEC394
2-FA6-F224-4-AE1-43-FE-9-FE2-0-C143713-F
DCB4317-C-38-A3-4953-A235-EE628-C13088-D
  • Like 7
Finished the rear, just need to run the return line to the fuel tank and vent. Otherwise tighten things to spec and move on to the exhaust.
I used 5/16 aluminum for the fuel hard line and copper nickel 3/16 for the brake lines with stainless steel tube nuts.
1-C29-EF32-A04-F-459-C-9131-D22-C36380-C
21-D976-D8-EC1-C-497-D-B301-FAF1-CC020-D
BD8-F1-C07-6-BA3-467-F-A72-C-2754-F94068
F9-ED4-BAC-91-BD-4-D9-A-8-A1-D-EE423-DA3
86-CD36-EA-22-C3-419-F-B923-8-D0-D7026-C
78-DD8268-8-BA4-47-E2-88-C8-5-C4-D692-E9
53-D2-D8-B6-BA2-B-49-E4-BF30-927-C09293-
4-EECFF70-532-A-40-E3-9016-F412-B892-CCF
419-AF792-D690-4628-89-FF-A86-B4-AD8-F88
41931-A7-E-C851-4202-8-C7-F-B0622-C748-C
That’s the fuel filter bracket from the Frontier, fits nicely here and should be extremely easy to change.
Also dropped the stock wheels off here locally for a guy to sandblast and powder coat. Hopefully it will be rolling here in a month or so.
Edited by Tank.
1 hour ago, EDM620 said:
Please replace those rusty line clamps - everything is so nice & fresh then there's those rusty old clamps...
If you gotta make new ones, some HDMW plastic is ideal
Lol those are there just so I could form the new line. They will go in the vibratory parts cleaner and painted this week.
Got started on the exhaust, was able to keep all of it above the bottom of the frame. There’s just one hard angle joint which is just due to my inexperience. It was a little difficult to get above the transmission crossmember. Otherwise just need to make an S to go from the resonator to the muffler, then I plan on running a 90 straight out the side in front of the rear tire.
The header is for an S14, it’s a chinese make but it was $48 bucks, so....let’s see how long it lasts.
00-F58934-0202-49-E9-931-C-A3-A95-EDB0-F
51114619-DE1-C-4612-84-F0-C47-A024-ADE3-
4-D1-E83-E7-3696-4-E4-A-8996-E4-E392893-
1-E9765-A6-4-DB3-433-B-9-E87-8-CC6321-DC
BE0466-C9-8-C94-44-F8-805-A-89-BD365-E4-
F592-B7-D3-90-FD-4-C76-93-C6-675-F5-D1-E
Return line is complete, the coiled up hose there is the vent line that will run under the bed to the front of the bed, then go up. From there I have a 90 to the actual vent.
  • Like 5
Just a few things left to do on the exhaust now. Mainly hangers and fully weld the front portion, oh and I need one clamp for in front of the resonator. I’ll finish the tail pipe once the bed is back on, but there is a 90 just stuck in there for now to get an idea.
650513-C0-6002-4-A92-A75-B-1-D095730-DF2
80-DF462-E-23-E7-4344-BA20-F42899-C72-C0
215-B7-F60-89-C0-4126-8-C16-DC62-CB969-E
1-EC897-D5-F5-BB-4-B16-87-D4-5328-A46881
F0-E56740-FB8-E-4222-B787-D646-D874-E7-E
59 minutes ago, Tank. said:
No it’s a universal truck tank kit from Tanks Inc. UT-N-2HT. Came with pretty much everything, I changed the filler cap to one like a late model ford, just stick it in and go.
https://www.summitracing.com/parts/tnk-utn2htkitgml
Whelp that's an easy $400 spend, lol thanks for the heads up!
Comparatively speaking, I have twice that in modifying my 240z tank for an aeromotive phantom unit and restoration. So for nearly everything I need for a little over $400 sounded like a good deal to me!!
