Stoffregen Motorsports Posted September 14, 2020 Report Share Posted September 14, 2020 Could you modify the lower control arm to lower the shock mounting location? I see about two inches there. Theory is great, but there's also this thing called packaging. I've had people ask me what suspension design software I use on my link suspensions and I tell them that software is only good for basic layout. It still has to fit in the truck. Quote Link to comment
datzenmike Posted September 14, 2020 Report Share Posted September 14, 2020 1 hour ago, FrankRizzo said: Sorry for the late reply Jon, I get 7.7 degrees sitting static. You'll see my coil adjustments are maxed out to the bottom and the truck is still too high... and I have massive mad caster where the top of the wheels tip out..so that is why im trying the Belltech drop spindles. Let me know how you figure out the swaybar mount. We could not get mine to fit with the rod ends he supplies.... Camber. Could you remove both adjustable upper control arms and shorten the blue parts marked JOES? Now you can turn the ends in, reducing the top wheel tilt. Once in you'll have to align the toe Quote Link to comment
Crashtd420 Posted September 14, 2020 Report Share Posted September 14, 2020 17 minutes ago, datzenmike said: Camber. Could you remove both adjustable upper control arms and shorten the blue parts marked JOES? Now you can turn the ends in, reducing the top wheel tilt. Once in you'll have to align the toe That or even shim where it mounts to the frame.... 1 Quote Link to comment
datzenmike Posted September 14, 2020 Report Share Posted September 14, 2020 Geez you're right it's on the inside of the frame, you could shim it forever. Getting close to the coil though Quote Link to comment
FrankRizzo Posted September 15, 2020 Report Share Posted September 15, 2020 (edited) Sorry - camber...but the caster is probably fucked up too. 🙂 Thanks for the suggestions. Very helpful. I'm going to try the drop spindles first. Im not a fan of the coilover adjustments being completely maxed out. Edited September 15, 2020 by FrankRizzo Quote Link to comment
Crashtd420 Posted September 15, 2020 Report Share Posted September 15, 2020 10 hours ago, FrankRizzo said: Sorry - camber...but the caster is probably fucked up too. 🙂 Thanks for the suggestions. Very helpful. I'm going to try the drop spindles first. Im not a fan of the coilover adjustments being completely maxed out. I could be wrong be I think the drop spindle will fix your ride height but not the camber issue..... You wont be altering any suspension geometry just the location of the wheel.... 1 Quote Link to comment
RustedRails Posted September 15, 2020 Report Share Posted September 15, 2020 2 hours ago, Crashtd420 said: I could be wrong be I think the drop spindle will fix your ride height but not the camber issue..... You wont be altering any suspension geometry just the location of the wheel.... If he adds the drop spindle, then adjusts the coilover's, does that change the geometry? Quote Link to comment
datzenmike Posted September 15, 2020 Report Share Posted September 15, 2020 2 hours ago, Crashtd420 said: I could be wrong be I think the drop spindle will fix your ride height but not the camber issue..... You wont be altering any suspension geometry just the location of the wheel.... Quote Link to comment
Crashtd420 Posted September 15, 2020 Report Share Posted September 15, 2020 46 minutes ago, RustedRails said: If he adds the drop spindle, then adjusts the coilover's, does that change the geometry? The height of the coilover does effect it, but I dont think his current coilovers will allow for any more adjustment... if he did a shorter coilover that would lower the truck and tip the top of the tires in .... he might still have to shim or adjust the upper control arm to really set the camber after the desired ride height is achieved.. Quote Link to comment
demo243 Posted September 15, 2020 Report Share Posted September 15, 2020 On 9/14/2020 at 1:43 PM, FrankRizzo said: Sorry for the late reply Jon, I get 7.7 degrees sitting static. You'll see my coil adjustments are maxed out to the bottom and the truck is still too high... and I have massive mad caster where the top of the wheels tip out..so that is why im trying the Belltech drop spindles. Let me know how you figure out the swaybar mount. We could not get mine to fit with the rod ends he supplies.... Did you think about a shorter spring? That would move the adjustable perches up the body and there for allow you to lower them further. It will lower the truck as you do so... you may want to run a helper spring to keep tension on the whole system when fully extended. If you want to keep your current ride height it wont help, but seems like your ride height is beyond what was "stock" or last shimmed/aligned too. I didnt read through the whole thread yet.. but just a thought. I essentially have the same problem of maxxed out coilover adjustment on my 510, but I still want to go lower, so I picked up a shorter spring to move the adjustable perches up higher on the body so I can therefore lower them further. Also looks like maybe you have less shock travel then suspension travel? If you remove the spring do you bottom out the shock before the arm hits the bump? - tough to say from the photo, but that would mean you compressed length is too long. 1 Quote Link to comment
