72 620 truck KA Build - Tank.
Tank.
The exhaust is done, as is the fuel system and brake lines. I repurposed the old 620 hangers and reworked one of the frontier hangers. I’ll admit it’s a little janky but it’s definitely firm where it needs to be. Next is figuring out an e brake setup and get the driveshaft shortened.
A0-F60-BE4-C6-F5-4904-860-E-F0-AD3-AAE19
93-B0-E97-E-293-C-49-B9-AD2-E-2-FEA0-F84
916-C011-D-7-F7-C-40-D6-A2-F6-DF7-C5-F16
17693-F4-C-D226-4-D49-A798-94640-C3-E4-B
2-FD79-DFC-7610-426-C-A3-A6-FFA04-D33-CD
446-AB2-AB-7-EBA-47-E8-80-E5-CA54-AF6-B5
EB347358-7-E0-C-480-A-BF88-12-C79-B2-D39
E6-D994-F5-3-FC3-4-F82-85-B5-D0-B9-F18-B
DA103143-F39-E-4-B72-9967-924-AD9-BB27-B
  • Like 5
  • Replies 105
On 2/26/2021 at 10:33 AM, partytron69000 said:
So good Tank.  Hopefully you're still around here in a couple years when I start peppering you with questions.  You're building your 620 pretty much exactly how I want to (except you need more turbo 😁), but its clear you're WAY better at this than me.
Thanks, I’ll still be around, probably won’t be done! Still have a very long way to go and have less and less time to put in it. Turbos...yeah I might single turbo the Z in a few years, but not the truck. It’s just the putt around truck.
Front revisited - here’s a peek at the sway bar solution!
Utilizing heim joints between the sway bar end and the lower coil over bolt with a spacer to give clearance to the spring.
I cut the end of the sway bar off about 1-1/2” from where it is full diameter, then rotated it to better fit the heim joint. After that, Z cut both to weld them back together. Everything has plenty of clearance and plays nice together. However I did notch the side of the lower control arm for heim joint clearance.
The bar is finished and the paint is drying. But I have a broken bolt in one of the sway bar mounts so I need to fix that. My father in law just got a blast cabinet so I’m going to take the mounts and a few other pieces over to his garage to try it out. So it will be a little bit before it’s fully together. But here are a few pictures.
DAA20-D65-2-A1-C-45-AA-B27-A-74-E5-CBF37
722-AEA15-E275-4-D37-97-EF-A2422-BA83-FC
D1-E26-D7-E-2204-45-A3-AE6-E-9-E39-ABF23
BFCA7899-4019-4-E88-9-BE0-BB91292-CC43-F
94-C38-AE0-2-E9-E-4072-B0-C2-DD9-AF316-A
214985-AF-5703-405-A-BC1-A-572-BBB02-E3-
Edited by Tank.
  • Like 4
By the way, early style oem 620 wheels DO NOT fit Isuzu rear brakes with beebani brackets. Not that big of a deal for me since I was planning on putting spacers on anyway. But it would be nice not to have to fool with them if i didn’t want to.
I could have told you that, since I'm the one that figured out that setup to begin with.  There used to be a thread about it on NWDE, but that forum has been gone for years!  I even cut a rim in half to show why it wouldn't clear.  If I remember right, it won't clear any 14" rim....but I'm not sure.  Heck....I still have the parts from the scrap yard sitting in my shed from when I first did it. lol  I'm a bit slow. 😞  LOL
Well I learned the differences of the oem wheels from you, but I was under the impression for the rear kit, some 14s fit. But you would know better than me.
Bleach pointed me to the Trooper parts many years ago.  There's been way too many projects since then to remember much about these. lol  Sadly, most of that was done on the NWDE forum and the pics were hosted on that forum.....so when it died, everything went with it.  I'm not sure I was using Photobucket back then.
***just saw Mike's archive link......sweet!  It might have some of the info....if you can find it. lol :)
Edited by mklotz70
I have a roller! The spacers I have are not the final ones but at least it rolls.
4-D977001-077-D-4-AE9-B3-DC-EE7485-B5570
A5-A3-C38-D-D2-A8-4-FEC-B382-0-A7-E8-F06
C078-BCA3-BCA4-4410-A82-E-CBD3-D7-BB85-C
663-AFBDF-E588-4-C0-E-9-CA5-AE3-D1-EA446
601582-C7-3664-4-C13-9-A33-0-C937-AB3-A1
And then there’s this....uncovered it for the first time in months. Charging the battery and going to wake it back up soon.
07-B754-F9-B766-4060-9380-7-CB0524-F74-C
  • Like 10
  • Thanks 1
5 hours ago, Soundline said:
That’s an impressive car.
I’m enjoying the 620 progress, I’m excited to see where it goes.
Thanks. Looking forward to getting it out and driving.
I have had a lot of fun building the truck so far, hope to be working on the body soon.
I was able to get the parking brake mostly done. The only part left to sort out is the connection between the handle cable and the new setup. This is a universal kit from CPP that came with everything but the brackets. I made those and welded them to the lower link brackets. Since I swapped it from the left side of the frame to the right, I’ll need to add an insulated clamp to the bottom of the bed to hold the left side up out of the way of the driveshaft, but that will be easy. The angle iron represent the bottom of the bed and cab. I left a lot of cable on the front side and plan to cut that once I know how I’m going to connect it to the cable coming from the cab.
4-E27-DF7-A-35-F6-45-D3-BA9-D-7-F948-C27
7-F24-D1-C8-E978-4-BCC-87-BB-C0-A66-B76-
4-BF0-A63-D-708-B-4-A05-876-A-288-DAB384
8-FC0-AA6-C-15-D3-43-D8-B425-8009-C17-A5
D456-EC89-6-D6-C-4-BFF-890-D-F80847-FFD3
71-E020-DB-E708-402-D-87-FC-869-CA46807-
  • Like 5
5 hours ago, ]2eDeYe said:
Looks like a nice kit.
How are you planning to set up the handle?
Not sure yet, I need the cab on to go any further but I’d like to just modify the stock cable. But the inner cable looks like it needs to be replaced, it’s a little rusty. I’ll end up routing it over the transmission and through the right torsion bar tube since it’s not there anymore.
  • 1 month later...
Finally had a chance to do some more work to the truck. I had the driveshaft made, stripped the rest of the cab and did a test fit. Definitely have a few tight spots to work through. But overall very happy with the results, I didn’t have to trim any of the fender well for the front suspension.
A4-E1-AD2-F-5470-4-E2-C-B2-D8-54268-C253
CC263-B82-8-C24-49-BA-BA41-29-C10-F8-C37
60-D15-E51-DA03-4-E1-D-97-F8-1244-FA700-
3-BD9-F4-B4-808-B-41-C7-822-C-624561987-
32169-ED5-54-CF-4-F6-E-95-D0-D99-DE0-E37
F082-E4-E9-A644-4-DED-8-E9-E-1-CC6-E1-F0
E52-A795-E-37-AC-4520-AAC2-4-FCB081-D348
E179-CB16-7-B7-F-407-A-A248-856-AA6-DCBE
47-D217-CA-EBAF-49-B6-9-FEE-768-E846744-
I set the transmission a little too high with the mount so I am just going to trim the opening here a bit.
My guesstimate on ride height turned out pretty good, as well as the track width.
  • Like 4
  • 1 month later...
29 minutes ago, RustedRails said:
How's the truck coming along @Tank.?
Had a detour to work on my father-in-law’s 50 ford truck frame. Just made the exact same fuel/brake setup as the datsun.
B29-C43-CB-B384-4563-8-E28-6-AD4-F0-CA38
Otherwise haven’t done much lately, too busy. But I was playing around with working out the brake booster/prop valve situation this evening actually. I have a list of things to work on while the cab is on. Hopefully will have more soon.
  • Like 4
  • 5 weeks later...
Got some goodies this week!!!!
Pretty much the same setup I have in the Z except for the combo. Speedhuts 3-3/8” gps speedo, tach, and combo. Could not have been easier to install. Literally dropped them in and put the threaded ring on the back, done.
FFBFB4-C8-3-BFD-4-ABC-8900-5-EFD61-C059-
D0-A51917-DBE8-42-B0-9-D3-B-D052853-EEF0
3-BC9-FEEB-1-A45-4-BCB-8-B1-E-3-C65545-E
B6-A3-B476-933-C-4-B8-C-B614-A01-E77-DCA
E8-F7-C398-063-C-4-CF7-8-B7-C-89213-B0-B
188-CA4-AD-CD0-C-4412-9-F7-B-78-D7-E5-EC
  • Like 6