FrankRizzo Posted September 15, 2020 Report Share Posted September 15, 2020 Thanks^ A+ I thought by getting the lower spring perch into the middle of the coilover range rather than maxed out at the bottom, it might help tip the wheels back out.... Im into the drop spindles already, so im going to try it if nothing else to get it more moderate... Sorry to Jack Jon's thread.... 1 Quote Link to comment
SPIDERSHACKOV Posted September 18, 2020 Author Report Share Posted September 18, 2020 All is good, you are having an issue with the install of the frobt suspension kit. I would like to hear about other issues people are having too. Quote Link to comment
Stoffregen Motorsports Posted September 18, 2020 Report Share Posted September 18, 2020 You all need to consider travel. If the shock is more adjustable, or a shorter spring is used, will there be enough travel? Ideally, you would have a long shock with lots of travel, and the suspension only limited by the bump stop. In a perfect world, the amount of travel on the shock and spring would be the same as the amount at the bumpstop, but the bumpstop should do the limiting, not the shock. 1 Quote Link to comment
FrankRizzo Posted September 19, 2020 Report Share Posted September 19, 2020 Looks like I'll be cutting everything out and doing it over again....Chuck hacked my truck. 😪. I found a great local guy that specializes in custom suspension. I think we are going to do shorter springs and shocks in conjunction with the drop spindles. Lower ball joint looking odd... Might have a little interference.... Coil rubs the bracket... Bonus points - weld cracking at the bottom @ 50 miles.... Im actually thankful I made it home...! 2 Quote Link to comment
thisismatt Posted September 19, 2020 Report Share Posted September 19, 2020 Scary welds. Scary mounts. Scary design all around. Beebanis triangulation has such a narrow base, I'd never run that bs. 2 Quote Link to comment
mrbigtanker Posted September 19, 2020 Report Share Posted September 19, 2020 On 9/14/2020 at 10:43 AM, FrankRizzo said: Sorry for the late reply Jon, I get 7.7 degrees sitting static. You'll see my coil adjustments are maxed out to the bottom and the truck is still too high... and I have massive mad caster where the top of the wheels tip out..so that is why im trying the Belltech drop spindles. Let me know how you figure out the swaybar mount. We could not get mine to fit with the rod ends he supplies.... And your top control arm is adjusted all the way with no room and you can clearly see the top of the wheel hanging out. Quote Link to comment
mrbigtanker Posted September 19, 2020 Report Share Posted September 19, 2020 1 hour ago, FrankRizzo said: Looks like I'll be cutting everything out and doing it over again....Chuck hacked my truck. 😪. I found a great local guy that specializes in custom suspension. I think we are going to do shorter springs and shocks in conjunction with the drop spindles. Lower ball joint looking odd... Might have a little interference.... Coil rubs the bracket... Bonus points - weld cracking at the bottom @ 50 miles.... Im actually thankful I made it home...! Wow man I am so sorry, I like Chuck but that is terrible. Thats why I use my guy, none of these issues at all. well it will be right soon. 1 Quote Link to comment
SPIDERSHACKOV Posted September 24, 2020 Author Report Share Posted September 24, 2020 Got the drivers side all mocked up snd ready to weld. 4 Quote Link to comment
SPIDERSHACKOV Posted September 24, 2020 Author Report Share Posted September 24, 2020 I was only able to get 6.5 degrees of shock angle. This is on par with everyone else that has installed this kit. 3 Quote Link to comment
SPIDERSHACKOV Posted September 24, 2020 Author Report Share Posted September 24, 2020 Had to do some major clearancing of the shock mount to clear the shock. 3 Quote Link to comment
SPIDERSHACKOV Posted September 24, 2020 Author Report Share Posted September 24, 2020 I havr just enough clearance for the swaybar to function. 3 Quote Link to comment
mrbigtanker Posted September 24, 2020 Report Share Posted September 24, 2020 35 minutes ago, SPIDERSHACKOV said: I havr just enough clearance for the swaybar to function. Yes mine is close as well. It will be fine. 1 Quote Link to comment
mrbigtanker Posted September 24, 2020 Report Share Posted September 24, 2020 So what are you doing ? Re welding the upper mounts ? Also did you get shorter springs. Quote Link to comment
5t341tH Posted September 26, 2020 Report Share Posted September 26, 2020 With my coilovers, I had to get rid of my sway bar.... so sad Quote Link to comment
mrbigtanker Posted September 26, 2020 Report Share Posted September 26, 2020 2 hours ago, 5t341tH said: With my coilovers, I had to get rid of my sway bar.... so sad Why? Quote Link to comment
